pioneer help
  • subarufreek
    • Nov 2013
    • 53
    Re: pioneer help
    thanks for the info. ive talked to him about my problem and he didnt say anything about having some parts, guess i can just ask though.
    • philliesfan30m
      • Aug 2013
      • 542
      Re: pioneer help
      i thought i was right there too with the help from tom when i was trying to fix mine but thats all that happened was i got close to fixing it! i didn't want to put any money into it like replace boards etc. i just wanted to find the exact problem but never did. i don't think they even make tv's anymore thankfully. thats probably why cause they suck! not that other tv's don't suck too but they are easier to fix!
      • mmartell
        • Oct 2013
        • 3189
        Re: pioneer help
        When your sets came on grey screen then shut off did they both have solid red/blue lights or flashing codes until next attempt at power on ?
        • philliesfan30m
          • Aug 2013
          • 542
          Re: pioneer help
          he never said what model it was just that it was a pioneer....
          • philliesfan30m
            • Aug 2013
            • 542
            Re: pioneer help
            mine was solid both red and blue almost like i never reset it at all
            • subarufreek
              • Nov 2013
              • 53
              Re: pioneer help
              solid red/blue the whole time. ill plug it in and the red light on the main board isnt on the red/blue lights are on. ill enter the remote code the tv clicks turns grey, clicks again and turns black then the red light on the main board will stay on.
              • philliesfan30m
                • Aug 2013
                • 542
                Re: pioneer help
                yeah thats exactly what mine did
                • philliesfan30m
                  • Aug 2013
                  • 542
                  Re: pioneer help
                  it's like it wants to and tries to reset the error but it just keeps coming back
                  • subarufreek
                    • Nov 2013
                    • 53
                    Re: pioneer help
                    did you replace your PSU or did you just get it to try to fix it? the reason i ask is because i did replace mine and at first the blue light would blink 13 times so my dad and i checked the voltage like mmartell said but when i went to show my dad what it was doing i realized the the blue and red lights were staying on like they should but i never did anything to it between those times it was like 4 days or so
                    • mmartell
                      • Oct 2013
                      • 3189
                      Re: pioneer help
                      Are those voltages present on P8 right now ? They shouldn't be as they are switched on by the mainboard so that's something to follow up right there.
                      • philliesfan30m
                        • Aug 2013
                        • 542
                        Re: pioneer help
                        i never replaced the power supply
                        • subarufreek
                          • Nov 2013
                          • 53
                          Re: pioneer help
                          yea the connector labeled P8 the 4(i think) pins that should be 5.1v but are reading 3.4v. thats part of the output, correct? theres really only one input on the PSU. im sorry im not following what youre saying. P8 is connect to the mainboard
                          • newtothis
                            • Mar 2013
                            • 1556
                            • england
                            #93
                            Re: pioneer help
                            Basically the PSU should only have 1 voltage when powered off... 5v standby. As the main board is what sends the signal for the PSU to switch on there should be no voltage except that 1 unless the power button is pressed.
                            • subarufreek
                              • Nov 2013
                              • 53
                              Re: pioneer help
                              hmmm. i only measured with the power on..... im confused though, the ac cord leads to the trap swithch which in turns leads to the PSU then to everything else. so wouldnt everything coming out of the PSU besides the one blue and brown wire be output?
                              • philliesfan30m
                                • Aug 2013
                                • 542
                                Re: pioneer help
                                that mainboard looks exactly like mine even though mine is a 5070pu
                                • philliesfan30m
                                  • Aug 2013
                                  • 542
                                  Re: pioneer help
                                  i think the wires from the power button go to the mainboard
                                  • newtothis
                                    • Mar 2013
                                    • 1556
                                    • england
                                    #97
                                    Re: pioneer help
                                    Well kind off... for example the PS_ON pin would be an input.. Main sends >2.5v signal to PS_ON to switch it on.
                                    What mmartell is getting at is that when the set powers itself down all the voltages should drop off.... but they are not, So the set isn't actually powered down
                                    • newtothis
                                      • Mar 2013
                                      • 1556
                                      • england
                                      #98
                                      Re: pioneer help
                                      Has the main been disconnected and the PSU forced on at all guys?
                                      • subarufreek
                                        • Nov 2013
                                        • 53
                                        Re: pioneer help
                                        how would i go about doing that?
                                        • philliesfan30m
                                          • Aug 2013
                                          • 542
                                          Re: pioneer help
                                          jumper the ps-on with 5vstb
                                          • Bushcat
                                            Pioneer PL-X9 motor speed control wobble
                                            by Bushcat
                                            I'm starting to re-cap a Pioneer PL-X9 turntable, specifically the motor control board, because although everything tests out OK according to the service manual, the speed wavers slightly despite the quartz lock light remaining on. So, I've decided to re-cap that board since it's the cheapest next step...
                                            Pioneer's passive component naming convention is clear to me. For example, CSZA R22M 35 is tantalum, radial leads, 0.22uF, 20%, 35V.
                                            BUT there are two capacitors on the board which have actual Pioneer part numbers: PCL-042. I can tell they are 0.1uF, 16V but don't...
                                            05-24-2023, 03:36 AM
                                            ME Firmware Cleaning Guide
                                            by SMDFlea
                                            Here`s a quick ME Firmware cleaning guide.
                                            The guide is basic,its main goal is to show you how to use intel FIT,its highly recommended that you all follow the guide posted at win-raid
                                            (The attached FIT version is 11, if your ME Firmware (FW) is not 11.0.*.* follow the win-raid guide. Use the tools version for your ME FW, for example: ME System Tools v9.1 For systems running ME v9.0 - v9.1)
                                            A video,software (intel FIT) and practice bios are all included. I`ll post a better video and more advanced guide at a later date.
                                            1. Open the...
                                            09-09-2020, 09:10 AM
                                          • EduCabral
                                            [Help Needed] Yatour YT-M06 (Pioneer 1) – Firmware or Schematic Request
                                            by EduCabral
                                            I'm currently working on reviving a Yatour YT-M06 CD Changer Emulator module for use with a Pioneer 1 interface (specifically with a DEH-P5950IB head unit).
                                            While the unit is recognized as a CD changer, none of the USB, SD, or AUX features respond, which leads me to believe the firmware may be corrupted or incompatible.
                                            🔧 Details:
                                            • Model: YT-M06
                                            • Interface: Pioneer 1
                                            • MCU: Fujitsu MB89F202
                                            • Goal: Find a valid .bin firmware file or memory dump from a working unit
                                            I'm happy to attempt flashing, analyzing memory dumps, or doing hardware-level...
                                            07-15-2025, 12:26 AM
                                          • ktmmotocross
                                            ps5 bv, schem or repair guide
                                            by ktmmotocross
                                            Have this PS5 EDM-033 with one beep. error is some short but i dont find one on main rails. need schem or guide to check all rails
                                            I would like to have BV, schem or repair guide so add them here
                                            07-02-2025, 11:57 PM
                                          • acedogblast
                                            by acedogblast
                                            11-02-2024, 05:13 PM
