Sony Bravia KDL-32BX300 No Standby Light
  • 1beertap
    • Mar 2009
    • 219
    I received this TV from a co-worker in order to fix. He claims that the TV got hit by lightning. The unit has no standby light turned on but the power supply does have standby voltage of 3.3v. I am thinking that the main board has a problem. Any ideas?
  • capkid
    • Oct 2010
    • 1339
    Re: Sony Bravia KDL-32BX300 No Standby Light
    Do you have any other voltages? I'm trying to think through this: Is anything different if you disconnect the main board from the PSU?
    LG Plasma Mal-Discharge Correction Service
      There are two yellow fuses on the power supply board by the white connector that goes to the main board, are they OK?
      You should download the service manual:
      http://elektrotanya.com/?q=showresul...oria=&kat2=all
      • 1beertap
        • Mar 2009
        • 219
        main board plugged in
        STBY = 3.3v
        ACOFFDET = 2.0V
        POWERON = 3.28V
        everything else = 0v
        main board unplugged
        STBY = 3.3V
        ACOFFDET = 3.29V
        POWERON = 0V
        • 1beertap
          • Mar 2009
          • 219
          Both fuses check good
          • 1beertap
            • Mar 2009
            • 219
            Hey guys, any other ideas?
            • philliesfan30m
              • Aug 2013
              • 542
              do the wires that go to the standby light attach to the main board through the side power panel?
              • philliesfan30m
                • Aug 2013
                • 542
                here is the schematic for this tv.
                • philliesfan30m
                  • Aug 2013
                  • 542
                  oops bud already posted 1 for your tv
                    OK, on page 29 of the service manual, report the voltage reading of ALL the pins of CN6401/6402/6403 when TV is plugged in and not turn on ( in standby mode) and when TV is powered on by the power switch. Black probe on the chassis, all the boards are connected together.
                    • 1beertap
                      • Mar 2009
                      • 219
                      Okay, here's what I tested.
                      CN6401
                      1 STBY3_3V = 3.3V
                      2 AC OFF DET = 2.0V
                      3 POWER ON = 3.28V
                      4 AUDIO_12V = 0V
                      5 AUDIO_12V_GND = 0V
                      6 REG12V_GND = 0V
                      7 REG12V_GND = 0V
                      8 REG12V = 0V
                      9 REG12V = 0V
                      10 BL_ERR = 0.05V
                      11 BL_ON = 0.04V
                      12 DIMMER = 0V
                      13 NC = 0V
                      14 T-CON_VCC_12V= 0V
                      15 T-CON_ON = 0V
                      CN6402
                      1 UNREG24V = 0V
                      2 UNREG24V = 0V
                      3 UNREG24V = 0V
                      4 UNREG24V = 0V
                      5 UNREG24V = 0V
                      6 GND = 0V
                      7 GND = 0V
                      8 GND = 0V
                      9 GND = 0V
                      10 GND = 0V
                      11 BL_ERR = 0.05V
                      12 BL_ON = 0.04V
                      13 NC(ADIM) = 0V
                      14 DIMMER = 0V
                      CN6403
                      CONNECTOR NOT USED
                      When I attempt to turn the unit on, the readings are still the same. Even though it does have a standby led and power led, both remain off at all times. The power button does work and is connected to the main board. The led indicators are connected to the main board via a separate connector from the buttons. Thanks guys and hope this helps.
                        OK, you have power supply board problem, it is getting the PS_ON (Power ON) but the 12V, 24V are not coming on. BUT, one voltage should change state, POWER ON = 3.28V, it should be below 1V when TV is powered OFF and 3.28V when Power switch is activated, if it does not change state, that mean the main board is also stuck on, so you may also have main board problem.
                        • xredhawk
                          • Jul 2011
                          • 103
                          i hear alot of problems with bad eeproms
                          • anmol
                            • Mar 2012
                            • 73
                            • India
                            disconnect socket from remot control board and check power on with keypad.
                            wbr
                            • chapulin
                              • Sep 2013
                              • mexico
                              since you do not have 12 volst you should check the circuit cxa
                              • dcapper
                                • Dec 2013
                                • 496
                                I have the same tv and replaced the power supply. It was a no go. It's the mainboard. I'm almost sure of it. I think you have the same issue.
