panasonic TC-P50U50 8 blinks
Re: panasonic TC-P50U50 8 blinks
On the SS board, Q051 was shorted. ( DG302 )
D041 & IC152 checked good after shorted part removed.
Possible cause = bad ground(s). Scrape ground clean with
razor or dremel tool top & bottom of board. Snug mounting
screws tight. Board # TNPA5623AB
( my repair this morning )Comment
Replace D041 and Q051 at the same time for prevent.
The resistor and IC usually check good and do not need replacement.
Individual parts can be bought on line.Comment
Trying to resurrect the euro tx version of these and have switched out for new the 2 common failed components. The set fired up 1st time and i then set about adressing the poor cooling and sourced a super silent 80mm 5v fan that i intended to run from the usb 5v line. However today i have just tried the set and its 8 blinking again grrr. Total run time of the set since the repair is less than 30 minutes and that was broken by 3 power cycles just to check my work.
Ive not pulled the board again as of yet and im leaving it to discharge itself so i dont know if the new components have crapped out but i wondering if im chasing a red herring and the panel may be bad.?
When it did fire up the picture was superb and bright with no odd discoloration anywhere. Unfortunately i didnt get as far as the service menu to check the screen hours because i was more concearned about the rubbish cooling and obvious hotspot in the top right (from the backside) corner.
The set "seems" in superb condition exteriorlly, even the 3 sets of glasses are unscratched and well cared for. I dont "think" its had an excessive amount of use but i may be wrong. However given its age i dont want to throw money at it by buying ss boards to substitute if they are going to get fried by a bad panel. Id like to repair this one and use it for a while just to play with the 3d side at length before i commit to buying a replacement for my old sammy dumb plasma which has served us well despite a recap 3 years ago.
These pana plasmas seem to pull up a lot of googlies when looking for issues, am i flogging a dead horse?Comment
Have you or someone else done this patch mod? Im curious that its this tiny trace that is causing the POST to report an error and tripping the 8 blink warning. Screw tightened up on installation, Set warms up and the backplate expands, screws loosen a touch and the backplate oxidizes a little until poof! Would a ground strap tied to one of the spare mounting lugs be an idea and soldered to the ground of the board direct istead of it being shared with a load baring screw?The guy with the repaired TV called me back and said there is noise coming from the TV. So I opened it up and yes, the solder pads from the screws where black again, so there was sparking.
The two solder pads for the two screws right next to the parts that blow up are already connected via a tiny trace on the board. That means the trace's inductance causes a voltage drop on it. When we tighten the screws the two solder pads are connected via the lower impedance path of the chassis.
Clearly a design failure.
I used dented washers now which should assure a good contact from solder pad to chassis/screw.
When it starts again I think a good way to really solve this is to connect those two solder pads with a thick wire onboard.Comment
I've repaired a few Panasonic plasmas (2010-2012) models and the SC and SS boards often have loose screws with discolouration to the solder on the pads under them, both top and bottom as well as evidence of arcing to the chassis.
2013 models don't have any solder on the pads, just bare copper and use screws with both flat and split washers so they don't come undone. After repairing boards, I remove the solder from around all the fixing holes using wick and fit new screws with flat and split washers.
I would do this to both SC and SS boards in yours and check the components you replaced as it sounds like the panel is ok to me.Comment
That sounds like a good course f action to me. Im waiting on a pack of 5.6ohm resisors to arrive in the next few days so this is something to be getting on with. Ill wick off all the solder thats heaped up around the bit of braid thats been stuck on on by the last repairer too then fix the trace under it which was probably arced through.
Got the launettes out and had a good close up view today.. R501 definitely looks brown compared with its twin further down the board so more than likely its out of spec and for what they cost i may as well change it.
Out of interest what is the current equivalent or better for the associated ic? Im posting on my phone atm and dont have access to the pc with the service manual and pana tec advisory. Ive not seen many mentions of it going down but be handy to know what to check out.
Many thanks for replyingComment
Hadn't seen these posted here so thought id add them.Attached Filesif you find these attachements useful please consider making a small donation to the site
R501 was dead, its back to life after the fix. I guess it was on its way out and my previous fix finished the job. Swapped all the screws for spring and flat washered machine screws scavanged from old network swithches, after wicking off all the solder around the holes and getting rid of the braid patch.
Im now looking for a 5v whisper quiet fan to vent the heat but mounting and vibration must be a concideration given that it will be attached to the back panel, any suggestions?Comment
I tried fitting a couple of used OE Panasonic fans from a GT30 model into a U20 that didn't have any at all. I did as you are thinking, mounting them on the rear panel vents, using a rubber gasket to try and damp any vibration.
In the end I removed them as even with several attempts at lower drive voltage, they still made too much noise. I think this is why they are fitted to the metal back of the screen itself rather than the back panel.
I've sold that TV now but if I were trying to do this again I would try and fit them as Panasonic do and put them close to the vents on the main chassis.Last edited by andyb1712; 11-06-2019, 02:57 PM.Comment
Assuming...7 Photos -
by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
After all of... -
by canadaboy25I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was... -
by BiruslapioHello, I've had this TV for 3 years, 2 years ago it stopped working signaling 12 Blinks, SOUND_SOS according to the service manual.
It has no VSUS or VDAT, and P15V has 1.0V instead, the same 15V goes to A board. F15V is ok and other main voltage rails.
It seems the power supply is defective, since unplugging D20 ribbon cable that goes from D-board to SC-board makes the behavior change, the TV stays on, there's no image nor VSUS, but 15V reads 2.4V, high enough to not trip the SOS 12 blinks, so it stays on, fans do not spin but I left it 2 hours, green led lit up... -
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
- Loading...
