LG DU-37LZ30 LCD TV Shuts off after an hour
  • 120volts
    • Oct 2013
    • 57
    No sings of bad caps
    Heat sinks get pretty hot on the power supply
    A couple of the caps get warm
    Any help is greatly appreciated.
    Dan "TV Tinkerer"
    Re: LG DU-37LZ30 LCD TV Shuts off after an hour
    Warm stuff up with a hairdryer slowly. If it shuts off quicker when warming an area you have found the fault.
    • 120volts
      • Oct 2013
      • 57
      Sounds like a good idea
      Dan "TV Tinkerer"
      • 120volts
        • Oct 2013
        • 57
        OK I usually hate to modify Stuff to get working "BUT"
        This TV was shutting after an hour and I found that the power supply heat sinks were just about to hot to touch.
        I ended up putting two computer fans in parallel to equal 24V and connected them to the back-light supply.
        Now the power supply runs quite cool and the TV doesn't shut down
        Dan "TV Tinkerer"
        • ben7
          Capaholic
          • Jan 2011
          • 4059
          Interesting. I wonder if this is a design defect?!
          Muh-soggy-knee
          • truep
            • Aug 2010
            • 373
            Leaking caps can cause overheating. I would change all of those above the top heat sink. Use Panasonic fm, or FC 105C caps from digikey. If for no other reason than to be safe.
              Adding fans is just likely to prolong the time till failure, it will probably stop working eventually.
              • vinceroger69
                • Mar 2012
                • 6714
                • uk
                in post 4 the yellow transformer to the right at the top the capacitor behind that looks like its been subject to heat and the outer plastic cover of the capacitor has shrunk those capacitors maybe your issue post 1 is a shopjimmy image edit truep beat me to it lol
                • 102mm
                  • Dec 2013
                  • 181
                  • us
                  I have this same model. The standby voltage is pulsating between 2 and 4 four volts on the power supply. Matter fact, any voltage I measure pulsates on the power supply. Anyone have a clue?
                  Craigslist Picks & Fixes
                  2 ea - Samsung 52"
                  Samsung 60"
                    Bad start up cap in the STBY power supply? Too much load being drawn from the power supply?
                    How board good clear pictures of YOUR board?
                    • saddle_au
                      Waste Warrior
                      • 121
                      The caps above the transformer on the right (in upper middle of image ) don't look healthy.
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        • uk
                        thats not his picture thats the original poster this user only joined the thread in post nine.
                        • huzo
                          HP Omen shuts down when loading OS
                          by huzo
                          The model is 15ec-1061nm
                          Board number is DAG3EDMB8D0​
                          SO i turn the laptop on , and as soon as it starts booting from disk, from usb, windows,linux,HBCD,anything i boot it just turns off....while in bios menu or in linux boot menu it stays on normally...It's like when it starts to use graphics it shuts down...But i measured 0.72V while working on the GPU power line,no excess heat is comming from GPU or CPU, i even removed the heatsink and turned the laptop on and everything worked fine, got a bit hot, fan span to full speed, but it worked like that for few minutes in bios...
                          10-29-2024, 12:05 AM
                        • baglaivlad
                          A1706 820-00239 - Works, but sometimes shuts off when the charger is disconnected
                          by baglaivlad
                          Hello everybody!
                          Have in work A1706 820-00239 model. Originally no power, shorted PPBUS_G3H because of corroded C6403, C6404. Some water damage around this components, but nothing major.
                          After replacing this capacitors the laptop came back to work, I reinstalled MacOS and had no issues until I started to test Type-C ports. Sometimes the laptop shuts off immediately when some action with Type-C ports performed (charger disconnected or USB device inserted/disconnected). I checked Type-C port flexes, they are okay, but I cleaned them anyway. I can't see any signs of liquid...
                          11-20-2024, 08:14 AM
                        • samuelphirik
                          Dell inspiron 15 7567 sudden shuts down
                          by samuelphirik
                          Hi. I have a pre-owned Dell Inspiron 15 7567. It worked fine
                          During the first 3 days of owning it until Dell Update software popped a notification about a latest Bios version 1.15.0 and latest Intel ME Software update of which I updated. It rebooted and firstly, Upgraded Bios from version 1.8.1 to 1.15.0 then it started upgrading Intel ME firmware. After that update, my laptop shuts down without notice (Like thermal shutdown)
                          I checked Thermal Paste on the processor and the Graphics Chip and it was dry. Replacing thermal paste has not helped me.
                          Now I've noticed that laptop...
                          07-02-2023, 05:45 AM
                        • nickgronk
                          Hisense 55H6570F boots, loads then shuts down -
                          by nickgronk
                          I have a Hisense 55H6570F that gets the the boot loading screen for android and then shuts down. Oddly I hear a crackle on the mainboard as shown in the picture - nothing looks blown. The tv will boot every time, but when it reaches the loading statge of the anroid logo you can hear crackling on the board and it shuts down. What am I looking for (other than buying a new set) ? Inside the square is where I hear the crackling
                          08-05-2024, 11:02 AM
                        • zx81
                          Sony LMD-2110W LCD monitor shuts down when warm
                          by zx81
                          I would very much appreciate any help or guidance with attempting to repair this Sony LMD-2110W LCD broadcast monitor.
                          It shuts down when warm after running around 20min or so. I can only get it to turn back on by physically removing the power cable for around 1 minute. It will then run for around 10min and powers down again.
                          Sometimes on a cold start, I can see a little flicker in the backlight in the bottom quarter of the screen.
                          If required I can remove individual boards to take pictures of the back of each board.
                          pics attached....
                          08-13-2019, 10:51 AM
