Wharfdale 37LCD1080P faulty
  • Davelee1097
    • 19
    • Uk
    Hello everybody!
    I'm wondering if I could have some assistance please?
    I have acquired a faulty wharfdale LCD TV that wouldn't turn on from standby, I have replaced all the capacitors on the psu and it now turns on, it still doesn't work however. The colours are very distorted and doesn't display an image correctly.
    Here is the video:
    http://youtu.be/siTRGCStKZY
    From what I've read, I think it could be a problem with an IC on the TCon, could that be correct?
    I have stripped it down and removed the TCon board, part number T370HW02 V0 06A22-1B.
    I put the TCon board back in loosely and tried to test the voltages on the IC but nothing is displaying on screen and I can't change the sources or enter the on screen menu. I'm not entirely sure what I've done.
    Any advice on the matter would be greatly appreciated.
    Sorry if my post doesn't make much sense, I'm posting on my phone.
    Dave
  • Davelee1097
    • 19
    • Uk
    Re: Wharfdale 37LCD1080P faulty
    I forgot to add, the IC in question is an AS15-F, I will post some close up pictures of the various boards when I'm back at the workshop later.
    • mmartell
      • Oct 2013
      • 3189
      Did you put the screws through the tcon so it's grounded ?
      • Davelee1097
        • 19
        • Uk
        Umm........no!
        I shall do that later and see if I'm back to where I was. Any ideas on if the IC on the tcon is at fault?
          AS15-F would not cause this issue.
          If this is a VESTEL set, I would press MENU 4725 to access service menu then select RESET.
          • Davelee1097
            • 19
            • Uk
            Thanks for the reply Tom!
            Wow, I didn't realise it could be something as simple as that! I don't actually have the remote for it, but I do have a harmony remote, could that work to access the service menu?
            Could it be a coincidence that the tv had bulging caps and this issue or would it be related somehow?
            Thanks again
            Dave
              You can use a remote for a Philips set (same codes for European TV) or if you can get the MENU button and numbers to work on a Harmony remote that will work OK too.
              • Davelee1097
                • 19
                • Uk
                Thanks again for your help Tom, I'll get the TV put back together shortly and try the service menu in the morning.
                I see in your signature that you've repaired quite a lot of TVs, have you ever come across anything similar to what I'm dealing with?
                Cheers
                Dave
                  Never myself but I've done tons of Vestel sets and they are unworthy piles of rubbish so it wouldn't surprise me to see another one go bad!
                  • Davelee1097
                    • 19
                    • Uk
                    Well, I put the TV back together and the problem of nothing on the screen and unable to change sources/menu etc still persists.
                    I'm not sure what's happened now, I seem to have made it worse. It does have some grey/black banding on the right of the panel with a black background. Any ideas?
                    • Davelee1097
                      • 19
                      • Uk
                      Bad news! I've opened up the tv again and had a look at the connections to the tcon, I've torn one of the ribbon cables from the screen to the tcon, it looks like 3 traces are affected. Anything I can do, or is it destined for the skip now?
                        You need to find a replacement cable; the only thing you can do about that will be to ask someone who's scrapped one of these models for parts to see if they've got one of the cables.
                        • mmartell
                          • Oct 2013
                          • 3189
                          Does that cable terminate with the same type of socket on the other end ?
                          And wouldn't you still get half an image with one good cable coming from the T-Con ?
                            Depends on the design, usually though yes half an image would be expected, other half may be blank, distorted or faded.
                            • netgearnetgear
                              TCL 43S423 TCON OR PANEL FAULTY???
                              by netgearnetgear
                              Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
                              08-20-2025, 06:04 PM
                            • x_orange90_x
                              TCL 50S535 bad tcon or panel issue?
                              by x_orange90_x
                              Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                              03-29-2025, 11:02 PM
                            • advant
                              by advant
                              02-03-2020, 12:25 AM
                            • Hakuu
                              by Hakuu
                              Hi There,
                              More Details
                              TV Model - LG OLED77G1PUA
                              07-12-2023, 02:37 PM
                            • kca
                              by kca
                              Hello all ~
                              08-31-2025, 06:38 AM
