Lg 47LH40-UA
  • oldhippie100
    • Dec 2013
    • 29
    • usa
    #41
    Re: Lg 47LH40-UA
    ok got ya..thanks
    • rickem3
      • May 2014
      Re: Lg 47LH40-UA
      Originally posted by budm
      I do not believe you will find them in local store since these are used mainly in high voltage circuit such as the backlights inverter. Mouser and Digikey, or EBAY will be the place to look. I will look at electronics recycle place to see if I can find them on old boards I collect.
      So you need the 33 and 54, one each? If I find them this Sat I can mail them to you since they will fit into regular envelope.
      I'm new here and have the same burnt 33 & 54. Hard to find them.
      • rickem3
        • May 2014
        Re: Lg 47LH40-UA
        I'm so thankful this fix worked for me. Again thanks you.
        • Larry_Ellison
          • Sep 2014
          • 9
          Re: Lg 47LH40-UA
          Good Morning,
          Can't make it out and can't find a spec on this board. Can anyone tell me the value of D605? It is located near the red circle in the first series of images.
          Thank you.
          • shawn84d
            • Apr 2015
            • 8
            • canada
            #45
            Re: Lg 47LH40-UA
            hi everyone i had the same problem as this but i have a lg 47LF11 i changed the 2 caps i now get a full picture and sound but the screen flashes about 3 times then the tv will shutoff has anyone had this issue before
            • shawn84d
              • Apr 2015
              • 8
              • canada
              #46
              Re: Lg 47LH40-UA
              here is a pic of my board same as the others but rev 1.4 anyway my issue is i am getting 64.0 v from the yellow box and the 2 black disc caps get hot i was going to chance those as well but wanted to wait to order more parts so im just wanting to know if anyone has had issues with the box or not and where can i find one from
                Re: Lg 47LH40-UA
                What GND point did you use to get the reading of 64V from the YELLOW BOX which by the way is the PFC INDUCTOR for producing boosted Voltage to run the main power supply and inverter circuits.
                You should see >360VDC between the two legs of the main filter caps when TV is turned on.
                Did you replace those two blue ballast caps?
                • shawn84d
                  • Apr 2015
                  • 8
                  • canada
                  #48
                  Re: Lg 47LH40-UA
                  Ok I re tested the PFC INDUCTOR I'm getting 170dc v in standby when I power the tv on it goes down to 111 dc v also the 2 black temperature thermistor (Dsc 2.5d-15) are getting realy hot there is a faint buzzing sound when the power goes on I think it is from the PFC INDUCTOR
                    Re: Lg 47LH40-UA
                    Are you measuring the DCV on the inductor? You need to test the DCV between the two legs of the main filter cap.
                    http://assets.shopjimmy.com/media/ca...ay57681601.jpg
                    Shopjimmy does not have picture of bottom side so you nee to provide us one with really well focused so we can easily see the traces.
                    • shawn84d
                      • Apr 2015
                      • 8
                      • canada
                      #50
                      Re: Lg 47LH40-UA
                      pics
                        Re: Lg 47LH40-UA
                        OK, those 2 thermistors are connected in series to feed the PFC Voltage booster circuit and there is no bypass relay and as they get warm the resistance should go down to reduce the power dissipation.
                        So we need to find out if the PFC Voltage is working or not first.
                        Also you circled those two blue ballast caps, did you replace them?
                        • shawn84d
                          • Apr 2015
                          • 8
                          • canada
                          #52
                          Re: Lg 47LH40-UA
                          Yes I did replace the 2 blue caps the one was burnt that was the first thing I replaced I will check the pic voltage tomorrow
                          • shawn84d
                            • Apr 2015
                            • 8
                            • canada
                            #53
                            Re: Lg 47LH40-UA
                            Not sure where to go from here but now my tv won't power up at all I'm getting 120 + v through out the board
                            • newtothis
                              • Mar 2013
                              • 1556
                              • england
                              #54
                              Re: Lg 47LH40-UA
                              is that the voltage at the main cap?
                              We need to know this voltage, budm has asked for it a couple of times already
                                Re: Lg 47LH40-UA
                                And I still do not get the answer as to what GND ref point is used for the measurement.
                                I just about had enough asking the same question over and over again, it has been happening a lot lately with lots of people I am trying help.
                                I am really getting really tired of it.
                                • newtothis
                                  • Mar 2013
                                  • 1556
                                  • england
                                  #56
                                  Re: Lg 47LH40-UA
                                  Yes I have noticed a lot of people who don't answer and come back with more questions and their own theories instead of following what is being asked.
