AS15-G Pinout schematic?
  • Glitcher
    • Mar 2013
    • 673
    • USa
    Does anyone have the pin layout for the AS15-G chip? I've been searching but only found one for the AS15-F so far..
  • jesus72
    • Dec 2013
    • mexico
    Re: AS15-G Pinout schematic?
    as15-f=as15-g=as15-u= as15-hf=tsl1014if=hx8915a=ec5575=sl1015i=rm5101=aat7200=
    all are equal.
      G = Green (not color) package
      • Glitcher
        • Mar 2013
        • 673
        • USa
        Wait so they are all the same? Does that mean I would be able to replace a defective AS15-F chip with an AS15-G and itll be fine?
        • newtothis
          • Mar 2013
          • 1556
          • england
          Yup, just figured this myself
          • Glitcher
            • Mar 2013
            • 673
            • USa
            Interesting... Its strange how the AS15-U chip I had to buy was 15$ (in the US)... while all the others AS15-F and AS15-G only costs around 5$. Good note.
            • Glitcher
              • Mar 2013
              • 673
              • USa
              Check out this bodge job I just finished on the AS15-G chip.
              I was given a free 40" sony kdl-40z4100 that was diagnosed by a "sony technician" saying it was a bad panel. I brought home the tv expecting to just part it out but saw that the screen is just extremely overbrightened in white (typical AS15 failure). Usually I don't mess up removing these types of chips but somehow this one was not so lucky... Accidently stripped off 11 traces for the as15 chip....
              I was just going to replace the entire tcon (55.40T02.C05) but the lowest priced was $125 and from china...
              Took while to figure out where the traces led but eventually I figured out most of them. (I noticed much half of the pins actually go to ground) need to figure out how to put over the metal heatsink but in the end finally got the TV back to normal...
              • T30M31
                • Feb 2014
                • 58
                I have a failed KDL-40Z4100 with the "negative image / white haze" problem which I am going to replace the AS15 chip on. During removal of the AS15 when the traces came off were you using a soldering iron or a hot air tool?
                I am planning on using a hot air rework station but just wondering how easy the traces might be to lift off the board.
                Also do you know if the AS15 was glued to the PCB?
                • Glitcher
                  • Mar 2013
                  • 673
                  • USa
                  I was using a hot air tool over the chip (Hot air gun). It would of probably been much easier with a hot air rework station, I need to get one of those soon. The chip seem harder to get off this board than usual but I don't think there was any glue used.
                  I only life 2 traces the first time when I removed the original chip. I placed a new chip on and soldered the two wires for the lifted traces but it didn't fix the contrast problem entirely (I didn't wire it correctly hence I had to add two little resistors when I finally got it right in the end) . I removed the new chip again and ended up lifting even more traces...
                  • Slow_Frank
                    • Jan 2014
                    • 9
                    Try and cut the pins off the IC with a razor knife or side cutters if you can, then just wipe all the pins off with a soldering iron. I find if you are careful this will work way better.
                    • lookimback
                      • Aug 2013
                      • 1489
                      That is sick. I've pulled tracings before and had to add jumpers but this takes the cake. You should win a prize for this one. Lol
                      ------------signature starts here------------
                      • PatrickSaw
                        • Nov 2015
                        • 20
                        • Spain
                        Hello everybody! I'll use this thread, instead of open a new one.
                        I need replace an AS15-U. Could I use an AS15-F? Because I have soldered one AS15F in a T-CON with a AS15U originally, and still fail... ΒΏΒΏ??
                        • Alastair E
                          Chief Womble
                          • Mar 2013
                          • 1963
                          • U.K.
                          I changed one Yesterday--And I changed one today Haha!
                          Will have to order some more. Ones Ive got at the mo are 'F' types but use 'em to replace Any AS-15 I find dead.
                          --Getting quite quick at 'em now, Under 5 mins today.
                          You can get some Strange effects from them, From Very Dark, to Very Light, Weird too high contrast--maybe negative picture, odd colour, loss of a range of colours, Colour reversal--List is endless as to the weirdness of the AS-15F and its friends, also--they don't always get red hot when they fail...
