A1706 820-00239 - Works, but sometimes shuts off when the charger is disconnected
  • baglaivlad
    • Sep 2022
    • 28
    • Ukraine
    Hello everybody!
    Have in work A1706 820-00239 model. Originally no power, shorted PPBUS_G3H because of corroded C6403, C6404. Some water damage around this components, but nothing major.
    After replacing this capacitors the laptop came back to work, I reinstalled MacOS and had no issues until I started to test Type-C ports. Sometimes the laptop shuts off immediately when some action with Type-C ports performed (charger disconnected or USB device inserted/disconnected). I checked Type-C port flexes, they are okay, but I cleaned them anyway. I can't see any signs of liquid damage or corrosion near CD3215s (these have underfill on this board, so no corrosion underneath).
    As it is intermittent issue (like the laptop shuts off in 1 of 10-20 times), I don't know where to look at. Do you have any suggestions?
  • motormayhem
    Lenovo T460 Only Charges on One Charger
    by motormayhem
    Laptop Question
    I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
    A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
    05-12-2023, 01:46 PM
  • Weelcup
    Dell XPS 9560, shuts down when charger connected.
    by Weelcup
    Hi Friends
    So i have today a XPS9560 laptop with LA-E331P motherboard i7 CPU.
    There were some corrosion around the charging chip BQ777. I cleaned the corroded component with ultrasonic. And then tested all the components within the corroded area. Replaced 2 resistors as they had wrong readings and then the laprop powered on. The original laptop battery were shorted and the battery fuse were blowen (inside battery circuit) so i replaced the battery as well.
    Now the batttery is charging normally. But the only wiered issue i am facing is that when the charger is connected...
    03-11-2021, 09:42 AM
    NVDC charger configuration...
    11-05-2024, 03:28 PM
  • flat-earther
    how to prevent a connected charger from draining battery when not charging?
    by flat-earther
    I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
    So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
    but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
    So the battery is backfeeding the charger and being drained.
    How can I prevent...
    08-07-2025, 01:04 PM
  • flat-earther
    ASUS X54H laptop thinks it's always charging even with charger unplugged
    by flat-earther
    The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
    Windows also shows ''Plugged in'' when charger is not connected.
    This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
    Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
    If I let battery run out and say it has 3% Windows will...
    06-24-2025, 09:32 AM
