Hyundai HLT-2001B schematics
  • Learn2Day
    • Jun 2013
    • 254
    • Portugal
    Re: Hyundai HLT-2001B schematics
    I've found an AO4606, but I've bought only one. Wasn't cheap either.. 2.60€ for one!
    Dumb question from this noob.. Why should I replace all 4 if only one is busted?
    Replacing the capacitors is affordable, but i see no point in spending 10€ in mosfets if one solves the problem.. I'm more interested in replacing the transformer, that's making an awful sound when i connect power (a sort of continuous "chhiiiiiiiii" lol).
    Thanks.
    Galaxy S6 Edge x2 (Gold&White)
    Asus GL552VW-i7 6700HQ|GTX 960M|15.6"FHD|16GB DDR4|512GB M.2 SSD+1TB SSD
    Clevo W230SD - i7 4710MQ|GTX960M|13"QHD+|16GB DDR3L|500GB+256GB mSATA SSD+1TB HDD
    Try Harder!
      When one fails, it can damage the others in a non-obvious manner.
      This means if you then put in the new transistor it blows it up so you waste more money.
      Or the other transistors are "walking wounded" and work briefly before failure.
      • Learn2Day
        • Jun 2013
        • 254
        • Portugal
        Ok. I'll buy 3 more tomorrow before replacing this one.
        Tomorrow, after removing the 4 mosfets, I'll test it again for shorts and post back if any other issue appears. If not, I'll just post success!!
        Thanks for all your help so far.
        Try Harder!
        • Learn2Day
          • Jun 2013
          • 254
          • Portugal
          Hi guys.
          Today i finally received all 4 mosfets and replaced them.
          Now the TV finally turns on, but i have no back light! I pointed a lantern to the screen and i could clearly see the volume bar up and down as i went up or down, but i have no back light in any part of the screen. Can you guys help me?
          Thanks again.
          Try Harder!
          • Learn2Day
            • Jun 2013
            • 254
            • Portugal
            Dunno if this is important but i did noticed i read 12V on D301 and D304, but read 0V on D302 and D305. Could it be U303 is the issue?
            After reading the datasheet it doesn't seem to be that.. I'm so confused.. Please help!!
            Try Harder!
            • Learn2Day
              • Jun 2013
              • 254
              • Portugal
              #26
              Additional info..
              I have connected a CCFL lamp from a laptop screen to lamp connectors and get no output. Also tried to measure outputs but have no voltage.
              Thanks.
              Try Harder!
                Did you put the two jumpers back in place?
                • Learn2Day
                  • Jun 2013
                  • 254
                  • Portugal
                  #28
                  Yes, of course! lol
                  Try Harder!
                    So you are getting 0V at the jumpers? We had you lift the jumper to see if you will get all the voltages back in the earlier test. I am having a little hard time seeing "D301 and D304, but read 0V on D302 and D305" in the pictures.
                    • Learn2Day
                      • Jun 2013
                      • 254
                      • Portugal
                      #30
                      It's not in the pictures budm, it's tiny SMDs hard to see... I used the schematics (download in post #7) to follow the circuit. D301,302,304,305 are connected to U301,302 (AO4606 SMD mosfets) on the inverter circuit.
                      Actually it makes sense, cuz 3193 IC (U303) pins 8 and 9 connected to D302,305, initial state in pins 8,9 is "forced to GND level" accordind to it's datasheet.
                      Even although everything seems fine to me in U303, I'm fairly inexperienced in understanding and testing it, but considering this IC connects all 6 backlights I believe the issue is either here or BL/ADJ input that controls the IC and I have no idea where it comes from..
                      Thanks!
                      Try Harder!
                        So you do have voltage now at the Jumppers? if that is the case then we need to find out if the logic board is sending the BL_ON and Dimming Control (BL_ADJ) to the inverter circuit or not. There should be ENABLE pin to turn on that PWM IC.
                        The BL_ON will be present when the monitor detects the video signal from the PC otherwise it will be in standby state.
                        • Learn2Day
                          • Jun 2013
                          • 254
                          • Portugal
                          #32
                          Hi.
                          I do have 12V at those jumpers. I found a BL pin in logic board connector, and is connected to IC pin 13 through R315, but it's not giving any voltages differences either if TV is on or standby. I read 0.1V in both states.
                          I got a bit confused with your steps explanation... Should I use a video signal in VGA port?
                          Thanks.
                          Try Harder!
