Vizio V042L No Picture has backlights.
+ More Options
Posts
  • philliesfan30m
    • Aug 2013
    • 542
    Re: Vizio V042L No Picture has backlights.
    i have checked out the controller chip and i don't see any signs of burning. now i just have to wait for the mosfets to get here and i'll post back if that fixed the problem. thanks for all the help tom it is greatly appreciated i have another tv with a problem but i am gonna start a new thread it turns on then shuts off after a few seconds and goes into standby mode thanks for the help
    • philliesfan30m
      • Aug 2013
      • 542
      is there a special way to get off q7,8,9, and 10 they are mosfets but they are attached to the board not a heatsink any good tricks to get them off? i'm having a heck of a time! i got the 2 pins on everyone disconnected but the back i can't get loose from the board any help appreciated
      • philliesfan30m
        • Aug 2013
        • 542
        nevermind i didn't realize they needed so much heat
          I cut off the two legs, then use Flux and ADD more solder to retain heat, also high Wattage iron ~60W should be used.
          • philliesfan30m
            • Aug 2013
            • 542
            i replaced the 4 mosfets on the inverter board but i still don't get a picture the t-con board come one when i first turn it on the goes out after a few seconds. i have all the correct voltage at the inverter board. all the mosfets i replaced read 10 except 1 which reads 9 with the dmm on 2000k. i read somewhere they are suppose to read 8.5k is that true? i ordered the ones that are 8.5k on the datasheet. why is the t-con board turning off though?
            • philliesfan30m
              • Aug 2013
              • 542
              thats a good idea for removal i will take note of that for future reference. i checked the capacitance of the 3 samwha caps on the inverter board and they all 3 read around 2400 but the are only rated at 680uf should i try that as the next solution? and i saw many people going up in voltage and up in uf higher than what they were using but how high is ok or should i just replace with the same exact?
              • philliesfan30m
                • Aug 2013
                • 542
                i hear they are crap caps anyways they are 35v 680uf caps on it now. what is anyones input?
                • capkid
                  • Oct 2010
                  • 1339
                  Did you test those caps out of the circuit? I'd de-solder at least one lead of each cap to make sure your readings are accurate. They might be fine. Space might be an issue, so you may not be able to go up much beyond the 35V. Since they're Samwha caps, I'd probably replace them anyway. Bud may have a different take or reasoning, but you normally want to keep the capacitance the same.
                  LG Plasma Mal-Discharge Correction Service
                  • philliesfan30m
                    • Aug 2013
                    • 542
                    yeah space is a problem because they are laying down on the board. but do you tink they could be the cause of my not having any backlight? or do you think it is the backlight driver that everyone else seemed to have a problem with on the tv. i will take 1 out and check it.thanks for the reply
                    • philliesfan30m
                      • Aug 2013
                      • 542
                      checked the caps out of circuit and they are good so i guess i has to be that backlight driver. if the inverter isn't working proplerly will that make the t-con shut down?
                        LCD LED TV Service Menu Codes
                        TCL LED TV Service Menu Code
                        LG LED TV Service Menu Code
                        10-31-2024, 03:58 AM
                      • Ierwin
                        Philips 58PUS7805 Menu working but no/weird picture from video sources
                        by Ierwin
                        I got a 58pus7805 that shows some weird behavior.
                        The menu and remote work fine and the picture is looking crisp and flawless while navigating the menu.
                        However, when a video source is displayed the screen either goes solid green (HDMI), solid black (SAT TV) or shows some fragments on mostly green background (AVI Playback from USB).
                        I tried to reinstall the firmware through the menu which was rejected saying it already had the latest version.
                        I managed to install the latest official firmware by holding the control button while plugging...
                        03-10-2024, 12:50 PM
                      • gavric
                        Vizio M70-C3 Half picture is bad, main board on its last leg?
                        by gavric
                        Hello, i am working on Vizio M70-C3. It can hardly power on, it takes 15 power button presses or remote. Seems like eeprom problem that I seen before but all reading online says that this tv has power board or main board problem.
                        When tv powers on vizio V logo shows nice on whole screen. picture 1
                        When it goes into tv mode it only shows good picture on left side of screen, right is all scrabbled up. pic 2
                        When i start youtube picture shows on left side fine, right is all scrambled. pic 2
                        When i click video to start playing picture goes black(like when you change...
                        09-02-2021, 08:55 PM
                      • csmith
                        Vizio-D50u-D1 Pulsating Backlights
                        by csmith
                        This Vizio came in the shop with no backlights. Replaced all the strips with replacement from Shop Jimmy. Set now has backlights but lights pulsate on left side. Half the screen brightens up then goes to normal then repeats.
                        Am I looking at a defective strip? Thanks in advance.
                        11-07-2024, 02:56 PM
                      • tusiime
                        How to access Vizio m652i-b2 service menu
                        by tusiime
                        The current main board on my Vizio m652i-b2 only has 1 of 4 HDMI ports working. Also, the coaxial port is not working.
                        So I ordered a replacement board. It boots up the tv, but the display is dark in areas, colors are off, etc. I have seen information online that a setting in the service menu may need to be adjusted. Have tried many ways to access the service menu using remote codes, but none work.
                        Can someone here provide the confirmed method for accessing the service menu on this tv? Thanks in advance!
                        09-15-2023, 09:57 AM
