I received this TV from a co-worker in order to fix. He claims that the TV got hit by lightning. The unit has no standby light turned on but the power supply does have standby voltage of 3.3v. I am thinking that the main board has a problem. Any ideas?
Sony Bravia KDL-32BX300 No Standby Light
Re: Sony Bravia KDL-32BX300 No Standby Light
Do you have any other voltages? I'm trying to think through this: Is anything different if you disconnect the main board from the PSU?Last edited by capkid; 09-05-2013, 07:48 PM. -
There are two yellow fuses on the power supply board by the white connector that goes to the main board, are they OK?
You should download the service manual:
http://elektrotanya.com/?q=showresul...oria=&kat2=allLast edited by budm; 09-05-2013, 09:17 PM.Never stop learning
STBY = 3.3v
ACOFFDET = 2.0V
POWERON = 3.28V
everything else = 0v
main board unplugged
STBY = 3.3V
ACOFFDET = 3.29V
POWERON = 0V
everything else = 0vComment
http://elektrotanya.com/?q=showresul...oria=&kat2=allComment
do the wires that go to the standby light attach to the main board through the side power panel?Comment
OK, on page 29 of the service manual, report the voltage reading of ALL the pins of CN6401/6402/6403 when TV is plugged in and not turn on ( in standby mode) and when TV is powered on by the power switch. Black probe on the chassis, all the boards are connected together.Never stop learning
Okay, here's what I tested.
CN6401
1 STBY3_3V = 3.3V
2 AC OFF DET = 2.0V
3 POWER ON = 3.28V
4 AUDIO_12V = 0V
5 AUDIO_12V_GND = 0V
6 REG12V_GND = 0V
7 REG12V_GND = 0V
8 REG12V = 0V
9 REG12V = 0V
10 BL_ERR = 0.05V
11 BL_ON = 0.04V
12 DIMMER = 0V
13 NC = 0V
14 T-CON_VCC_12V= 0V
15 T-CON_ON = 0V
CN6402
1 UNREG24V = 0V
2 UNREG24V = 0V
3 UNREG24V = 0V
4 UNREG24V = 0V
5 UNREG24V = 0V
6 GND = 0V
7 GND = 0V
8 GND = 0V
9 GND = 0V
10 GND = 0V
11 BL_ERR = 0.05V
12 BL_ON = 0.04V
13 NC(ADIM) = 0V
14 DIMMER = 0V
CN6403
CONNECTOR NOT USED
When I attempt to turn the unit on, the readings are still the same. Even though it does have a standby led and power led, both remain off at all times. The power button does work and is connected to the main board. The led indicators are connected to the main board via a separate connector from the buttons. Thanks guys and hope this helps.Comment
OK, you have power supply board problem, it is getting the PS_ON (Power ON) but the 12V, 24V are not coming on. BUT, one voltage should change state, POWER ON = 3.28V, it should be below 1V when TV is powered OFF and 3.28V when Power switch is activated, if it does not change state, that mean the main board is also stuck on, so you may also have main board problem.Last edited by budm; 09-08-2013, 11:40 AM.Never stop learning
I'll check mine tonight. I bought a new power supply and it didn't work, so I'm willing to go on a little faith.Comment
dcapper, are you getting the PS_ON signal to the power supply board?Never stop learning
by SkishyIshyHey All,
I have a Sony 65x900f that I purchased cheap because of a no-power issue.
I assumed that because there is no standby light visible, it would be an easy fix - however upon opening up of the unit I can confirm that the 3v3 standby voltage is making it's way from the power supply to the main board. I'm a little confused as to why there is no standby light.
I am firstly wondering if anyone has this model of TV, or has worked on one and can give me some insight. I have tried to find a service manual for this model, to no avail - and would really appreciate... -
by androriparaHello everyone,
i am trying to repair a Sony KDL-55HX820 led TV which is throwing error code 4 (standby led flashing four times).
I followed the troubleshooting flowchart at page 69, and between pin1 and pin7 of CN6002 i am reading 1.91V so i guess i can rule out the B Board as the culprit.
Before ordering new G* Boards (by the way, should i change both? it is not specified in the manual) i wanted to try and do more advanced troubleshooting since i've read in other threads people resolving their problems on the 46/55 HX 820/823/825 models by replacing the Samsung led... -
I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
What I already found is that the 12.8V are not an the connector to the main board connector to the power... -
by noinimodNo standby red light, nothing
This Sony has a separate AC->DC power adapter supplying 19.5V to the TV power board (JK3)
Disconnected JK3 power board from main board, checked voltages on all the pin outs
At a few pins I can see the power supply providing 19.5V to the main board
Based on the service manual triage.. it seems to be pointing towards the power board (JK3) being the most possible culprit
LED light turns on when I disconnect LED driver board ribbon from mainboard (so i thought it is the mainboard,... -
by AleMontiHi everyone,
I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
After checking the basics I did the following:- I measured all voltages and as expected the only active supply is the 3.5V standby. It
- Loading...
