Vizio LCD.. Worth bothering with it ?
  • Nitro468
    • Oct 2013
    • 65
    Freebie on Craigslist, I think it is probably toast, but what does semi-transparent mean in this case? Here is the description...
    I have a 46" Vizio tv that's all yours. The catch is that it has a semi-transparent one inch black band across the screen. It's not too bad and we used the tv for months with this issue. It doesn't obscure anything it's just makes everything a little dimmer in that part of the screen.
    Bad panel ? or is it worth playing with ?
  • mmartell
    • Oct 2013
    • 3189
    Re: Vizio LCD.. Worth bothering with it ?
    Tab bond. Worth a shot if you want to tear it down.
    Post a pic of the anomaly.
    • newtothis
      • Mar 2013
      • 1556
      • england
      Hey for free... get it!
      Have a play and if it fails use the boards as parts
      • Nitro468
        • Oct 2013
        • 65
        Send owner an email, post was still there.
        See what happens.
        Thank you for the advice.
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • Cartel
          FORD 1996 ECU RECAP: Aluminum - Polymer worth bothering?
          by Cartel
          I will be pulling my crown vic ECU and recapping it. 3 in total, 47uf 16v x2 and a 10uf 63v
          I hope they havent puked yet. I was thinking of replacing them with Aluminum - Polymer thru hole caps. probably 47uf 25v and 10uf 80v
          They arent cheap. Anyone have any experience with them? Am I wasing my money on premium caps?
          Nichicon PLV series
          thanks
          06-01-2025, 04:58 AM
        • SS454
          vizio e650i-a2 backlight flashes then turns off
          by SS454
          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
          panel: au optronics T650HVN05.4
          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
          https://www.shopjimmy.com/vizio-56-0...-power-supply/
          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
          08-20-2020, 03:57 PM
        • mrtek
          Vizio M65-C1
          by mrtek
          Hi.
          picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
          When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
          This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
          07-14-2025, 07:28 PM
        • JDC
          Vizio D50u-D1 - Worth repairing?
          by JDC
          I'm pretty sure I know the answer but here goes: got a Vizio D50u-D1. I know the main board is bad. I can replace it with a used one for $50 or have it rebuilt for a few dollars more. I just wonder if it's worth it? Just seems to me that another board is going to eventually bake itself to death or the LEDs are going to burn out.
          I'm thinking no. What do you think?
          11-23-2021, 05:48 PM
