I'm new to electronic repair. Trying to troubleshoot a Dell monitor that only has an AC port for power. I'm concerned about safety and not getting shocked. Should I order an isolation transformer and plug in the monitor into that and proceed with testing the board inside? Or should I get a DC power supply and limit the amps and connect the voltage to a pin somewhere inside where 19V DC is first expected? Or both? Thanks.
Newbie about to dive in with the leads. Safety advice please.
Tags: None
isolation transformers dont stop you getting shocked, they make it more dangerous infact
they pass enough current to kill you but they prevent an RCD or GFCI from tripping!
just learn where to NOT put your fingers - like not touching heatsinks because they are often live.
Hi CapLeaker, I definitely would like to avoid having the monitor in AC mains. That's why I'm looking for safety addons or alternative ways to measure when troubleshooting, like a DC power supply. I'm totally new to this so still reading and watching videos how other people do it. Thanks.Comment
remember ohms law is very important.
remember 1.414 That is to convert AC to DC. let's say 100VAC x 1.414 = 141.4 VDC
Voltages with a working PFC are 380 to 400VDC on the main filter capacitor. If you see 320VDC for example, the PFC isn't working.
Search some usernames and read some threads here on badcaps. There are some real entertaining threads here.Comment
Awesome advice and I will remember this. The monitor actually does work but gets vertical lines. I'm watching all kinds of videos now trying to find information on what are all the different voltage rails in there . Basically the very beginnings of understanding monitors.Comment
by KYBOSHPicked up a Tektronix type 422 oscilloscope locally for a few bucks last year.
It wouldnt power on at all so I stowed it away under my bench for later testing.
Today I remembered it was down there and pulled it out to see what was what.
I checked for continuity and everything checked out.
There was a burned smell and a resistor was replaced with a temporary replacement (see yellow box in picture).
The burned smell is very pungent/acidic and I am not familiar with these vintage electronics to know whether I am smelling the remains of the replaced resistor or...1 Photo -
by fadi90Hi everyone,
I'm working on repairing a Pilz PNOZ X4 safety relay module. When I opened it up, I found some of the connector pins detached from their pads. I replaced the connector with individual wires, but the issue remains.
The module is set to dual-channel mode with manual start. In this mode:- Y36-Y37 and Y1-Y2 are bridged.
- 24VDC is applied across A1-A2.
- It monitors two emergency circuits (S11→S12 and S11→S52).
- When both are closed (24V present on S12 and S52) and the start button is pressed (S33 connected to S34), the NO contacts (13-14, 23-24, 33-34)
by Borse2008Hi everyone,
I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:- The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
- There’s
07-15-2025, 04:55 AM -
by Green ProbeHi, Im looking to replace some EMP21N03 mosfets on an Alienware motherboard, but I'm having trouble finding a legit supplier. The ones that are available from China have pictures with the engraved logo looking very scratchy and sketchy. Nobody in the US sells them. I'm trying to find a compatible mosfet, but I'm not well versed enough to be confident im making the right choice. Does anyone have a suggestion or advice that could help me find the right mosfet? Thanks!
by user234Hi all,
Recently installed a new motherboard but during the process I seemed to have damaged my Gigabyte Eagle 3060 Ti card.
My motherboard ROG STRIX B550-A is detecting an issue with the VGA (light ON)
I have attached 2 photo's of my GPU board, one above and the other is what I believe to be the 5V - as you can see, this has visual damage so looks suspicious to me.
If I replace this part what are the odds this will resolve the issue? - any additional information on where to source the parts would be much apricated too!
This is...-
05-10-2025, 04:25 AM -
- Loading...
