pioneer help
  • subarufreek
    • Nov 2013
    • 53
    Re: pioneer help
    no the tv wont stay on, service factory mode being hit display wait 4-7 secs then left up left right power? if so yes i tried that and it will click turn on like the grayish color then back off and that red light on the main board will be on, but no led blinks on the front, is the light on the main board supposed to stay on?
    • mmartell
      • Oct 2013
      • 3189
      Re: pioneer help
      I mean have you ever entered Factory Service mode on ANY Pioneer ? I did it a few years back and then recently tried again and had a devil of a time getting it right.
      Try hitting the power button and see if the set acts exactly the same as when you try to enter factory mode. If it's the same I will attempt to coach you on how to press the buttons.
      • subarufreek
        • Nov 2013
        • 53
        Re: pioneer help
        nope, never done it before, and when i hit the power button by itself it doesnt do anything. the red and blue light stay on but nothing else, and when i do the reset code that is when it attempts to turn on and do what i mentioned above.
        • mmartell
          • Oct 2013
          • 3189
          Re: pioneer help
          Ok just to rule it out try this... Count "one thousand one, one thousand two" etc...
          Start counting by HOLDING the Display button for a count of three. Let go but keep counting.
          On "eight" start the rest of the sequence pushing one button per second so the power button gets pushed at "twelve".
          That works for me all the time every time. Report back if that changes anything or not.
          • mmartell
            • Oct 2013
            • 3189
            Re: pioneer help
            About lights on the main board I can't report until tomorrow after I receive the board I'm waiting for but keep in mind I have a different model.
            • subarufreek
              • Nov 2013
              • 53
              Re: pioneer help
              ok, will do. thanks. what model is yours?
              • mmartell
                • Oct 2013
                • 3189
                Re: pioneer help
                6010fd
                • subarufreek
                  • Nov 2013
                  • 53
                  Re: pioneer help
                  ok, well i tried it like 1o times and same thing every time. any other ideas? also i talked to another guy that was talking about bypassing the trap switch. any clue on that?
                  • mmartell
                    • Oct 2013
                    • 3189
                    Re: pioneer help
                    You can't "bypass it" after it's been tripped you have to close the switch and clear the flag. You can insert a jumper wire in the harness going to the switch and it will look to the micro as the switch it always closed.
                    Wait. You do have the trap disabled somehow with the back off while you are working on this don't you ??
                    • subarufreek
                      • Nov 2013
                      • 53
                      Re: pioneer help
                      yea, i have a clip on it to keep it pushed down. is that right?
                      • subarufreek
                        • Nov 2013
                        • 53
                        Re: pioneer help
                        also the fan doesnt come on. should it come on immediately?
                        • mmartell
                          • Oct 2013
                          • 3189
                          Re: pioneer help
                          Yes that's right, as long as you're sure the switch is registering as closed. You can take the connector off and check for continuity directly on the switch to be sure.
                          • mmartell
                            • Oct 2013
                            • 3189
                            Re: pioneer help
                            I can check the fan for you tomorrow.
                            I need to reread this thread before I ask you the same questins over again lol.
                            • subarufreek
                              • Nov 2013
                              • 53
                              Re: pioneer help
                              ok, thanks again
                              • mmartell
                                • Oct 2013
                                • 3189
                                Re: pioneer help
                                Ok I'm going to assume like any reasonable person that with damage like in the pic you still have an issue with the psu. Did the original have any physical damage to it as well ?
                                Is the burnt section where the main power comes in ?
                                • mmartell
                                  • Oct 2013
                                  • 3189
                                  Re: pioneer help
                                  Whoa those wires have been blown off ! How is that set working at all ?? What am I missing here ?
                                  • subarufreek
                                    • Nov 2013
                                    • 53
                                    Re: pioneer help
                                    it wasnt working when i bought it, nothing at all. no lights or anything. yes the burnt section is where the main power goes in, i bought the new board and cut the wires down and put new metal clamps on it and reused the little white connector. now its gettin the power and all that like it should, just cant figure out where to look next.
                                    • mmartell
                                      • Oct 2013
                                      • 3189
                                      Re: pioneer help
                                      Ok so the pic of the burnt power supply is the previous power supply which was replaced.
                                      Did you take the connector off the trap switch and measure with a meter to verify the switch is closed ? That probably seems useless but if the switch isn't closed or has failed open you could be chasing the moon and never fix it.
                                      • subarufreek
                                        • Nov 2013
                                        • 53
                                        Re: pioneer help
                                        im not understanding what youre meaning by closed? like pushed in to make sure the tv thinks that "the back is closed"?
                                        • mmartell
                                          • Oct 2013
                                          • 3189
                                          Re: pioneer help
                                          A switch is either open (no contact) or closed (continuity). Like anything else a switch can fail and in this case if the switch is broken no amount of pushing on it will "close" it if it has failed open.
                                          That's why I suggest you simply test the switch or bypass it altogether by inserting a jumper wire in the connector.
                                          • Bushcat
                                            Pioneer PL-X9 motor speed control wobble
                                            by Bushcat
                                            I'm starting to re-cap a Pioneer PL-X9 turntable, specifically the motor control board, because although everything tests out OK according to the service manual, the speed wavers slightly despite the quartz lock light remaining on. So, I've decided to re-cap that board since it's the cheapest next step...
                                            Pioneer's passive component naming convention is clear to me. For example, CSZA R22M 35 is tantalum, radial leads, 0.22uF, 20%, 35V.
                                            BUT there are two capacitors on the board which have actual Pioneer part numbers: PCL-042. I can tell they are 0.1uF, 16V but don't...
                                            05-24-2023, 03:36 AM
                                            ME Firmware Cleaning Guide
                                            by SMDFlea
                                            Here`s a quick ME Firmware cleaning guide.
                                            The guide is basic,its main goal is to show you how to use intel FIT,its highly recommended that you all follow the guide posted at win-raid
                                            (The attached FIT version is 11, if your ME Firmware (FW) is not 11.0.*.* follow the win-raid guide. Use the tools version for your ME FW, for example: ME System Tools v9.1 For systems running ME v9.0 - v9.1)
                                            A video,software (intel FIT) and practice bios are all included. I`ll post a better video and more advanced guide at a later date.
                                            1. Open the...
                                            09-09-2020, 09:10 AM
                                          • EduCabral
                                            [Help Needed] Yatour YT-M06 (Pioneer 1) – Firmware or Schematic Request
                                            by EduCabral
                                            I'm currently working on reviving a Yatour YT-M06 CD Changer Emulator module for use with a Pioneer 1 interface (specifically with a DEH-P5950IB head unit).
                                            While the unit is recognized as a CD changer, none of the USB, SD, or AUX features respond, which leads me to believe the firmware may be corrupted or incompatible.
                                            🔧 Details:
                                            • Model: YT-M06
                                            • Interface: Pioneer 1
                                            • MCU: Fujitsu MB89F202
                                            • Goal: Find a valid .bin firmware file or memory dump from a working unit
                                            I'm happy to attempt flashing, analyzing memory dumps, or doing hardware-level...
                                            07-15-2025, 12:26 AM
                                          • ktmmotocross
                                            ps5 bv, schem or repair guide
                                            by ktmmotocross
                                            Have this PS5 EDM-033 with one beep. error is some short but i dont find one on main rails. need schem or guide to check all rails
                                            I would like to have BV, schem or repair guide so add them here
                                            07-02-2025, 11:57 PM
                                          • acedogblast
                                            by acedogblast
                                            11-02-2024, 05:13 PM
