Sony KDL-46ex600 T Con fuse blows
  • DakotaKid
    • Nov 2010
    • 165
    I got this TV and it would power on, gave 5 blink error which indicates bad T Con. I found the 3A fuse on the T Con blown so I soldered a fuse holder with 3A inline and powered on the TV. The picture and backlight came on and showed "no signal message" and other info. The picture showed a lot of bleeding and blotches though the panel seems to be ok as far as no cracks or anything. After about 30 seconds the T-con fuse blew again and now it is back to the 5 blink error code.
    There is no visible damage on the T-con board top or bottom but it doesn't seem to be displaying a clear and proper image before the fuse blows. Is there something I can check, e.g. 12v input or something to diagnose whether it is T Con board or a different problem?
    Thanks in advance.
    DK
    Re: Sony KDL-46ex600 T Con fuse blows
    There should be switching power supplies on the T-CON board, you can tell by the round/sq inductors. You may have bad SMPS IC for those supplies or shorted loads.
    • DakotaKid
      • Nov 2010
      • 165
      Thanks budm. Pictures posted. I took a closeup of the inductor coil that seems to be a little discolored though I cannot tell for sure. Is there a way to test these? If I measure across them on the exposed terminals, both show 0 ohms. Is this worth repairing or should I be looking for a replacement board?
      DK
        I would disconnect those two white ribbon cables that go the panel, then put in the new fuse and see if the fuse will still blow (you can set the meter to DC AMP mode (put the probes in place of the fuse) so you can read the current draw), if not, it may have bad TFT drive ICs. I can see that it has 3 switching power supplies.
        • DakotaKid
          • Nov 2010
          • 165
          Thanks. I went ahead and put another fuse in and disconnected the two ribbon cables. I powered it up and it does NOT blow the fuse. The TV stays on with green power light, backlight stays on until I turn it off. If I read your last comment right that indicates is probably the TFT drive IC's. Are those part of the Tcon or (gulp!) the panel?
          DK
            They are part of the panel. You can try with only one ribbon at a time to narrow it down, it may be a bad driver IC or it may be a component like an MLCC failed (ceramic SMD capacitor.)
            • DakotaKid
              • Nov 2010
              • 165
              Thanks tom and budm. Making progress! I have attached pictures. With left hand ribbon connected and right hand disconnected I get perfect picture on left half of screen. With left disconnected and right connected I get as shown in the picture. Definitely something wrong with the right hand side of panel / drivers / tcon. Hope this helps you guide me to next steps.
              Thanks.
              DK
                That is bad panel TFT drives, I had the same problem in LG 47", see post 10
                  I think you have a defective tab driver #6 from the left. Probably not repairable unfortunately. You can try checking for obvious shorts but the IC is probably bad.
                  • DakotaKid
                    • Nov 2010
                    • 165
                    Well that's a bummer. The half that works sure looks great. LOL. Guess this one is headed to the junk pile. Thanks for the help!
                    DK
                    • Daren87
                      Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                      by Daren87
                      I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                      08-13-2023, 03:25 PM
                    • Michale32086
                      LG 60LN5400 Blows TCON Fuse
                      by Michale32086
                      I could have sworn I posted about this before, but I can't seem to find the post..
                      To whit..
                      I have a 60LN5400 that came in.. Backlights work fine.. No display..
                      Traced the problem to the TCON board.. Blown fuse..
                      Replaced the fuse.. Blows again.. Replaced the fuse again... This time it fries the marked part on the Main Video board...
                      Got a new Main Video Board.. Replaced the fuse on the TCON..
                      The fuse is fine and the backlights come on fine if I don't have the cellophane connectors from the TCON to the...
                      10-30-2019, 09:21 AM
                    • corrize
                      Replacing resistor fuse in Sony DV charger
                      by corrize
                      Hello, I have 2 old chargers for Sony DV, and I found the same resistor fuse dead. Fuse is a crossing component : 0,47 Ohms (0,125W deduced because the lenght is 3mm). But I can’t find the same for buy.
                      So, I want to replace by another like 0 Ohms, 1 Ohms 0,125W,
                      It is the same please ? I guess it’s the same, the only change should be the time to burn ? Thanks...
                      06-30-2025, 06:59 PM
                    • kca
                      by kca
                      Hello all ~
                      08-31-2025, 06:38 AM
                    • thelankanguy
                      Sony KD-55X9000F TCON Issue
                      by thelankanguy
                      The TV shows a black screen with no image.
                      TCON ribbon connectors were disconnected individually for image and there was no half image even.
                      Later both ribbons were disconnected and TCON voltages were tested.
                      12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                      There is also a short to ground in this circled inductor.
                      Is this a TCON issue or something else ?...
                      12-13-2024, 12:27 AM
