Sony KDL-40V4100 Blown out color
  • Neonpeon
    • May 2012
    • 41
    Can anyone recommend where to start looking on this one?
    The attached picture is with the brightness turned down quite a bit. Overall the picture looks washed out when I reset the settings to defaults. It's kind of like what you would get by setting a computer monitor to 16 colors.
    Re: Sony KDL-40V4100 Blown out color
    Can you show us what it looks with all controls to factory settings? Could be GAMMA chip fault or LVDS fault, the sudden transitions between colours are throwing me off it being the gamma chip though.
    • Neonpeon
      • May 2012
      • 41
      Here is my Vizio 47 compared to the Sony with the same picture.
      The Sony video settings were reset to default. (From the main menu, not from Service menu.)
      I have cleaned the LVDS Cable, and tcon connectors.
      Doesn't seem to change at all.
      • freakaftr8
        • Oct 2012
        • 3743
        this looks exactly like a TV that was dropped off to me last night exact same Sony exact mines a z4100same picture problem it looks like a gamma IC on the t-con board to me like tom66 said. I havent cracked mine open yet. Do you see a very faint darker left or right side of screen?
          Manual for 46" which should be close enough
          Try accessing service menu, can you see easily accessible reset option? It could be that the RGB DRV and offset are set wrong due to corrupted memory.
          If that doesn't fix it, can we get a pic of the T-con so the gamma chip can be tested?
          • Neonpeon
            • May 2012
            • 41
            I can get into service menu. Just have no idea what to do after I get there. Now that I look at it with my hdmi cable from laptop going into it, it looks like the detail is all there, it just kinda looks like i am looking at it through a white milk carton. It's just washed out.
            It's not faint on either side. It looks to be pretty much solid. When I use the NEC Pattern Generator on it, and it looks great. All the colors are crisp and detailed.
              Does your laptop happen to have a Nvidia graphics chipset?
              • Neonpeon
                • May 2012
                • 41
                No it's a Radeon 6620
                • Neonpeon
                  • May 2012
                  • 41
                  Here's a pic showing the display with the Laptop in the foreground.
                  Might also mention that I am using the same HDMI port on all these pics.
                    I was asking because some Nvidia chipsets have issues with HDMI and sending RGB vs YPbPr data which some TVs do not correctly decode. Try seeing if there is an option for colourspace. Since you say test pattern generator (NEC?) looked OK?
                    • Neonpeon
                      • May 2012
                      • 41
                      It Looks ok, but I think it is because it has a mostly black background. Also, When I change settings on the tv, it flashes from dark to light. In the second it is dark, the image looks good. It is almost as if It has too much backlight which is washing out the screen?
                      • Neonpeon
                        • May 2012
                        • 41
                        Here is how to get to the service menu:
                        Turn off the set
                        Hit Display, Vol +, 5, then power.
                        Here is the service menu. I can hit 2 and get to this screen which shows reset, but I have no idea what to do now.
                        I'm up for trying a complete reset, if anyone knows how to do this.
                        • dcapper
                          • Dec 2013
                          • 496
                          I have the same tv doing this. Did you figure it out?
                          • neilc6
                            • Nov 2015
                            • 1550
                            Most likely AS15F chip on Tcon board.
                            • maxvalutech
                              • 804
                              • australia
                              Yes tcon problem usually and if board economical then replace provided it isn't one bonded to screen.
                                • 12323
                                • U.S.
                                http://www.ustvparts.com/apps/websto...s/show/4290766 Think that one will work, might want to triple check tho, unless you want to try changing out on component level.
                                • dcapper
                                  • Dec 2013
                                  • 496
                                  Awesome! I kinda figured that would be it.
                                  • aaronwt6
                                    • Apr 2013
                                    • 855
                                    • US
                                    Highly unlikely that's the correct T-con for your TV. Most likely you have an AUO LCD panel. That one is for a Samsung panel. You're going to find the AUO replacement closer to $100.
                                      • 12323
                                      • U.S.
                                        • 12323
                                        • U.S.
                                        NO not at all, it's a Sony.
                                        • RetroComputingGrotto
                                          New Toy UNI-T UTi260B - What Settings?
                                          by RetroComputingGrotto
                                          I've literally just received in the post a UNI-T UTi260B (it's currently on charge).
                                          After quickly scanning the user manual I see there are all sorts of configurable settings (Measurement settings, Palette settings, Point temperature settings and Image Mode). As this is my first Thermal Imaging Camera I have no idea what all these settings are nor if I need to change/configure any of them.
                                          I intend/hope to use this to help me diagnose issues with laptop motherboards so should I just leave the settings as the default or is there someone out there with a UNI-T thermal...
                                          09-02-2025, 08:36 AM
                                        • x_orange90_x
                                          Sony Bravia KD-50X690E blown resistor
                                          by x_orange90_x
                                          I just picked up this tv yesterday and the previous owner said while watching tv he heard a loud a pop and then the screen went dark. I removed the back cover and found the source rather quickly; resistor R8601. A chunk of the ceramic had blown off exposing the inner wire. Due to the damage I cannot make out the colors of a couple bands. I likewise cannot find a datasheet for the power supply. I tried pulling up pictures of the same board online but the resistors have different colored bands which I half expected as I've had this happen before.
                                          The power supply is 715G8413-P01-001-0H2S...
                                          07-16-2024, 06:53 AM
                                        • Carlos#2003%
                                          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                          by Carlos#2003%
                                          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                          02-15-2024, 07:52 PM
                                          HP EliteBook 840 G5 + Color LaserJet Pro MFP M477fdw + 3 year NBD HW Support Notebook 800 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook 840 G5 + Color LaserJet Pro MFP M477fdw + 3 year NBD HW Support Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G5 + Color LaserJet Pro MFP M477fdw + 3 year NBD HW Support boardview and 840 G5 + Color LaserJet Pro MFP M477fdw + 3 year NBD HW Support schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...
                                          09-06-2024, 08:23 AM
