Proscan 40LD45Q Power Supply not turning back lights on, no HV fault present.
    Re: Proscan 40LD45Q Power Supply not turning back lights on, no HV fault present.
    What is getting me is that, we know the inverter is putting out the high voltage since you did have burnt wire when the HV connector was not seated properly, so I expect ypu to the see the backlights to flash on then goes in to shutdown due to error.
    • sattech200
      • Aug 2012
      • 59
      I agree. I posted the youtube video to show I don't even get the slightest flicker out of them. What gets me even more is I can hook the power supply/inverter directly to a test bulb and it will turn it on.
      Don't have a lot of experience under my belt with these but is it possible that the power supply/inverter isn't capable of supplying the current needed for all of the bulbs?
        Even that it will at least try once then if the power supply droops down then it stops.
        • jmm1952
          • Sep 2011
          • 10
          SATTECH200...did you resolve this issue?? I have the same problem...connector arced and burnt connector. With HV wires not connected the on (blue) light remained on. All voltages COLD side are good 5,12,24vdc. Took HV transformers off to test, replaced connector, replaced the 2-5pico farad caps...plugged it in.. now it seems no HV voltage available at connector. With the voltage seen on this thread. I'm going to double check all voltages. Hope to hear you had some success.
          • sattech200
            • Aug 2012
            • 59
            Not yet unfortunately
            I did replace the balancer board and that had no change of the issue. I suspect that one of the transformers on the power supply is weak and plan to replace the power supply next. I really hate swap testing components like this but after spending A LOT of time researching the issue I just keep hitting a brick wall for information. Just not sure what to think at the moment.
            Waiting on some extra money to order one at this time.
            • jmm1952
              • Sep 2011
              • 10
              Thanks for the response...I've been working on this Proscan for about a week (off and on). Just put it back together this afternoon...turned it on red (stby) to blue (on) but no image. I did go back and check the HV filter measured 386VDC and noticed that the backlight hit for about 2secs then off...but unit didn't go to stby. Going to measure the readings at balancer board. Thanks will post what I find.
              • phil245
                • Feb 2014
                You may have bad lamps in the LCD panel
                • ruaok
                  • Aug 2014
                  Originally posted by sattech200
                  I've spent a solid day looking for service manual/schematics for this set and finally found this. Talk about waving a carrot in front of the rabbit. ughhh. Seriously wish I could find the full manual.
                  http://dc359.4shared.com/doc/qwaBqW_4/preview.html
                  I've started troubleshooting power supply but would really like to know what IC U2 is. Half the numbers are scratched off. I've used a couple different magnifying glasses and can only make out.
                  E6E....
                  SE6...
                  I've checked voltages at U1 (Inverter IC, OB3316QP) and all look good from what I can tell (based on my limited knowledge and experience) according to the datasheet I found here EXCEPT for the VS, I'm not clear on what that should be from the datasheet.
                  U1 Inverter IC, OB3316QP
                  1-ENA…….……2.75v
                  3-CS…………….1.27v
                  5-STIME……....0v
                  6-VS…………....0v
                  7-VDDA…..……5.17v
                  8-GATE2……….2.05v
                  9-GATE1……....2.05v
                  11-RI….………...2.40v
                  14-BF/DMOD..2.07v
                  15-DIM…….…..3.45v
                  16-SVD…….…..5.19v
                  One thing that keeps sticking in my head is that I haven't been able to identify any fuses on any boards of this set outside of the glass one on the main input.
                  Attached Pics are the backside of the power supply board RE46AY2502, AYL400203. I can try to get clearer pics if that will help any.
                  Any and all thoughts, comments or suggestions are greatly appreciated.
                  Thank you.
                  Randy
                  HERE IS YOUR FULL SERVICE MANUAL.
                  YOUR LINK ABOVE LED ME TO IT, IT TOOK ME OVER 3 HOURS TO FIND, BUT GOOGLE AND THE INTERNET ARE MAGIC.
                  • Rodville
                    • Sep 2015
                    • 20
                    Was there any update on this? I just got one of these TV's and when I plug it in I only get a blue light.
                      03-31-2024, 02:12 PM
                    • Tynan Dill
                      by Tynan Dill
                      Assuming...
                      11-22-2024, 01:46 PM
                      07-01-2024, 06:34 AM
                    • madan1
                      555 based power supply getting too hot
                      by madan1
                      Good day.
                      I have an AC/DC -> DC PWM (rectifier + 555 buck converter) power supply with MDF11n60, which is getting very hot.
                      The input is AC from a transformer and the output powers a 24v dc fan. The power supply is used to regulate the speed of the fan.
                      After several runs on the bench power supply I noticed that the mosfet is reaching 80+C*. The mosfet reads fine on component tester, the thermal paste is changed, the fan is cleaned and with freshly oiled bearings.
                      When powered directly from the bench psu, the fan takes ~0.7A on 12V. The current consumption is similar...
                      06-23-2025, 04:38 PM
                    • Andreas_de
                      Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                      by Andreas_de
                      Hello!
                      i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                      Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                      Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                      04-12-2025, 10:38 AM
