Philips 50pf9631d/10
  • soukehal
    • Dec 2012
    • 45
    • Algerie
    7 have flashing lights but I'm confused everyone with the same model number has a different board then mine, no Bonbe capacitor. Please Help
  • soukehal
    • Dec 2012
    • 45
    • Algerie
    Re: Philips 50pf9631d/10
    hello no answer 8001 led flashes 5 times 5 fault codes for VS .. here I have disconnected the power supply connector (PS-505-PHN LJ44-00125 20060705 Rev.02) 8006 cn ... TV starts with LED 8001 and LED 2000 hand no logic unit 50'HD VS.1 ASIC) green alas no picture fix, remote react Ar / walking and volume, mute more channels, I believe pane on module (model 50HD W1 Y-MAIN PCB code 41 LJ-04084A
    Rev. No. Ri.0 (07.06.15) following someone can help me thank you.
    • capkid
      • Oct 2010
      • 1339
      Your issue may not be a power supply problem. You may have a peripheral board that is failing. A 42" Philips I worked on that had 7 blinks had a bad CBA audio board. I'm not saying that's your problem, but I wouldn't automatically assume the power supply is at fault. These Philips TVs can be tricky. I'd do a couple things:
      (1) Thoroughly examine the power supply with a flashlight to see if you can find any burned components.
      (2) Try disconnecting various boards from the TV circuit one at a time then try to turn on the TV after disconnecting each board. When I had an audio board problem and I disconnected the CBA board, the TV turned on and I had a picture (of course, I had no sound).
      What is your chassis version (e.g. BJ2.2)? There should be a label on the back cover of the TV with this info. You can search Tom's service manual database using the chassis version: http://www.toms-service-manuals.com/
      LG Plasma Mal-Discharge Correction Service
      • himinshed
        • Aug 2013
        • 20
        • australia
        hello all my chassis is ftp 2.2a aa model s42ax-xb01 product code bx1a0508 344594 i have looked on toms service manuals and cant find one i have checked the power supply with a flashlight ,cant see any problems .have diconected boards one at a time no change in voltage readings i am adding a picture of the power supply ,have circled transformer KE 04477a which i think may have been hot but i have no data to test it any sugestions on where to find a service manual would be great cheers Shayn
        • soukehal
          • Dec 2012
          • 45
          • Algerie
          hi, "capkid" I thank you for the aid, for me I disconnect cn8006 all his attention connector present Demare tv with LED 8001 and 2000 Alume I CROI problem on Y-MAIN.
          I consider food, not burned components, my version of the chassis is BJ3.0E PA? elas the Shema does not even thank you.
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • tuner2000i
            Philips 65PUS8518/12 distorted image after main board replacement
            by tuner2000i
            hello everyone,
            I don't normally do tv repairs but this is a case with my personal TV which got fried together with many other electronics in my house after a thunderstorm.
            The TV is a Philips 65PUS8518/12 which had no power. I measured and concluded that the main board was probably fried through ethernet or hdmi. I found a board with same number 715GD328-M0F-B00-005Y (I had G) but from a 55PUS8518. The TV starts but the image is doubled, distorted. I need to set the panel code which is 016 according to the sticker on the back but I can not seem to do it.
            07-15-2025, 01:15 PM
          • howardc64
            by howardc64
            07-24-2025, 05:17 PM
          • spantor
            Activate power board Philips 40PFH40009/88 tv
            by spantor
            Hello partners.
            Could someone tell me how to make this Philips TV source work without the mainboard being connected? The model of the board is EAX65423701 (2.1) and the model of the Philips TV is 40PFH40009/88.
            The TV is dead, there is no standby light, however there is a voltage of 12v on the pins ( included 12v VAU ) and 3.2v on the PS-ON pin (see photo) when the power board is connected to the main board. If I disconnect both boards I only get 8 volts on 12v pins. I would like to rule out a fault in the main board by making it work, but so far no one has been able to tell...
            02-11-2024, 05:07 PM