                                • anmol
                                  • Mar 2012
                                  • 73
                                  • India
                                  @ dcapper,
                                  you have try as post #14 ?
                                  wbr
                                  • dcapper
                                    • Dec 2013
                                    • 496
                                    Originally posted by anmol
                                    @ dcapper,
                                    wbr
                                    I'll check mine tonight. I bought a new power supply and it didn't work, so I'm willing to go on a little faith.
                                      dcapper, are you getting the PS_ON signal to the power supply board?
                                      • dcapper
                                        • Dec 2013
                                        • 496
                                        No. I ordered a new mainboard today for $50.00
                                        • SkishyIshy
                                          Sony Bravia XBR-65x900f: No Power, No Standby-light - however 3.3v STBY is present
                                          by SkishyIshy
                                          Hey All,
                                          I have a Sony 65x900f that I purchased cheap because of a no-power issue.
                                          I assumed that because there is no standby light visible, it would be an easy fix - however upon opening up of the unit I can confirm that the 3v3 standby voltage is making it's way from the power supply to the main board. I'm a little confused as to why there is no standby light.
                                          I am firstly wondering if anyone has this model of TV, or has worked on one and can give me some insight. I have tried to find a service manual for this model, to no avail - and would really appreciate...
                                          03-17-2021, 11:44 AM
                                        • androripara
                                          Sony Bravia 55HX820 - 4 times blinking red standby led
                                          by androripara
                                          i am trying to repair a Sony KDL-55HX820 led TV which is throwing error code 4 (standby led flashing four times).
                                          I followed the troubleshooting flowchart at page 69, and between pin1 and pin7 of CN6002 i am reading 1.91V so i guess i can rule out the B Board as the culprit.
                                          Before ordering new G* Boards (by the way, should i change both? it is not specified in the manual) i wanted to try and do more advanced troubleshooting since i've read in other threads people resolving their problems on the 46/55 HX 820/823/825 models by replacing the Samsung led...
                                          10-19-2023, 05:16 AM
                                        • noinimod
                                          Sony 55X900E no standby light, no power. Replaced mainboard already
                                          by noinimod
                                          No standby red light, nothing
                                          This Sony has a separate AC->DC power adapter supplying 19.5V to the TV power board (JK3)
                                          Disconnected JK3 power board from main board, checked voltages on all the pin outs
                                          At a few pins I can see the power supply providing 19.5V to the main board
                                          Based on the service manual triage.. it seems to be pointing towards the power board (JK3) being the most possible culprit
                                          LED light turns on when I disconnect LED driver board ribbon from mainboard (so i thought it is the mainboard,...
                                          12-22-2021, 12:58 AM
                                        • jasonbay13
                                          Philips 37HFL5682L/F7 no standby light, incomplete service manual?
                                          by jasonbay13
                                          picked up a tv and when the power is plugged, the standby light flashes real quick then goes off. of 3.3, 12, 24v is all there but i couldnt find any 5v on the back-end board. ON/OFF is low, which it seems is what turns on the backlight so i removed the wire at the back-end board and put a 10k resistor to the 3.3v, which when plugged in brings on the backlight for a split second and also a blue light "LED1" on the inverter board, which goes off after a short time.
                                          am i missing something to bring on the backlight or is the inverter/ccfl gone bad? would that cause the inverter board...
                                          12-01-2023, 09:55 PM
                                        • Nicktronic
                                          Samsung UN70NU6070F Standby Light flashes twice
                                          by Nicktronic
                                          Hey Everyone,
                                          So I've got this Samsung and the reported issue is that when powered on the backlight comes on, but no picture, no sound, it will flicker, the standby light will flash red twice and repeat the whole process...each loop lasts about 15 seconds.
                                          I've googled the issue and understand it is likely a panel/driver board issue, but was hoping the "tape method" could be successful. Before I did that though, I disconnected the left LVDS cable and powered the TV on. This time I got sound, no picture and the two blink standby light stopped. Did the same...
                                          03-27-2023, 07:01 PM
