Wharfdale 37LCD1080P faulty
  • Davelee1097
    • Jun 2012
    • 19
    • Uk
    Hello everybody!
    I'm wondering if I could have some assistance please?
    I have acquired a faulty wharfdale LCD TV that wouldn't turn on from standby, I have replaced all the capacitors on the psu and it now turns on, it still doesn't work however. The colours are very distorted and doesn't display an image correctly.
    Here is the video:
    http://youtu.be/siTRGCStKZY
    From what I've read, I think it could be a problem with an IC on the TCon, could that be correct?
    I have stripped it down and removed the TCon board, part number T370HW02 V0 06A22-1B.
    I put the TCon board back in loosely and tried to test the voltages on the IC but nothing is displaying on screen and I can't change the sources or enter the on screen menu. I'm not entirely sure what I've done.
    Any advice on the matter would be greatly appreciated.
    Sorry if my post doesn't make much sense, I'm posting on my phone.
    Dave
  • Davelee1097
    • Jun 2012
    • 19
    • Uk
    Re: Wharfdale 37LCD1080P faulty
    I forgot to add, the IC in question is an AS15-F, I will post some close up pictures of the various boards when I'm back at the workshop later.
    • mmartell
      • Oct 2013
      • 3189
      Did you put the screws through the tcon so it's grounded ?
      • Davelee1097
        • Jun 2012
        • 19
        • Uk
        Umm........no!
        I shall do that later and see if I'm back to where I was. Any ideas on if the IC on the tcon is at fault?
          AS15-F would not cause this issue.
          If this is a VESTEL set, I would press MENU 4725 to access service menu then select RESET.
          • Davelee1097
            • Jun 2012
            • 19
            • Uk
            Thanks for the reply Tom!
            Wow, I didn't realise it could be something as simple as that! I don't actually have the remote for it, but I do have a harmony remote, could that work to access the service menu?
            Could it be a coincidence that the tv had bulging caps and this issue or would it be related somehow?
            Thanks again
            Dave
              You can use a remote for a Philips set (same codes for European TV) or if you can get the MENU button and numbers to work on a Harmony remote that will work OK too.
              • Davelee1097
                • Jun 2012
                • 19
                • Uk
                Thanks again for your help Tom, I'll get the TV put back together shortly and try the service menu in the morning.
                I see in your signature that you've repaired quite a lot of TVs, have you ever come across anything similar to what I'm dealing with?
                Cheers
                Dave
                  Never myself but I've done tons of Vestel sets and they are unworthy piles of rubbish so it wouldn't surprise me to see another one go bad!
                  • Davelee1097
                    • Jun 2012
                    • 19
                    • Uk
                    Well, I put the TV back together and the problem of nothing on the screen and unable to change sources/menu etc still persists.
                    I'm not sure what's happened now, I seem to have made it worse. It does have some grey/black banding on the right of the panel with a black background. Any ideas?
                    • Davelee1097
                      • Jun 2012
                      • 19
                      • Uk
                      Bad news! I've opened up the tv again and had a look at the connections to the tcon, I've torn one of the ribbon cables from the screen to the tcon, it looks like 3 traces are affected. Anything I can do, or is it destined for the skip now?
                        You need to find a replacement cable; the only thing you can do about that will be to ask someone who's scrapped one of these models for parts to see if they've got one of the cables.
                        • mmartell
                          • Oct 2013
                          • 3189
                          Does that cable terminate with the same type of socket on the other end ?
                          And wouldn't you still get half an image with one good cable coming from the T-Con ?
                            Depends on the design, usually though yes half an image would be expected, other half may be blank, distorted or faded.
                            • x_orange90_x
                              TCL 50S535 bad tcon or panel issue?
                              by x_orange90_x
                              Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                              03-29-2025, 11:02 PM
                            • advant
                              by advant
                              02-03-2020, 12:25 AM
                            • Hakuu
                              by Hakuu
                              Hi There,
                              More Details
                              TV Model - LG OLED77G1PUA
                              07-12-2023, 02:37 PM
                            • Daren87
                              Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help NeededπŸ™
                              by Daren87
                              I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                              08-13-2023, 03:25 PM
                            • alltvrepairs
                              Lg TCon test pins for screen test
                              by alltvrepairs
                              i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
                              Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
                              Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
                              Appreciate your help....
                              06-13-2025, 06:33 AM
