Dynex DX-46L150A11 backlight/inverter problem?
  • nomoresonys
    • 12206
    • U.S.
    #41
    Re: Dynex DX-46L150A11 backlight/inverter problem?
    Originally posted by davekra
    Well, it's definatily a bad bulb.
    I cut the traces that go to two bulbs and swapped them and the unlit bulb didn't move. Inverter is good.
    So, the only thing to do is disassemble the display panel.
    Taking it apart was easy enough...I just really hate touching the actual display panel (finger prints and all. OK, I have issues)
    You can see in the pic the bad bulb. You can also see that the plastic reflectors are pretty crispy (I can paint or put some foil on them). They should be white and you could actually see that in the display.
    So, given that one bulb is bad how long before the others go too? And if one is replaced, wont it's color be brighter than the others? The bulbs dimm over time till they die.
    This was my mother-in-laws set and she never really turned it off so if I had to guess, the bulbs have 10k to 15k hours on them. They're about done arent they?
    CFLWarehouse.com has them for $20 which is $240 for the set. Think it's worth it? Or just replace one, get a little more life from it and stop worring about stuff?
    What do you think?
    Thanks,
    davidk
    I think I'd try the 20 dollar bulb Dave spoke of here.
    • audiofreak19
      • Apr 2013
      • 556
      • usa
      #42
      I'm interested in what happens after the bulb. I swapped my bulb and got 2 sec to black. The bulb lights up fine but shuts off. Please let us know what happens when you put a bulb in it.
      • jackal68
        • Mar 2014
        • 91
        I know this is an old thread but i found a guy on youtube who installed a resistor to bypass a bad bulb (2:15 min into the video). However, I am not sure of the resistor value (brown, red, black - i'm assuming it is 120ohm, can anyone confirm)? Also, he mentioned that he moved the bulb from the middle to the bottom; how difficult is it to do that?
        thanks.
        https://www.youtube.com/watch?v=TO1_pkFNJKY
        • nomoresonys
          • 12206
          • U.S.
          #44
          Moving the tube is a total stripdown job, you might have luck with this method but it leaves the tube where it is, do you know which tube it is?: https://www.youtube.com/watch?v=Dh01ZepjDp0
          • jackal68
            • Mar 2014
            • 91
            I believe it is either the 3rd or 4th one from the bottom (very similar to what the guy had on the youtube video).
            • nomoresonys
              • 12206
              • U.S.
              #46
              Most of the time you don't notice much being one tube down, mostly only when there's a solid color on the screen, fixed one that happened to be right at the top, I only noticed it if I looked really hard but I think that's only because I knew it was there.
              • jackal68
                • Mar 2014
                • 91
                Hi
                could I know how you 'fixed' it? Was it using the resistor suggestion on the youtube video or another way? I want to confirm if the resistor is 120ohm or 12ohm. thanks
                • nomoresonys
                  • 12206
                  • U.S.
                  #48
                  Look at the video, I believe he used just a jumper wire to bypass the transformer if you are sure you have the faulty transformer located you can just remove it, I bypasses because it was easier for me.
                  • jackal68
                    • Mar 2014
                    • 91
                    Okay, i actually ordered another inverter board, but unfortunately, it arrived cracked. Initially, I thought I could use the transformer from the cracked board on my board, but it turns out that the board versions are difference (I assume they are still compatible), so the transformers are actually different as well (see pic). I am wondering if anyone know whether I can still swap the transformers, making sure that the 'proper' connections are made to the board.
                    I also tried jumping the timer pin to ground, but it didn't work. The tv would still lose the backlight after a few minutes. Lastly, i took out the transformer altogether, but in this case, the light would come on for a few seconds and then turn off.
                    As I already had the transformer off, I took out another transformer from the same board and swap them, to see if the dark lcd location would change - it didn't. So, i assume that the lcd bulb is faulty. As such, is there anything I can do to bypass the backlight turning off (I tried the jumping pin but didn't work).
                    any ideas before I dump this tv?
                    https://
                    • nomoresonys
                      • 12206
                      • U.S.
                      #50
                      Appears to be something wrong, pretty sure if you have a bad lamp or transformer and you take the transformer out of the equation, the tv should stay on. one lamp down, thinking you either took off the wrong one or you have a whole different issue.
                      • jackal68
                        • Mar 2014
                        • 91
                        Maybe there is something else going on. As soon as I take out one transformer, the tv turns on for a second and then the backlight goes out. Whereas, when all the transformers are on the board, i get about 2-5 minutes.
