Hyundai HLT-2001B schematics
  • Learn2Day
    • Jun 2013
    • 254
    • Portugal
    #41
    Re: Hyundai HLT-2001B schematics
    Oh man, this is getting tough, only component in inverter circuit that affects all 6 outputs is U303, I've measured it inside out and I could swear it's working properly, only thing missing is proper outputs and brightness adjustment input. Unfortunately i do not have one available to test and there are none in my retailers stock.
    I'm out of ideas.
    Galaxy S6 Edge x2 (Gold&White)
    Asus GL552VW-i7 6700HQ|GTX 960M|15.6"FHD|16GB DDR4|512GB M.2 SSD+1TB SSD
    Clevo W230SD - i7 4710MQ|GTX960M|13"QHD+|16GB DDR3L|500GB+256GB mSATA SSD+1TB HDD
    Try Harder!
    • Learn2Day
      • Jun 2013
      • 254
      • Portugal
      #42
      BL_ADJ/BRT_ADJ reads 0V. This what I've been saying. It's 0V from Q502 forward (page 3).
      Try Harder!
        If you disconnect that line form the pin, then use external DC voltage such 1.5V batteries as the source, then you can see what happen.
        If Q502 is stuck on or has C to E shorted, then that will cause 0V. If you short B to E which will turn off Q502, then the Collector voltage should rise up.
        • Learn2Day
          • Jun 2013
          • 254
          • Portugal
          #44
          That's not an easy task. The same connector feeds logic board and returns Vdd and ON/OFF. Best way of doing that is cutting the wires and that's something I'd like to avoid for now.
          I guess I'll start with Q502 instead. I'll post back results.
          Thanks.
          Try Harder!
            Just short out E to B that will bring the Collector voltage up if the transistor is good.
            • Learn2Day
              • Jun 2013
              • 254
              • Portugal
              #46
              C to E not shorted, shorting B to E didn't rise C. I've found a jumper in BL_ADJ! Will remove it next and post back.
              Try Harder!
              • Learn2Day
                • Jun 2013
                • 254
                • Portugal
                #47
                Shorting B to E didn't rise C voltage. Does this means the transistor is busted?
                Try Harder!
                  That sure looks like it, when you short E to B, the transistor will no longer get the Bias current to turn it on, that is why the Collector voltage will rise up. You can lift the Collector pin also to verify that nothing else load down the voltage, you can see Collector resistor which is connected to the voltage source.
                  • Learn2Day
                    • Jun 2013
                    • 254
                    • Portugal
                    #49
                    Hi guys, sorry for the long absence but my mom was sick and I needed to go to her place for a couple of weeks...
                    Anyway, I removed Q502 and tested, it seems to be working fine, but even without Q502, i still have no backlights!!
                    I tested BL_ADJ without Q502, reads 5V and no BL, after this i removed a shunt to interrupt the 5V feeding and still nothing.. I'm septic to believe the issue is in Q502, but I also dunno what else to do.
                    Any Ideas?
                    Thanks!
                    Try Harder!
                    • Learn2Day
                      • Jun 2013
                      • 254
                      • Portugal
                      #50
                      please help..
                      Try Harder!
                        Sorry, I ran out of suggestion at this point.
                        • Learn2Day
                          • Jun 2013
                          • 254
                          • Portugal
                          #52
                          Yeah, I pretty much expected that, I guess i was just looking for validation before I bin it.
                          Snif...
                          Cheers!
                          Try Harder!
                          • trepachka
                            HP Probook 450 G8 Boardview+Schematics - screen backlight issue
                            by trepachka
                            I am just wondering if anyone has boardview+schematics for HP Probook 450 G8.
                            Computer is missing screen backlight. The backlight fuse must be kaput. I know the fuse is located on the motherboard because we tried a different working screen and it, too is missing backlight.
                            Perhaps, if the boardview+schematics are not available, someone can point out where the screen backlight fuse is located. Thanks.
                            03-16-2024, 12:32 AM
                          • ugamazing
                            Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
                            by ugamazing
                            I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
                            We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
                            12-17-2024, 07:05 PM
                          • coasterghost
                            Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                            by coasterghost
                            For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                            Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                            Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                            System Hardware:
                            Processor: AMD Ryzen 7 PRO 5850U
                            Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                            09-08-2025, 10:46 PM
                          • shahnld
                            Lenovo legion 5 pro startup issue
                            by shahnld
                            Good day Experts
                            I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
                            A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
                            And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
                            08-24-2025, 12:31 PM
                          • ahmarzo
                            Acer laptop battery draining issue
                            by ahmarzo
                            Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
                            Help me to diagnose this issue as there is no shortage in the inputs MOSFET
                            08-02-2025, 06:39 AM
