Vizio m550nv orang light and no turn on
  • audiofreak19
    • Apr 2013
    • 556
    • usa
    #61
    Re: Vizio m550nv orang light and no turn on
    if you dont mind me asking how to i test those. what should the poles read one gnd one voltage and what would the other read.
    • freakaftr8
      • Oct 2012
      • 3743
      Black pole on chassis ground red lead on the biggest pin opposite of the three pins. Write down u1 u2 u3 etc. Write what voltage you get then writw or post a clear pic of the board or write what each regulator says on it.
      meter is set on dc voltage
      • audiofreak19
        • Apr 2013
        • 556
        • usa
        #63
        All of the ones labeled u1 U2 ect. Are the box with 4 legs on each side. I have heard of someone having to replace one of these but I don't know which one they had to replace or hot to test it.
        • audiofreak19
          • Apr 2013
          • 556
          • usa
          #64
          Anyone know how I can test these mosfets or what ever they are.
          • catman25
            • Nov 2013
            Looking for a little help . I am a amateur but pretty good with diy . I have a vizo with no picture ,no sound and wont turn off unless I unplug it . I tested the regulators and these are the reading
            u8 2.4-3.3-5.12
            u9 0-1.18-2.2
            u7 .03 -1.03-2.05
            u33 1.27 - 205 -5.10
            Im suspecting the u33 issue but curious can I replace this with any auto regulator ?
            Freeze spray did not work unless I did that wrong .
            Also I picked up part lm317t adjustable regulator ? Would this work or must I use a 1117 format ?
              u8 2.4-3.3-5.12: 1.25V ref + 2.4 = 3.65V bad. Voltage between ADJ pin and Output pin should always be 1.25V
              u9 0-1.18-2.2 little low
              u7 .03 -1.03-2.05: looks bad, min is 1.25V, this can be due to low input voltage of 2.05V
              u33 1.27 - 205 -5.10: 1.25V ref +1.27 = 2.5V, Bad
              So the rule is, the voltage between the ADJ pin and the Output pin should always be 1.25V +/-2%, the expected output voltage should be = 1.25 + Adj voltage
              Also try to show more resolution of the voltage with at least 2 decimal points.
              See link below for 1117 from Digikey.
              LM317 is not low drop out reg.
              • vinceroger69
                • Mar 2012
                • 6714
                • uk
                #67
                ignore wrong thread
                • catman25
                  • Nov 2013
                  *** would it seem like there is more to the "fix" then regulators ? Any other things that would typically cause these reading same symtoms ?
                  • catman25
                    • Nov 2013
                    I did want to add I have a new main board coming and just trying to fix this one to possibly return new one coming . Just hope its the main board and nothing else
                      It looks like you do have some bad regulators.
                      • audiofreak19
                        • Apr 2013
                        • 556
                        • usa
                        #71
                        So opening up my tread again. I finally just bought another main board off ebay and hooked it up and it did the same thing. I'm wondering more now if it's something on the power supply cause in another forum a guy was having the same problem but he just went and bought a new power supply instead of troubleshooting it down to the component level. On the main power connectors it gets the 5v standby voltages when it's plugged in. But after about 10 min of the flashing logo the other connectors with the 18v and the 12v and bk light and power on get juice all out of no where. I tried testing the 4 diodes on the heat sink ad they seem to test fine they all test the same. I'm not sure what else to do to avoid spending the money on a power supply.
                        • audiofreak19
                          • Apr 2013
                          • 556
                          • usa
                          #72
                          Another thing I have been thinking about. So it could be a voltage regulator on the power supply gone bad cause when I got the tv the main board had a partially melted smd capacitor. So if a voltage regulator went bad and sent more voltage then supposed to causing it to melt. I don't know I'm just brain storming.
                          • Mtrprts
                            • Dec 2014
                            • United states
                            #73
                            Please help. I also have m550nv. No turn on. Just orange vizio light. All readings on power board that are supposed to read 5volt, read correctly. All pins showing 12 volts read zero. I have replace power board and get exact same readings. Any suggestions?
                            • Louis82
                              • Feb 2012
                              • 240
                              Have you guys been able to find what the problem could be on this main board. I have the same symptom, orange/amber light is on but will not change to white. Tv not turning on.
                              • Louis82
                                • Feb 2012
                                • 240
                                Budm, I'm working on this Vizio Tv M550NV. Can you look at these readings and tell me which one seems defective to you. Thanks in advance.