                            OK, the logic board is not sending the BL_ON (>2V = ON) to turn the inverter. Yes, you do need to feed the it with video signal, I.E. VGA. The key point is that you should see the backlights flash on at least before it goes into standby. By the way, did anyone else work on this unit before you and did you see it work before it went out?
                            • Learn2Day
                              • Jun 2013
                              • 254
                              • Portugal
                              #34
                              No, no one worked on this TV before. It was offered to me by a family friend after it got busted. Never opened before it got to me. Will try VGA and post back.
                              But my main concern now is.. Either VGA works or not, how do I follow and fix BL_ON signal?
                              Thanks.
                              Try Harder!
                              • Learn2Day
                                • Jun 2013
                                • 254
                                • Portugal
                                #35
                                VGA is recognized by laptop but still no back light. Found schematics.
                                Thanks.
                                Try Harder!
                                • Learn2Day
                                  • Jun 2013
                                  • 254
                                  • Portugal
                                  #36
                                  Well, this is weird.. After following the circuit on logic board, I assume BL is NOT BL_ON, is BL adjustment. I believe BL_ON actually refers to ON/OFF instead.
                                  Weird thing is, ON/OFF has power and VDD on U303 (pin10) also 5V, and ON/OFF (pin6) reads 2.5V. By this, I think the issue is probably not in BKL ON/OFF.
                                  This leaves BL Adjustment (pin13), on which i read 0.99V, but I read 0V in BL connector pin.
                                  I dunno how i can adjust brightness in a dark screen. Brightness adjustment is in menu, and i can't see anything to navigate menu. It's getting worse and worse..
                                  Please help. Thanks.
                                  Try Harder!
                                    At 1V, the lamps should be on, the range of the lamp brightness is 0~5V (0 = min, 5 = Max). So the problem is in the inverter circuit some where.
                                    • Learn2Day
                                      • Jun 2013
                                      • 254
                                      • Portugal
                                      #38
                                      Ok, i started to follow BRT_ADJ circuit on logic board. I believe i found a irregularity, but i don't where the issue is coming from..
                                      I read 2.90V at IC500 pin28, but it drops to 0.78V in R521. All seems fine here, but problem is at Q502 i get 0V output to R526,527. R526 reads 5V in the other end. Already tested C538,540 for shorts but all seems fine.
                                      Could it be a burned Q502? It's an SMD NPN transistor and unlikely to burn, but I'm about to believe anything..
                                      Thanks.
                                      Try Harder!
                                      • Learn2Day
                                        • Jun 2013
                                        • 254
                                        • Portugal
                                        #39
                                        Not really. Please consider I read 1V at pin13, not the connector.
                                        For pin 13, datasheet says:
                                        Low frequency PWM controlling input. A PWM output comes out by
                                        comparing this DC input and the 1.0 ~ 2.5V triangle wave that is generated
                                        by CTPWM.
                                        By this i assume 1V is the minimum voltage which is always present. But I'm open to suggestions..
                                        Thanks.
                                        Try Harder!
                                          So what do you read at the connector? The DC control signal is used to adjust the PWM. The main point is that, the lamps should fire up first and if there is something wrong, the detection circuit will shut it down.
                                          Sch page 3 PL500 pinout for the BL_ADJ.
                                          • trepachka
                                            HP Probook 450 G8 Boardview+Schematics - screen backlight issue
                                            by trepachka
                                            I am just wondering if anyone has boardview+schematics for HP Probook 450 G8.
                                            Computer is missing screen backlight. The backlight fuse must be kaput. I know the fuse is located on the motherboard because we tried a different working screen and it, too is missing backlight.
                                            Perhaps, if the boardview+schematics are not available, someone can point out where the screen backlight fuse is located. Thanks.
                                            03-16-2024, 12:32 AM
                                          • ugamazing
                                            by ugamazing
                                            12-17-2024, 07:05 PM
                                          • coasterghost
                                            Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                                            by coasterghost
                                            For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                                            Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                                            Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                                            System Hardware:
                                            Processor: AMD Ryzen 7 PRO 5850U
                                            Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                                            09-08-2025, 10:46 PM
                                          • shahnld
                                            Lenovo legion 5 pro startup issue
                                            by shahnld
                                            Good day Experts
                                            I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
                                            A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
                                            And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
                                            08-24-2025, 12:31 PM
                                          • ahmarzo
                                            Acer laptop battery draining issue
                                            by ahmarzo
                                            Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
                                            Help me to diagnose this issue as there is no shortage in the inputs MOSFET
                                            08-02-2025, 06:39 AM
