Samsung LE26A457 Lcon Board.
  • zerocool
    • Jul 2013
    • 13
    • gwent
    Help, My Samsung TV suddenly decided to die on me.
    After reading some of the posts, it would seem that other members have had the same problem of the dreaded flashing red LED and no picture. I checked and found that the backlight was on, so it would appear that the power board was okay as I could not see any bulged capacitors.
    I did however find that the small 2 amp fuse on the Lcon board was blown and also a small inductance was also burnt up.
    I purchased an identical board of ebay, and fitted this but on powering up, the very same inductance burnt up on the replacement board.
    Not wanting to purchase yet another Lcon board and blow this one as well, My questions are: was this just a faulty board in the same manner as the original?
    or is it a fault with another board or the screen itself.
    I have not heard of the screen blowing the LCON board, but if anyone has any suggestions as where to go next I would be very grateful.
  • zerocool
    • Jul 2013
    • 13
    • gwent
    Re: Samsung LE26A457 Lcon Board.
    Sorry all about my earlier posting, it should read the TCON board and not the LCON board. ( Hanging my head in shame)
    • notallbad
      • Oct 2012
      • 1190
      Any chance you can get some photos up of both sides of the PS board and the T-Con(LVDS).
      Also do you have a multi meter to take some readings?
        The LCD panel may have shorted out TFT Driver ICs which are mounted on the flexible circuit board between the LCD glass panel and the PCB.
        It looks something like this:http://s807.photobucket.com/user/bud...tml?sort=3&o=5
        • sordids999
          • May 2013
          • 2152
          ok got this tv today its got sound but no picture the backlight comes on but i can just see a image,checked voltages to invertor seem fine so...
          any ideas
          • sordids999
            • May 2013
            • 2152
            i can just about see a image but very faint
              Check panel manufacturer.
              I reckon tab bonds - I've had a few like this - they're pretty easy to fix. (Done four so far.)
              • sordids999
                • May 2013
                • 2152
                photo added
                  Hmm, usually ChiMei V260B1 with this fault. You can try the tabs, but no experience myself with this AUO panel. Could also be GAMMA fault, that is common with AUO. Can you post a pic of T-con?
                  • sordids999
                    • May 2013
                    • 2152
                    done
                      Another one with AS15G Gamma voltage ref. IC in AUOPTO T-CON.
                      http://www.shopjimmy.com/auo-55-07a9...-con-board.htm
                        Was going to say check gamma voltages but can't see all of them there. Check what you can from VGAMA1 thru VGAMA12. Odd(?)
                        • sordids999
                          • May 2013
                          • 2152
                          Vgama 1 6.46v
                          vgama 6 7.15v
                          vgama 9 7.10v
                          vgama 10 7.15v
                          vgama 11 7.10v
                          vgama 12 7.96v
                          vgama 14 8.03v
                          vgama 17 8.67v
                          vgama 22 10.07v
                            From a quick look at what's available, it's bad. So replace AS15 or t-con.
                            • sordids999
                              • May 2013
                              • 2152
                              thanks searching right as we speak
                              • sordids999
                                • May 2013
                                • 2152
                                Ok then board arrived and fitted colours seem really bright but the strangest thing is I can see the menu on the screen still, seems to be a slight delay
                                • sordids999
                                  • May 2013
                                  • 2152
                                  There seems to go a delay on the TV writing that shows up on screen sits there for ages
                                    Check those gamma volts again - there is a chance the board you got is bad.
                                    • sordids999
                                      • May 2013
                                      • 2152
                                      Vgama 1 14.93v
                                      vgama 6 14.75v
                                      vgama 9 10.33v
                                      vgama 10 8.67v
                                      vgama 11 8.55v
                                      vgama 12 7.97v
                                      vgama 14 8.02v
                                      vgama 17 8.67v
                                      vgama 22 10.09v
                                      • sordids999
                                        • May 2013
                                        • 2152
                                        Any luck anyone?
                                        • ohren
                                          by ohren
                                          09-08-2023, 05:24 PM
                                        • C152Heavy
                                          by C152Heavy
                                          Summary for TL-DR readers:
                                          • VCC pin (18) of PFC...
                                          01-11-2023, 02:53 PM
                                          09-07-2024, 05:50 AM
                                        • Nicktronic
                                          Samsung Power Supply Board BN44-00874F
                                          by Nicktronic
                                          Hey everyone,
                                          This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
                                          Anybody...
                                          03-17-2025, 06:20 AM
