Hello. Need opinion from a problem in my TV sony KDL-26B4050. I think the problem is TCON V260B1-C01 (no image, video/ecran black, backlight ok). Is realy the problem in tcon. Someone have tcon schematic V260B1-C01?
Thanks.
Hi, i have the same problem.When i warm the board located above the TCON V260B1-C01 , image comes.First i replace TCON V260B1-C01 whith another one and i had the same problem...Have i problem whith panel????
pictures of boards and one of all boards in one shot
This is my latest mission, to try getting this Sony tv back to normal working orderβ¦
I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
I have tried a Cold Reset as per the service manual.
I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
I have looked all the way through the service manual and tried many online...
Hi, hoping for some views on this one which I've not come across before. The TV generates an image that has 12 noticeable bands across it. The image is still there and accurate, but the colour (or perhaps the brightness) changes gradually across each band which creates a noticeable 'step change' at the edge of each band. Given it's a 4K TV with 2160 rows of pixels, I'm guessing the 12 bands correspond to 12 gate drivers of 180 rows each. If this guess is right, then perhaps:
a) all the gate drivers are malfunctioning the same way (which seems unlikely), or
b) the Tcon board is malfunctioning,...
Hi all! A bit of an interesting and unusual problem: as the the title suggests I have a Hisense H50N5300UK that reboots when showing fullscreen solid red images (and some other solid colours, but red generally causes the issue the fastest). I first came across the problem assuming it was an intermittent issue, but later lucked into finding out that a title sequence of a show I watch happened to trigger the reboot.
What happens:
TV appears to operate normally, for an indefinite amount of time until a problem image appears
The problem image is displayed very briefly, then the
