Vizio D50u-D1 - Worth repairing?
  • JDC
    • May 2015
    • 273
    I'm pretty sure I know the answer but here goes: got a Vizio D50u-D1. I know the main board is bad. I can replace it with a used one for $50 or have it rebuilt for a few dollars more. I just wonder if it's worth it? Just seems to me that another board is going to eventually bake itself to death or the LEDs are going to burn out.
    I'm thinking no. What do you think?
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Vizio D50u-D1 - Worth repairing?
    Go buy another TV. Maybe you can offer it on craigslist for someone interested in repairing them.
    • JDC
      • May 2015
      • 273
      Everything is leaning towards scrapping it instead of repairing it. I don't need to repair it. Blah. I just hated throwing away stuff that can be fixed but what's the point if it's just going to die a natural death in a couple years.
      • alfatv
        • Sep 2020
        • 353
        I see one for 40$, pretty good price and worth fixing
        • CityZen
          • May 2014
          • 40
          If you would enjoy the experience of trying to repair it, I'd say go for it. I've recently been watching lots of NorthridgeFix repair videos on YouTube, and it's inspired me to take on some projects. I've already fixed a non-working GTX 1070 GPU just by fixing a broken 0-ohm resistor.
          • dskall
            • Oct 2016
            • 2905
            • usa
            Sounds like he is trying to talk himself out of repairing it.
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • SS454
              vizio e650i-a2 backlight flashes then turns off
              by SS454
              vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
              panel: au optronics T650HVN05.4
              72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
              link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
              Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
              https://www.shopjimmy.com/vizio-56-0...-power-supply/
              Vizio 55.75J01.001G (91.75J10.004G) Main Board...
              08-20-2020, 03:57 PM
            • mrtek
              Vizio M65-C1
              by mrtek
              Hi.
              picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
              When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
              This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
              07-14-2025, 07:28 PM
            • howardc64
              Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
              by howardc64
              Failure Symptom
              No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
              Where is the short?
              Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
              Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
              05-27-2025, 02:56 PM
            • ossroy
              Vizio M60-C3 multiple symptoms leading to death
              by ossroy
              Initially, I had an issue last winter where, when the room was cold, the TV came on but continuosly scrolled through the inputs. Slapping the back of the lower left where the KB board and light are would solve things until the room warmed up and things worked fine.
              Then recently it started coming "on" but no picture, just backlight. Turning it off and on again fixed things. Then it got worse, where I'd have to cycle power several times to get picture. Then I got the dimming light and sometimes flashing after dimming. Again, cycle power a few times and it would eventually...
              05-16-2022, 12:44 PM