                          TELEFIX
                          • PatrickSaw
                            • Nov 2015
                            • 20
                            • Spain
                            I have this (near to 100% white image, with sound).
                            Faulty T-CON & AS15-U? Only change AS15 fix it? Any fuse or diode?
                            • PatrickSaw
                              • Nov 2015
                              • 20
                              • Spain
                              And this is the T-CON
                              • Alastair E
                                Chief Womble
                                • Mar 2013
                                • 1963
                                • U.K.
                                Best way to find if the AS-15 is messing round is to measure all the 'VGAMA' test-points--There's about 20 of 'em....
                                They should start low, at just under a volt or so and show a climbing voltage range, with around 0.5V higher with advancing VGAMA number test-point....
                                0.5V Vgama 1
                                1V Vgama 2
                                1.5V Vgama 3 etc, upwards.....
                                IF there's a large jump in the trend or a missing voltage on one or two--the AS-15 is stuffed. A chip thats too hot to touch is another (But not always) an indication....
                                Take all the voltage readings, and post 'em here with their ref numbers.
                                TELEFIX
                                • PatrickSaw
                                  • Nov 2015
                                  • 20
                                  • Spain
                                  0.5V Vgama 1
                                  1V Vgama 2
                                  Thanks so much!! Still pending!!
                                  • steviewonder
                                    • Dec 2013
                                    • 183
                                    • england
                                    Also worth noting is that the raydium RM5101 is a direct replacement for the AS15's,
                                    Much more reliable, but also a little more expensive.
                                    Another point is avoid buying the cheap as15's from china-many are out of spec,or don't work at all!
                                    • Terryfictv
                                      • Mar 2011
                                      • 124
                                      I have had one bad new Chinese and thus most good....cost only about $1.00.
                                      BTW, AS15 and AS19 are not the same...
                                      A microscope to check each leg connect is very helpful !
                                      Terry
                                      • Glenwood
                                        • Mar 2021
                                        • United Kingdom
                                        As15-f 0808bg b8110168 what do the numbers mean
                                        • GrafZahl
                                          Searching for Schematic /Boardview for Lenovo T14s Gen4, KT4D5 NM-F221
                                          by GrafZahl
                                          I am searching for Schematic and/or Boardview for Lenovo T14s Gen4, Board: KT4D5 NM-F221
                                          This one is with Nuvoton NPCX997KAABX EC.
                                          I was only able to locate one for a Version with MEC1723 Chip, but this is not the one I need.
                                          I would buy it, if I knew a site selling it, but I just canΒ΄t find it.
                                          03-24-2025, 08:33 AM
                                        • nandraina free
                                          Searching for Lenovo v15-iil schematic and boardview
                                          by nandraina free
                                          Hi
                                          My Lenovo laptop doesn't turn on.So I need schematic and boardview ,please
                                          Thank you in advance
                                          01-08-2025, 03:28 AM
                                        • diazald
                                          Searching for a Peavey XRs schematic
                                          by diazald
                                          Searching for a Peavey XRs Schematic. A SMD capacitor with no values cracked on me. I have searched off and on for months with no luck.
                                          Any help would be greatly appreciated
                                          11-24-2023, 02:49 AM
                                        • Mark_Karlsson
                                          Searching for an ADA1100 schematic
                                          by Mark_Karlsson
                                          Hello.
                                          I'm a self-employed mechanic/machinist. I'm attempting to fix my friend's Mustang dynamometer. He replaced the power supply but installed too new of a unit, which I discovered had no -5 volt supply. After installing the correct supply, this rectified the problem we were having with the load cell. But I'm still getting no speed output on the monitor screen.
                                          I've checked the hall effect sensor and I am getting the signal to the daughterboard. I traced the signal through three processors in the lower daughterboard. I can see the signal at the input to the upper...
                                          08-15-2022, 03:52 PM
                                        • TinkerTron
                                          Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                                          by TinkerTron
                                          Hey everyone,
                                          I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                                          Instead, here's what's been bugging me so far:
                                          The schematic...
                                          03-06-2025, 02:03 PM
