pioneer help
  • mmartell
    • Oct 2013
    • 3189
    Re: pioneer help
    Your PSU is putting out 3.4v where it should be 5.1v that is not "putting out the voltage it should".
    He can't reset the trap switch fault because he can't enter factory mode.
    It IS possible you are not entering the keystrokes exactly right.
    @phillies fan I saw you had another thread with a Pio what ever happened in your case ?
    @suburu my fans do NOT come on after power up. They are likely temp controlled. The motherboard is covered by an input board so nothing can be seen behind it.
    • subarufreek
      • Nov 2013
      • 53
      Re: pioneer help
      ill call some shops around town tomorrow and see how much they charge to simply enter in a code. if its too much guess ill have to take a loss. or another gamble with trying to buy a main board. theres only those 3 maybe 4 wires that are reading 3.4 where it should be 5.1. damn this tv
      • mmartell
        • Oct 2013
        • 3189
        Re: pioneer help
        If you used the cadence I told you about to enter the codes it should have worked. That being said with a non-genuine remote we can't even be sure that the display button isn't mapped to the info button, which would of course would not work. Do you know of a Pioneer tv anywhere you could practice on ?
        Last edited by mmartell; 12-18-2013, 11:25 PM. Reason: little goddamn smartphone keys
        • philliesfan30m
          • Aug 2013
          • 542
          Re: pioneer help
          mine would let me reset it but then it would go right back into the trap switch fault and never let me enter the factory mode just a repeating problem which was caused by the mainboard i believe. it would reset but would go right back even with the trap switch jumpered.i didn't want to put any more time into it and didn't think it was worth putting any money into it.
          • subarufreek
            • Nov 2013
            • 53
            Re: pioneer help
            nope, ive even asked all my friends on facebook if they had one i could check with and no luck. its a pioneer brand and is the same exact model that came with the tv if that helps at all.
            • mmartell
              • Oct 2013
              • 3189
              Re: pioneer help
              Did you hold the "Ok" button for five seconds until the message popped up on screen "Factory settings have been restored..." ?
              • mmartell
                • Oct 2013
                • 3189
                Re: pioneer help
                Earlier you said it was a "replica" ?
                • philliesfan30m
                  • Aug 2013
                  • 542
                  Re: pioneer help
                  i just went back and saw what you posted and when i reset the trap switch the screen would come on for a few seconds but never let me get to factory mode. i would say it is your mainboard
                  • subarufreek
                    • Nov 2013
                    • 53
                    Re: pioneer help
                    ive never gotten the tv to stay on so i can see anything on the screen. all i can see that the screen is working is it turning like a gray color when i hear the relay click but then it turns back to black.
                    • subarufreek
                      • Nov 2013
                      • 53
                      Re: pioneer help
                      well a replica of what came with the tv. its not the one that was purchased with the tv.
                      • subarufreek
                        • Nov 2013
                        • 53
                        Re: pioneer help
                        well damn, the last cheap mainboard for my tv just sold. not going to pay over $100 for just the board. unless i can luck out and find someone on here or some other forum.
                        • philliesfan30m
                          • Aug 2013
                          • 542
                          Re: pioneer help
                          the screen wouldn't stay up long enough for anything to be posted on it before it went back to the trap switch fault
                          • subarufreek
                            • Nov 2013
                            • 53
                            Re: pioneer help
                            sounds exactly like what mine is doing
                            • philliesfan30m
                              • Aug 2013
                              • 542
                              Re: pioneer help
                              thats exactly what mine did it showed a grey screen then went black
                              • subarufreek
                                • Nov 2013
                                • 53
                                Re: pioneer help
                                but you just said forget it and didnt mess with it anymore?
                                • philliesfan30m
                                  • Aug 2013
                                  • 542
                                  Re: pioneer help
                                  i stayed up for days messing with that tv before i said to hell with it!
