pioneer help
  • subarufreek
    • Nov 2013
    • 53
    pioneer help
    hello, i have just replaced the power supply in my pioneer pdp6070pu and now the blue light blinks 13 times. i have looked into this and it says its the main assy or power supply. i know i have to reset it but the manual says to turn the tv guide feature off and nowhere does it tell me how to. any help on this?
  • mmartell
    • Oct 2013
    • 3189
    Re: pioneer help
    Do a factory reset - the tv guide feature is OFF by default until you go through the setup process for it.
    • subarufreek
      • Nov 2013
      • 53
      Re: pioneer help
      thats what i assumed. but they screen wont even turn on to see what im doing.
      • mmartell
        • Oct 2013
        • 3189
        Re: pioneer help
        Hmm.. there is a way to do it through the rs232 port but I've never used that. I suspect even if you could do a factory reset it wouldn't get your raster back.
        Have you tried the factory reset key combination ? I ask because you don't turn the set on FIRST to enter factory mode so I guess it's possible it will boot up in Factory mode if that really is your problem.
        • subarufreek
          • Nov 2013
          • 53
          Re: pioneer help
          well i bought it and the guy that said it just wouldnt turn on so i took the back off and boom, first thing is see is i need to replace the psu. and yes i tried the reset combo while its in standby, but when i push the power button at the end of the combo it tries to turn on and same thing. screen turns the grayish color and hear the relays clicking but the blue led blinks 13 times again.
          • subarufreek
            • Nov 2013
            • 53
            Re: pioneer help
            heres some pics, lol kind of self explanatory, but i think something else is wrong now.
            • mmartell
              • Oct 2013
              • 3189
              Re: pioneer help
              Oh my that can't be good. Where did you get the PSU from ?
              • subarufreek
                • Nov 2013
                • 53
                Re: pioneer help
                ebay. . but before it didnt do anything and now its kind of powering on so thats a good sign. right? lol
                • mmartell
                  • Oct 2013
                  • 3189
                  Re: pioneer help
                  Ya it WAS a good sign. It's dead again now ?
                  • subarufreek
                    • Nov 2013
                    • 53
                    Re: pioneer help
                    well not completely. like before it did absolutely nothing, no lights or anything. now its been doing the same thing since i put it back together, the 13 blinks. i dont think it has anything to do with the psu considering that it is getting power now, whereas before it was just dead
                    • mmartell
                      • Oct 2013
                      • 3189
                      Re: pioneer help
                      13 blinks IS power supply failure. You may have changed one bad psu for another.
                      • subarufreek
                        • Nov 2013
                        • 53
                        Re: pioneer help
                        i took the back off again and realized that this little red light is on, its located on the main board i believe. any clue?
                        • subarufreek
                          • Nov 2013
                          • 53
                          Re: pioneer help
                          from what ive read its the main assy or the psu. any clue what "MTB-RST2/RST4" is? thats straight from the manual.
                          • mmartell
                            • Oct 2013
                            • 3189
                            Re: pioneer help
                            Its missing voltages in the reset lines.
                            • subarufreek
                              • Nov 2013
                              • 53
                              Re: pioneer help
                              so test all voltages on the lines that were disconnected? im confused.
                              • mmartell
                                • Oct 2013
                                • 3189
                                Re: pioneer help
                                Check your output voltages at power supply first.
                                This is from the 6010 SM
                                • subarufreek
                                  • Nov 2013
                                  • 53
                                  Re: pioneer help
                                  thanks i will look into that over the week end. here to hope!
                                  • subarufreek
                                    • Nov 2013
                                    • 53
                                    Re: pioneer help
                                    ok, i checked the output voltages and all checkout good but the connector jw271 there are 4 pins that should read 5.1 and are reading 3.4. would that make that much of a difference? also now the blue and red leds on the front are staying on like they should and when i enter the remote code it tries to turn on but turns back off and the leds dont blink. any clues or what to do next is very appreciated.
                                    • mmartell
                                      • Oct 2013
                                      • 3189
                                      Re: pioneer help
                                      Solid red and blue are Trap Switch.
                                      The 3.4v is low not sure how that would impact the relevant circuits.
                                      • mmartell
                                        • Oct 2013
                                        • 3189
                                        Re: pioneer help
                                        Have you ever gone into the factory service mode ? Sounds like you just aren't doing it right and the set refuses to turn on because the Trap Switch was tripped.
                                        • Bushcat
                                          Pioneer PL-X9 motor speed control wobble
                                          by Bushcat
                                          I'm starting to re-cap a Pioneer PL-X9 turntable, specifically the motor control board, because although everything tests out OK according to the service manual, the speed wavers slightly despite the quartz lock light remaining on. So, I've decided to re-cap that board since it's the cheapest next step...
                                          Pioneer's passive component naming convention is clear to me. For example, CSZA R22M 35 is tantalum, radial leads, 0.22uF, 20%, 35V.
                                          BUT there are two capacitors on the board which have actual Pioneer part numbers: PCL-042. I can tell they are 0.1uF, 16V but don't...
                                          05-24-2023, 03:36 AM
                                          ME Firmware Cleaning Guide
                                          by SMDFlea
                                          Here`s a quick ME Firmware cleaning guide.
                                          The guide is basic,its main goal is to show you how to use intel FIT,its highly recommended that you all follow the guide posted at win-raid
                                          (The attached FIT version is 11, if your ME Firmware (FW) is not 11.0.*.* follow the win-raid guide. Use the tools version for your ME FW, for example: ME System Tools v9.1 For systems running ME v9.0 - v9.1)
                                          A video,software (intel FIT) and practice bios are all included. I`ll post a better video and more advanced guide at a later date.
                                          1. Open the...
                                          09-09-2020, 09:10 AM
                                        • EduCabral
                                          [Help Needed] Yatour YT-M06 (Pioneer 1) – Firmware or Schematic Request
                                          by EduCabral
                                          I'm currently working on reviving a Yatour YT-M06 CD Changer Emulator module for use with a Pioneer 1 interface (specifically with a DEH-P5950IB head unit).
                                          While the unit is recognized as a CD changer, none of the USB, SD, or AUX features respond, which leads me to believe the firmware may be corrupted or incompatible.
                                          🔧 Details:
                                          • Model: YT-M06
                                          • Interface: Pioneer 1
                                          • MCU: Fujitsu MB89F202
                                          • Goal: Find a valid .bin firmware file or memory dump from a working unit
                                          I'm happy to attempt flashing, analyzing memory dumps, or doing hardware-level...
                                          07-15-2025, 12:26 AM
                                        • ktmmotocross
                                          ps5 bv, schem or repair guide
                                          by ktmmotocross
                                          Have this PS5 EDM-033 with one beep. error is some short but i dont find one on main rails. need schem or guide to check all rails
                                          I would like to have BV, schem or repair guide so add them here
                                          07-02-2025, 11:57 PM
                                        • acedogblast
                                          by acedogblast
                                          11-02-2024, 05:13 PM