                        It doesn't matter which of the 12 transformers I take out, the backlight will go off in 1 sec (i've tried 3 of them already).
                        Do i need to jump some wires so as to bypass the transformer i took out?
                        • nomoresonys
                          • 12206
                          • U.S.
                          #52
                          Ok, was thinking that this tv may be different, the ones that were successfully fixed all seemed to be samsung as was mine, go back and read the thread, bud tells of some differences in post #29.
                          • jackal68
                            • Mar 2014
                            • 91
                            yes, I'm aware of post #29 (I thought you were as well). Nonetheless, thanks for giving me some inputs.
                            I'm still wondering if I ground that pin with a resistor, whether it will work. I tried grounding the pin without a resistor and there was no change to the tv.
                            can anyone tell me if that's 12ohm or 120 ohm?
                            Again, the resistor color is found at 2:23 min of this video below:
                            • jackal68
                              • Mar 2014
                              • 91
                              well, i decided to take a chance and solder in a 120ohm resistor (as per the video). It worked! The screen stays on now (even though there is a darker line where the bulb is burnt). It is not very noticeable when watching tv, only noticeable on a blank screen.
                              For the price of the resistor, this is great to keep my tv alive!
                              Hopefully, this helps someone else.
                                I look at that video (per jackal68), the resistor look to be 12 Ohm (Brown/Red/ Black), it can be just jumper wire, and he said pin 3, it is actually pin 14 (you can see the Dot on the IC for pin 1 is located), so what he did was to bypass protection circuit. I would keep an eye on that TV and will not leave it on if you are not around to monitor it since protection circuit is no longer in place..That high Voltage for the bad bad lamp is still present and it can arc over.
                                Basically it is not a fix, it is bypassing the protection circuit, it is like using tin foil in place of the fuse.
                                There are many video out there about bypassing, but they do not tell you what the bypassing actually done to the circuit and no warning either.
                                • nomoresonys
                                  • 12206
                                  • U.S.
                                  #56
                                  Ok, thanks Bud, there's the difference, the fix in the video I posted and same fix I did on mine was not a protection disable, which I would NEVER do, no sense in burning down the house.
                                  • jackal68
                                    • Mar 2014
                                    • 91
                                    It is good to know. As this is a tv that will only be used sparingly, i'll keep my eye for the issue and make sure it is not left unattended.
                                    Thanks for the feedback.
                                    • ezenia
                                      LUMIMAN Smart Bulb IC ID?
                                      by ezenia
                                      I have a LUMIMAN Smart Bulb that suddenly stopped lighting one day. The bulb is still detected in the app, but won't light. I've probed around and nothing seems to look off with any of the diodes, caps or resistors. The Bluetooth/Wi-Fi module seems to be working as it's still detected in the app. I even tried deleting and re-pairing the bulb (it didn't light, but I was still able to follow the pairing instructions), it re-paired fine, but still no light.
                                      In diode mode, the LEDs all light up when probed so I'm guessing this means the LEDs themselves are OK. I was expecting...
                                      04-28-2025, 05:56 PM
                                    • x_orange90_x
                                      Vizio E55-E1 bad backlights or bad inverter?
                                      by x_orange90_x
                                      I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
                                      I don't know how exactly to test the inverter itself. Is it...
                                      01-29-2025, 09:24 PM
                                    • vestaviascott
                                      Epson 5040UB Projector No Lamp Strike Stuck in Startup - Blinking Status/Lamp Lights
                                      by vestaviascott
                                      Hoping someone here can put me on the right track. I'm trying to troubleshoot/flowchart the "internal projector error" on my newly acquired Facebook Marketplace bought Epson 5040UB projector (3LED, not DLP). Owner said it needed new lamp, actually error code blink pattern indicates "Internal Projector Error, call Epson support". Unit is out of warranty as of 8/19
                                      Here's what happens:
                                      1) Power on
                                      2) Blue power indicator lights and the lens cover motor opens the lens cover, light fan noise heard
                                      3) Blue status light flashes for appx 4 minutes...
                                      07-29-2020, 06:08 AM
                                    • Gentian
                                      APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                                      by Gentian
                                      I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                                      It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                                      03-06-2023, 07:07 AM
                                    • valvashon
                                      Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                                      by valvashon
                                      For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                                      History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                                      01-04-2024, 01:44 PM