                                  • philliesfan30m
                                    • Aug 2013
                                    • 542
                                    Re: pioneer help
                                    i tried everything but replace the mainboard because the cheapest 1 i saw was over 100 dollars and i didn't think it was worth it and it was given to me and i had enough tv's just didn't have a plasma and wanted 1 just for the hell of it
                                    • subarufreek
                                      • Nov 2013
                                      • 53
                                      Re: pioneer help
                                      yea, im in the same boat but i feel like im like right on the edge of figuring it out and its bugging me to death. not to mention i only have about $100 in it.
                                      • philliesfan30m
                                        • Aug 2013
                                        • 542
                                        Re: pioneer help
                                        if i remember correctly tom66 said he was messing with a pioneer too and he said it is still in his shed i don't remember what model etc. but he didn't fix his either. i am not sure but i think he said that. i don't remember what the problem was with his or if he said he just said he didn't mess with it and was gonna use it for parts or something
                                        • subarufreek
                                          • Nov 2013
                                          • 53
                                          Re: pioneer help
                                          yea, there was one last main board i found for $75 and it just sold on ebay today. wish i wouldve bought it then, now the cheapest one i can find is $175 and theres no way im going to take that gamble. i also still have until the 26th to possibly return this PSU
                                          • Bushcat
                                            Pioneer PL-X9 motor speed control wobble
                                            by Bushcat
                                            I'm starting to re-cap a Pioneer PL-X9 turntable, specifically the motor control board, because although everything tests out OK according to the service manual, the speed wavers slightly despite the quartz lock light remaining on. So, I've decided to re-cap that board since it's the cheapest next step...
                                            Pioneer's passive component naming convention is clear to me. For example, CSZA R22M 35 is tantalum, radial leads, 0.22uF, 20%, 35V.
                                            BUT there are two capacitors on the board which have actual Pioneer part numbers: PCL-042. I can tell they are 0.1uF, 16V but don't...
                                            05-24-2023, 03:36 AM
                                            ME Firmware Cleaning Guide
                                            by SMDFlea
                                            Here`s a quick ME Firmware cleaning guide.
                                            The guide is basic,its main goal is to show you how to use intel FIT,its highly recommended that you all follow the guide posted at win-raid
                                            (The attached FIT version is 11, if your ME Firmware (FW) is not 11.0.*.* follow the win-raid guide. Use the tools version for your ME FW, for example: ME System Tools v9.1 For systems running ME v9.0 - v9.1)
                                            A video,software (intel FIT) and practice bios are all included. I`ll post a better video and more advanced guide at a later date.
                                            1. Open the...
                                            09-09-2020, 09:10 AM
                                          • EduCabral
                                            [Help Needed] Yatour YT-M06 (Pioneer 1) – Firmware or Schematic Request
                                            by EduCabral
                                            I'm currently working on reviving a Yatour YT-M06 CD Changer Emulator module for use with a Pioneer 1 interface (specifically with a DEH-P5950IB head unit).
                                            While the unit is recognized as a CD changer, none of the USB, SD, or AUX features respond, which leads me to believe the firmware may be corrupted or incompatible.
                                            🔧 Details:
                                            • Model: YT-M06
                                            • Interface: Pioneer 1
                                            • MCU: Fujitsu MB89F202
                                            • Goal: Find a valid .bin firmware file or memory dump from a working unit
                                            I'm happy to attempt flashing, analyzing memory dumps, or doing hardware-level...
                                            07-15-2025, 12:26 AM
                                          • ktmmotocross
                                            ps5 bv, schem or repair guide
                                            by ktmmotocross
                                            Have this PS5 EDM-033 with one beep. error is some short but i dont find one on main rails. need schem or guide to check all rails
                                            I would like to have BV, schem or repair guide so add them here
                                            07-02-2025, 11:57 PM
                                          • acedogblast
                                            by acedogblast
                                            11-02-2024, 05:13 PM
