Philips Magnavox 32MF338B/27
  • MdPhoenix
    • May 2010
    • 50
    Re: Philips Magnavox 32MF338B/27
    Got one of the Ebay boards. Showed up in beautiful condition. The TV works flawlessly now. Thanks for the assistance all!
    • aaronwt6
      • Apr 2013
      • 855
      • US
      Awesome. Thanks for the update!
      • DIYGuy12
        • Jan 2015
        In this thread the pictures are of the inverter board and the part is referenced as the power supply/inverter board. The eBay link is for the power supply board. Is the issue caused by the Inverter board (part number BA8AF0F01032) or the power supply board (Part number BA8AF0F01023-1). I have no burn marks on either board, but have the issue with the green light flashing when power is selected "ON", display flashes and then the TV shuts down and the red standby light is on. I can hear a slight buzz noise coming from the Inverter board when powering on.
        • Terryfictv
          • Mar 2011
          • 124
          I have the same Model....the very slight buzz is usually a shorted zener diode
          or very possibly, more than one shorted! I replaced D644 43v 1watt on the power board, but now need some help identifying D635 zener diode. Marking looks like 20B, but not sure. It is glass, 1/2 watt..... Can anyone help ?
          • Terryfictv
            • Mar 2011
            • 124
            Found MTZJT-7720B = 20v zener.
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • m1ch43lzm
              by m1ch43lzm
              05-12-2025, 08:37 PM
            • spantor
              Activate power board Philips 40PFH40009/88 tv
              by spantor
              Hello partners.
              Could someone tell me how to make this Philips TV source work without the mainboard being connected? The model of the board is EAX65423701 (2.1) and the model of the Philips TV is 40PFH40009/88.
              The TV is dead, there is no standby light, however there is a voltage of 12v on the pins ( included 12v VAU ) and 3.2v on the PS-ON pin (see photo) when the power board is connected to the main board. If I disconnect both boards I only get 8 volts on 12v pins. I would like to rule out a fault in the main board by making it work, but so far no one has been able to tell...
              02-11-2024, 05:07 PM
            • silikon77
              Philips 70PUS7855/12 bad colors when applying the tape fix on teh T-con board
              by silikon77
              Hi!
              Got an 70 inch Philips tv model 70pus7855/12 from scraps and I decidet to give it a go. I'm an enthusiast but no porfessional in the electronics.
              Found some advices watching youtube nad came up with this:
              It came with no picture, after diagnosing it I found out that the right side of the T.con board was faulty.
              I taped down the clock signals and I got a picture but the left side of the panel has less pronounced colours. Only the right 3rd side of the panel has good colors.
              See attached picture.
              I tried a few combinations to block individual clock...
              01-02-2025, 02:26 PM
            • Hakuu
              by Hakuu
              Hi There,
              More Details
              TV Model - LG OLED77G1PUA
              07-12-2023, 02:37 PM