                                IC G5684
                                Pin 1: 1.8V
                                Pin 2: 0.0V
                                Pin 3: 5.0V
                                Pin 4: 5.1V
                                Pin 5: 1.2V
                                Pin 6: 1.2V
                                Pin 7: 0.8V
                                Pin 8: 0.8V
                                IC G5693
                                Pin 1: 5.1V
                                Pin 2: 0.8V
                                Pin 3: 0.0V
                                Pin 4: 0.8V
                                Pin 5: 5.0V
                                Pin 6: 0.0V
                                Pin 7: 1.8V
                                Pin 8: 5.1V
                                IC G5692
                                Pin 1: 5.1V
                                Pin 2: 0.8V
                                Pin 3: 0.0V
                                Pin 4: 0.8V
                                Pin 5: 5.0V
                                Pin 6: 0.0V
                                Pin 7: 2.5V
                                Pin 8: 5.1V
                                IC G5692
                                Pin 1: 5.1V
                                Pin 2: 0.8V
                                Pin 3: 0.0V
                                Pin 4: 0.8V
                                Pin 5: 5.0V
                                Pin 6: 0.0V
                                Pin 7: 3.3V
                                Pin 8: 5.1V
                                • Louis82
                                  • Feb 2012
                                  • 240
                                  Bump
                                    OK, I will download the spec sheets for them first, but so far the outputs look to be about right:
                                    3.3V, 2.5V, 1.8V, and 1.2V which are the typical Voltages.
                                    • Louis82
                                      • Feb 2012
                                      • 240
                                      Thank you Budm.
                                        OK, these are the spec sheets for the Buck converter ICs.
                                        The outputs look right, if you want to really find out for sure then you will need to check the two resistors that are used to set the output Voltage, see the spec sheets for details.
                                        • Adogabriel100
                                          Macbook pro A1278 820-2936 No light/turn on
                                          by Adogabriel100
                                          Hey! how are you guys? i wonder if you could help me with this macbook 820-2936 that does not turn on. (Doesn't have green/orange light).
                                          History:
                                          this macbook came for a short on C6990 that blows D6990 and R6990 on his way. i re-placed the componets and it work again.
                                          A month later comes back again and has the actual problem (no green/orange light and dont turn on)
                                          The macbook can turn on with only the battery connected but in fact, dosent charge.
                                          Voltajes:
                                          PP3V42_G3H = 3.3v
                                          PPBUS_G3H = 12.2V
                                          PM_PWRBTN_L...
                                          06-28-2023, 07:41 PM
                                        • dionzarek
                                          PS5 Slim EDM-040 Only turn on 1 Sec, Blue light then immediate off.
                                          by dionzarek
                                          Hello everyone, I am new to this PS5 troubleshooting, I need help on diagnosing the problem. My PS5 Slim board EDM-040 that beep and only shows blue light then immediately turn off.
                                          I've checked the PSU its normal 12V. I've checked all the capacitors its all good no shorts, but there are 2 caps shorted, I think its near the SSD. You can look at the image attachment.
                                          When tested it only shows 0.003 while other caps show 0.4 to 1. WHen in continuity mode those 2 caps goes beep/shorted.
                                          Any help to where should I check on or suggestion would be very appreciated....
                                          02-08-2025, 11:00 PM
                                        • vdrokko99
                                          MBP wont turn on Only green light on charger
                                          by vdrokko99
                                          I have a similar problem... I got an old MBP for free, but wont turn on... Only green light on charger. I measured these voltages. If i try to do an smc reset using keyboard, nothings happen, wont go out the green led. I dont know how to continue, please help me.
                                          SMBUS_SMC_BSA_SCL 3.5V
                                          SMBUS_SMC_BSA_SDA 3.5V
                                          12-01-2024, 12:18 PM
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • ruletero
                                          HP Omen only do not turn on, only flashes white light
                                          by ruletero
                                          Hi everyone
                                          Please help me with this laptop
                                          HP Omen 15-dc0003la , MB DAG3DBMB8D0 REV. D
                                          It doesn't turn on, when I connect the charger with battery orange light appears on power jack and without battery white light appear, it is fine I think
                                          But if I press power button, power led flashes white once, only that, not consumes anything power, not start, nothing more.
                                          Bios was programmed with a working version, no changes.
                                          Voltages
                                          +3vS5 = 3v when I connect charger, next goes to 0 (I think is fine)...
                                          06-07-2023, 10:11 AM
