Vizio VO370M LCD Orange Light Only
  • BradBerger
    • Oct 2013
    • 32
    Hey everyone, new to the forum and having an issue with my Vizio TV.
    It's a 42" VO370M model and was given to me by a friend that did not want to fix it. The orange Vizio light would come on, but nothing happened when pressing the power button.
    I let it sit for a few months without touching it and decided one day to mess around with it. Miraculously, it powered on perfectly and I've been using it without issue for about a month or two. Well, my luck ran out last night when I went to turn it on and the original problem came back, orange standby light only.
    Currently, I have the back taken off and have checked all connections without any success. I have a multimeter handy so I can check what I need. This seems like a common problem with Vizios so hopefully someone can lend some advice!
    Thanks again everyone!
  • Glitcher
    • Mar 2013
    • 673
    • USa
    Re: Vizio VO370M LCD Orange Light Only
    I would check the voltage regulators on the main board.
    • BradBerger
      • Oct 2013
      • 32
      I should mention I am in no way an electronics expert so I may need a bit of an explanation of certain things.
        Yes, check the regulator's voltages, also check the fuses on the main board for < 1 Ohm and the voltage readings on both ends of the fuses with ref. to the chassis ground.
        http://s807.photobucket.com/user/bud...?sort=3&page=1
        Also check the voltage on the output pins of the power supply connectors.
        • BradBerger
          • Oct 2013
          • 32
          Thanks for the quick responses. Here's what I have gathered so far...
          U2
          1117
          pin 1 = 2.038V
          pin 2 = 3.283V
          pin 3 = 5.01V
          U4
          1117
          pin 1 = 2.054V
          pin 2 = 3.302V
          pin 3 = 5.05V
          U5
          1117
          pin 1 = 1.380V
          pin 2 = 2.631V
          pin 3 = 5.02V
          U7
          L391
          G1084
          pin 1 = 2.031V
          pin 2 = 3.263V
          pin 3 = 5.04V
          U8
          1117
          pin 1 = 0.9mV
          pin 2 = 1.248V
          pin 3 = 3.254V
          U11
          7805CT
          RAD947 G
          pin 1 = 58mV
          pin 2 = 0.7mV
          pin 3 = 0.7mV
          U9
          1117
          pin 1 = 1.252V
          pin 2 = 2.488V
          pin 3 = 5.04V
          F1 read 0 Ohms but 102 Ohms when I switched the test leads.
          F2 read 0 Ohms either way.
          F1 voltage 5.04V on both ends
          F2 voltage 59.6mV on both ends
          Voltage output from power supply on 12V pins all 60.6mV
          Voltage output from power supply on ST/+5V pins all 5.04V
          Hope this helps!
            OK, the 12v will not be at the fuse until the main board sends the PS_ON signal to turn on the power supply board, so the U11 will not be putting out 5V since there is no 12v feeding it.
            Otherwise all other regulators are putting out correct voltages (voltage between pin1 and pin 2 should always be 1.25v +/-2%).
            So at this point, the main board is not sending out the PS_ON or the power supply is bad, you need to check the voltage at the ps_on pin on the power supply board to verify.
            • BradBerger
              • Oct 2013
              • 32
              The voltage at the On/Off pin on the power supply is 5.8mV
              So is that a sign that the power supply is bad?
                I need to see your board, I believe that ON/OFF pin is for the Backlights ON/OFF, there should be a pin with PS_ON (or STBY) on the power supply board. The main board is the one that generates all those signals and sends then to the power supply board.
                • BradBerger
                  • Oct 2013
                  • 32
                  Snapped a pic for you....I went ahead and tested INV_ON just in case that was it and it came to 13.7mV
                    Well, the main board is not sending the Inverter on signal or the power supply on signal, so the main board is the problem.
                    • BradBerger
                      • Oct 2013
                      • 32
                      I dont need to be pressing the Power button as I'm testing these do I?
                      Which pin do you think the PS_ON is, or is it even worth testing it?
                      If the main board is the problem, would it be easier to just replace it or try to locate the issue?
                        You do need to hit the power button so the main board will send out the signals to the power supply board, I thought that is what you have done.
                        ON/OFF is the PS_ON.
                        • BradBerger
                          • Oct 2013
                          • 32
                          Sorry about that, like I said not exactly an expert.
                          Anyway, went back and tested PS_ON and INV_ON again pressing the power button with no difference at all.
                            OK, that confirm the main board is not working properly. The main board for this model is not cheap, I fixed the one in my pictures by using the main board from the VL370M, the bad main board that I have has problem with the main micro controller, it runs real hot in a few minutes and blow the fuse for the 5V.
                            • BradBerger
                              • Oct 2013
                              • 32
                              So is there anything I can do to avoid replacing the entire board?
                                I did not have any luck locating the problem, most Vizio main board failed due to bad regulator, but yours are OK. The price of the main board should come down when the holiday season ended, I would not spend more than $50 on the main board, also prepare for the power supply-inverter board to fail in the future.
                                • BradBerger
                                  • Oct 2013
                                  • 32
                                  Darn, looks like that's my only option. Thanks so much for your great help and information!
                                  • BradBerger
                                    • Oct 2013
                                    • 32
                                    Bit of an update here.
                                    I ordered a replacement main board and just installed it with no luck. Only this time, the white Vizio light comes on as well as the backlight. Then it sits there. No Input screen or anything, just backlight. I have a question about the part numbers on these boards. The original board in the TV was labeled 3637-0502-0150(0H) while the board I received has the part number 3637-0502-0150(0I). Does this different designation in the parentheses make all the difference? Or is something else causing the problem now?
                                      Just to be sure, re-seat the ribbon cable between the main board and the T-CON, if still no pictures then you need to check the DC voltage on the fuse in the T-CON board.
                                      • BradBerger
                                        • Oct 2013
                                        • 32
                                        No voltage at all at the fuse on the T-CON board. I checked it with both main boards just in case. Nothing. What should I be looking for next?
