Hi folks, I have this 32 inch bush lcd tv and it powers on and shows picture fine and also has sound but after about 5 seconds it switches itself off follwoed by the standby light flashing red which is usually blue, Could someone please tell me where i should start to troubleshoot the problem, Thanks.. :-)
Bush LCD32TV016HD Red Flashing Light
Re: Bush LCD32TV016HD Red Flashing Light
Check the caps on the power supply. Very common fault.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
Thanks tom, This is actually the second time i've worked on this model, Last time i noticed some bulged caps on the power board then once i replaced them the set fired up straight away and has worked fine ever since, This one however shows no signs of bad caps, I tested all of them and replaced any showing less than 10% of the stated values then powered it up and still i get the red light after a few seconds, Might also be worth mentioning that a high pitched buzzing sound can be heard which seems to be coming from the power board and it changes tone in time to the flashing, There is 10 caps on the main board, could any of these be faulty or is it normally just power board caps which fail.??Comment
Is there a flashing red light on the power board too, or does it stay solid? (Or maybe on this one there is no light.)
Also, post some pictures of the boards. I have done 26", 32" and 37" of this, each once, and all had bad caps with varying symptoms, but I can't recall what the board looked like. I've found no other issues myself other than the crummy caps, so it makes for an easy fix.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Also, post some pictures of the boards. I have done 26", 32" and 37" of this, each once, and all had bad caps with varying symptoms, but I can't recall what the board looked like. I've found no other issues myself other than the crummy caps, so it makes for an easy fix.Comment
OK, check the various voltages on the power board. Verify they correspond to the rated voltages as labelled, try to get before and after fault.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
All voltages seem to be normal during the first 5 seconds then once the red light starts to flash all voltages disappear apart from the 5vstb which is on ok..??Comment
Is there a PS ON pin? If not, can you list the connections going to the main board?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
STB's the pin. Check STB when it turns off.
If STB changes state (low-high or high-low) you know the main board is causing it.
In which case I would investigate the power buttons etc and check none are stuck down or intermittent/contaminated -- isolating the button board would be a simple test.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
That means the main board is shutting off, for one reason or another. Recommend checking the buttons as mentioned above.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Romoved the pannel to get the buttons out and there is no signs of any corrosion or damage to the buttons, Left them still connected then powered on the tv up and pressen the power button to switch it on then quickly removed them, The tv stayed on for a few seconds like normal then shut off followed by the red light...Comment
I'm guessing the main board has a fault then, likely corrupted eeprom.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
You can check voltage regulators but most likely you will be looking at a replacement.
https://www.badcaps.net/forum/showthread.php?t=22231Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
I would not expect those to cause this fault.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Easky15 could you do me a favour? Any idea what the thread and length of the fixing bolts on the BUSH LCD32TV016HD are that secure the set to the pillars on the oval tabletop stand? I've taken my TV off a wall where it has been for a few years and I found the old stand but minus the boltsComment
by learnmoreHello Community!
CASE DETAILS
Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
Tried inserting firmware on USB and left it in for a few hours, but no change
by CraigRWorking on a hp x360 15-eb1043dx that will not turn on and the power light just flashes. It pulls 700ma when flashing. Under the thermocam I found a component I am unable to id that light up. If someone can help would be appreciated. I put the number that are on it in better test....
by stephonwhyteun65tu7000fxza - I am experiencing the flashing red light on the power led. So I purchased the replacement kit for the mainboard and power supply. I still experienced the flash red power light. So I purchased a new ribbon cable, The flashing light stopped for a minute, I could hear sounds on the TV but no picture. I did the 60 second reset and it went back to flashing. What could possibly be the issue now? All the LEDs are lit up from what I can see.
Thanks for all responses. -
by Kambi13Hello all need some help, I've got a Deskjet 3720 that turns on but everything is flashing, power light and everything on the lcd also is flashing. There's no paper jams or anything like that, printer is clean inside12-02-2023, 05:26 AM
by GRANDGGHi i have an issue with LG 42lw4500 wich after pressing the power button flashes red then goes solid white light 2 clicks and nothing , the weird thing is SOMETIMES if i leave the tv plugged in it would come on and fuction normally (i should mention that vertical rectangle going from the bottom to the top of the screen have some red dot artafacts it only appear in somthing like the tv input menu and any input i give like vga , but not in the system menu , i thought i should mention this , i cannot confirme if the tv had this issue when it was up and running in its previous owner . ) when checking...
- Loading...
