Flickering and double/ triple images
  • go-fish
    • Oct 2013
    • 9
    • england
    My samsung 32 inch LCD TV has suddenly developed this problem - flickering and double/triple images of moving objects. When the scene changes, there are frozen images from the previous scene. I have tried removing the ariel and connecting with my laptop through HDMI but same problem.
    Could anyone pls advise? The TV is abt 3 years old.
    G
    Re: Flickering and double/ triple images
    What is the model #? Does the TV have a 100Hz feature? Or is it vanilla 50Hz?
    • go-fish
      • Oct 2013
      • 9
      • england
      It's Samsung LE32C450E1W. Dont know if it has 100 Hz feature.
        Just 50Hz (which is fine, given most 100Hz sets look awful.)
        Can you provide a picture of the fault?
          It sounds like tab bonding, wait to see the pictures to confirm.
          • go-fish
            • Oct 2013
            • 9
            • england
            Sorry for late response. Actually, the problem used to occur few minutes after turning on the TV. For last two evenings, the prob is not occuring so cdn't take pictures.
            • wreksta
              • Aug 2013
              • 508
              • england
              defo tab bonding
              • go-fish
                • Oct 2013
                • 9
                • england
                The problem came back. Pls see attached pictures.
                • freakaftr8
                  • Oct 2012
                  • 3743
                  I can't tell but in those pictures is very faint vertical line and everything underneath that line is flickering like vertically jumping but everything above it is perfect?
                  • go-fish
                    • Oct 2013
                    • 9
                    • england
                    There is no vertical line. however, there is a permanent horizontal line about a centimeter from the bottom edge.
                    The problem occurs after the TV is switched on for 5 minutes. Some weird magenta coloured horizontal/vertical lines start appearing from the left side and then ghost images.
                    • go-fish
                      • Oct 2013
                      • 9
                      • england
                      Some more pictures attached
                      • go-fish
                        • Oct 2013
                        • 9
                        • england
                        Pls advise.
                          Looks like a tab bond/panel failure
                          Different fault possibly same cause/fix
                          http://www.youtube.com/watch?v=purk_SyiT44
                          • freakaftr8
                            • Oct 2012
                            • 3743
                            Agreed. You could push on the tabs to see if the picture normalizes if you feel comfortable doing it.
                            • go-fish
                              • Oct 2013
                              • 9
                              • england
                              I tried doing that yesterday but no change. Is it something which is repairable at a decent cost so that it works for a reasonable time.
                              • freakaftr8
                                • Oct 2012
                                • 3743
                                Ok. Do you have freeze spray. Spray on both sides of the lcd panel right at the line thats one cm from the bottom. see if picture clears up. I had an off brand TV with samsung internals that I modified the screen and it cleared the problem. But this modification is not for the faint at heart.
                                • freakaftr8
                                  • Oct 2012
                                  • 3743
                                  And if the freeze spray method does not work try heat at the same areas. Not too much that it melts anything thou.
                                  • reessi
                                    ACER BM320 Monitor - Horizonal Flickering Lines After a While
                                    by reessi
                                    The monitor started off showing flickering thin (1 pixel) lines horizontally every say 3mm..
                                    They are black on the right and gradually fade to nothing on the far left.
                                    They start either after 5 mins or up to 2 hours after so annoying for testing.
                                    They flicker continuously very fast! With a slight pause milli-second every second.
                                    Initially I cleaned the LVDS cable and connected to the T-Con and then it worked fine for 3 weeks but not sure if this was just co-incidence.
                                    I tested each half by removing the first the left flex from...
                                    06-03-2025, 09:58 AM
                                  • DrvLikHell
                                    Fixing an I-Inc IF281D for the 3rd time, now with added flickering!
                                    by DrvLikHell
                                    Hello everybody! It's been nine years and I'm back again with the same monitor that several people here helped me fix back then. The first time, I replaced two caps as was recommended here and the original problem was solved. Then it started acting up a few years later and I came back for a parts list and replaced a few more caps (I didn't make a post about that and don't remember which ones), and again the problem was solved. This time, however, I'm not sure if it's caps.
                                    The monitor stays on but certain colors will flicker. Generally it's darker colors like dark greys or dark blues,...
                                    07-05-2024, 02:54 AM
                                  • Jaysean
                                    Acer VN7-591G-70RT Display Flickering
                                    by Jaysean
                                    Hello Badcaps coummunity hope you all are having a bless day,
                                    Hope I didn't post it wrong kinda new at forum site rules and tradition
                                    So I'm dealing with screen flickering problem on my laptop.
                                    I'm not quite sure if it's the display cable or the screen itself that's causing the issue,
                                    so I'm turning to you all wonderful expert on Badcaps for some guidance. Your help is much appreciated!
                                    [Screen Flickering](https://i.imgur.com/xK9vHqc.mp4)
                                    [HDMI port to external display seem to work be working](https://i.imgur.com/snSC24e...
                                    10-27-2023, 10:22 AM
                                  • howardc64
                                    TCL 49S405 double image
                                    by howardc64
                                    LCD displays a 2nd image slighty offset vertically. And multiple pairs of black lines along the bottom. Probably common as google "TCL 49S405 double image" pulls up this ifixit post ( link ) with identical ( nearly, but their fault seems to be on the other half of the panel than mine ) problem without solution.
                                    This one looks to be a more difficult to diagnose because most? of TCON seems integrated ( CSOT BGA on buffer baord) into the left panel edge board ( looking from rear of TV) There are 2 buffer boards for each 1/2 of the screen. Main connects to the left buffer board...
                                    06-23-2025, 03:20 PM
                                  • arctor
                                    LG 55uh661v flickering images and lines
                                    by arctor
                                    Hi, I have this tv a LG 55UH661V that show flickering images and lines. I tried to take off one at time the right and the left ribbon cable and put the tape for ask the pin…but nothing working. Or I stop to have picture or still flickering. Someone can help me to understand what pin I have to mask? What I notice the buffering board, the flat cable becomes very hot, I don’t think it s normal, I’m talking about the orange flat cable soldering on the buffering board, both side are very hot. I give you the photo with both the ribbon cable on and a photo with the right off and with the lefts...
                                    06-16-2025, 11:57 AM
