pioneer help
  • philliesfan30m
    • Aug 2013
    • 542
    Re: pioneer help
    using a resistor 1k
    • subarufreek
      • Nov 2013
      • 53
      Re: pioneer help
      any pics? sorry im just better with pics. or i can wait for my dad, hes a little more inclined for stuff like this. lol
      • philliesfan30m
        • Aug 2013
        • 542
        Re: pioneer help
        https://www.google.com/#q=picture+of+1k+resistor
        then disconnect the connector only on the mainboard end that has the ps-on and 5vstb going to it and put 1 end of the resistor in the ps-on and 1 end in the 5vstb and power on the tv
        • subarufreek
          • Nov 2013
          • 53
          Re: pioneer help
          ok, ill get to this hopefully in the next day or 2, thanks so much for the help so far guys!
          • mmartell
            • Oct 2013
            • 3189
            Re: pioneer help
            Yes you need to perform the test with the resistor to see among other things if the mainboard is pulling down that 5.1v supply or if the psu is to blame.
            • newtothis
              • Mar 2013
              • 1556
              • england
              #106
              Re: pioneer help
              We can pinpoint what board is at fault once done... Anything from 470ohms to 1kohm will do.... Even if they are taken from an old board. I have a feeling the psu is at fault.... Disconnect the entire main to psu connector and power the set on from the mains first... I have a feeling you will still have more than 1 voltage present
              • Bushcat
                Pioneer PL-X9 motor speed control wobble
                by Bushcat
                I'm starting to re-cap a Pioneer PL-X9 turntable, specifically the motor control board, because although everything tests out OK according to the service manual, the speed wavers slightly despite the quartz lock light remaining on. So, I've decided to re-cap that board since it's the cheapest next step...
                Pioneer's passive component naming convention is clear to me. For example, CSZA R22M 35 is tantalum, radial leads, 0.22uF, 20%, 35V.
                BUT there are two capacitors on the board which have actual Pioneer part numbers: PCL-042. I can tell they are 0.1uF, 16V but don't...
                05-24-2023, 03:36 AM
                ME Firmware Cleaning Guide
                by SMDFlea
                Here`s a quick ME Firmware cleaning guide.
                The guide is basic,its main goal is to show you how to use intel FIT,its highly recommended that you all follow the guide posted at win-raid
                (The attached FIT version is 11, if your ME Firmware (FW) is not 11.0.*.* follow the win-raid guide. Use the tools version for your ME FW, for example: ME System Tools v9.1 For systems running ME v9.0 - v9.1)
                A video,software (intel FIT) and practice bios are all included. I`ll post a better video and more advanced guide at a later date.
                1. Open the...
                09-09-2020, 09:10 AM
              • EduCabral
                [Help Needed] Yatour YT-M06 (Pioneer 1) – Firmware or Schematic Request
                by EduCabral
                I'm currently working on reviving a Yatour YT-M06 CD Changer Emulator module for use with a Pioneer 1 interface (specifically with a DEH-P5950IB head unit).
                While the unit is recognized as a CD changer, none of the USB, SD, or AUX features respond, which leads me to believe the firmware may be corrupted or incompatible.
                🔧 Details:
                • Model: YT-M06
                • Interface: Pioneer 1
                • MCU: Fujitsu MB89F202
                • Goal: Find a valid .bin firmware file or memory dump from a working unit
                I'm happy to attempt flashing, analyzing memory dumps, or doing hardware-level...
                Yesterday, 12:26 AM
              • ktmmotocross
                ps5 bv, schem or repair guide
                by ktmmotocross
                Have this PS5 EDM-033 with one beep. error is some short but i dont find one on main rails. need schem or guide to check all rails
                I would like to have BV, schem or repair guide so add them here
                07-02-2025, 11:57 PM
              • acedogblast
                by acedogblast
                11-02-2024, 05:13 PM