                                  • shawn84d
                                    • Apr 2015
                                    • 8
                                    • canada
                                    #57
                                    Re: Lg 47LH40-UA
                                    i was using a couple main one was the screw hole on the main board marked pg105 if thats not it where is the best gnd point should i use
                                    • pigpen007
                                      • Dec 2019
                                      Re: Lg 47LH40-UA
                                      Removing both c402 and c407 caps and placing 100pf cap instead works.
                                      My c407 was burnt to a crisp and it seemed smaller than the 33pf cap in parallel to it (side note that my 33pf is in the c402 spot). So I'm assuming that my c407 is a 22pf cap, unlike the 54pf which i'm seeing posted here.
                                      None the less, I found a 100 pf 6kv cap locally for $1.50CAD and removed the 33pf.
                                      Seems to be working fine. I've since ordered a few 22pf and 10pf caps if something doesnt feel right.
                                      • topgun
                                        • Aug 2010
                                        #59
                                        Re: Lg 47LH40-UA
                                        I replaced c402 and c407 with 2 - 27pf and 1 - 33pf, both from Mouser.com. Soldered the legs of one of the 27pf to the other and then soldered to the board. Seems to be working good. I know this is an old post but this old unit is still working good.
                                          • 12276
                                          • U.S.
                                          #60
                                          Re: Lg 47LH40-UA
                                          Indeed, they made the ccfl tvs much better than the led and oleds that constantly have problems or are made to break right after warranty.
                                          • tranquility
                                            newbie needs capacitor sizes. HP Spectre X360. schematic maybe available
                                            by tranquility
                                            hello, i am very new to laptop repair and generell electronics
                                            i have a HP Spectre X360 Convertible 13 - ap0016ng
                                            motherboard number DA0X36MBAE0 REV E
                                            massive burned and shortet mosfets. after removing them still shortet in the i think "main power rail"
                                            found a shorted capacitor. removed it and the short is gone.
                                            i want to try a crazy repair which is hard because the mosfets are like welded on one side to the track. is there a method to get this loose ?
                                            in this area another capacitor was shortet.
                                            12-06-2024, 04:12 AM
                                          • UL161
                                            Need Help Identifying Parts on a crossover and a few other newbie questions
                                            by UL161
                                            Hi I am trying to refurbish this crossover with some higher quality poly-caps/parts... The speaker is a in-wall Polk 65-RT... Key questions I have are:
                                            1) What in the world is the yellow part on the board (label is MET 1.0J 100V)?... Should I even consider replacing it?
                                            2) The 470uF cap.... Does anyone know have a suggestion as to where I can find a reasonable audio quality polycap near that value? (or at least 3 160s or the like?) { I don't want to spend $70 just to replace this one if I can) (maybe even someone looking at this circuit could even tell if this cap is important...
                                            09-29-2024, 03:17 PM
                                          • cloghin
                                            newbie questions
                                            by cloghin
                                            Apologies if I am asking the wrong questions , but not sure how else to start:
                                            I have an A2251 / 820-01949 Mac book pro with no power, 20 v on USBC meter and 0.05 Amps. Following this link ( below)
                                            * Do I need to remove the board from case so I can access its other side ? The link calls for measuring PP3v3_S5 ( I suppose this is in diode mode with positive probe on ground) , but I don't know how to do that without removing the board from case.
                                            * I have the FlexBV board , are the values displayed in volts diode mode only ? Because my etekcity multimeter shows...
                                            09-26-2024, 11:48 AM
                                          • Cappy Oligan
                                            Newbie about to dive in with the leads. Safety advice please.
                                            by Cappy Oligan
                                            I'm new to electronic repair. Trying to troubleshoot a Dell monitor that only has an AC port for power. I'm concerned about safety and not getting shocked. Should I order an isolation transformer and plug in the monitor into that and proceed with testing the board inside? Or should I get a DC power supply and limit the amps and connect the voltage to a pin somewhere inside where 19V DC is first expected? Or both? Thanks.
                                            08-30-2024, 05:40 PM
                                          • Jofo
                                            eVGA GTX 970 - newbie fixing
                                            by Jofo
                                            I am a newbie and this is my first repair attempt on eVGA GTX 970 that I bought from one guy. He said that his power supply died and took the graphics card with it and smelled smoke from the card too. When I took the card apart, one of the high-side MOSFETs was obviously damaged and there was a short on one of the PCIe connectors.
                                            The situation now is as follows:
                                            - The choke was already damaged when I disassembled the card
                                            - I've desoldered the high-side MOSFET "H" that was damaged, short gone...
                                            09-29-2022, 03:22 AM
