Philips 42" Plasma - Model 42PF7320A
  • Injustice
    • Jul 2013
    • 18
    • Trinidad & Tobago
    Re: Philips 42" Plasma - Model 42PF7320A
    I will replace the original Y buffers tommorrow and check to see if the flashing stops.
    Presently I do not have a Digital Voltmeter, but I believe I can buy one.
    No oscilloscope available
    • Injustice
      • Jul 2013
      • 18
      • Trinidad & Tobago
      Right,
      I changed back to Original Y buffers first - No change - Still Flashing Red Screen
      Then I changed back to the Original X Board - No Change also - Still Flashing Red Screen
      I did notice that there were 2 Green led lights on the "A2 board" don't know it proper name - [ photos attached ]
      One was Solid green ( inner ) and the other was blinking (outer, closer to the A2 writing ) in the same sequence as the flashing of the screen.
      Also there was a Humming sound coming from the Y Main board area, the hum was in the same sequence as the flashing of the screen. and blinking of the green light.
      Does this mean anything ?
        It sounds like you got a defective Y-buffer board which has caused damage to your Y-main board.
        • ajshoe
          ajshoe
          • Dec 2012
          • 477
          • usa
          tom,
          Have a Phillips 50PF9630A with smeared blotchy picture. assumed X sustain was bad - checked x sustain IPMs, checked out good. I see you mentioned something about a cracked resistor on control board - do u have any more info on where this resistor is located ?? Don't believe my x-sustain board is bad. no bad caps, voltages are good, panel comes on with smeared blotchy pic, menu button does nothing visible. do u remember old post heading ??? thanks
          • celiabrown
            Issue with Plasma Philips 37inch chassis FTL2.1
            by celiabrown
            Hello guys,
            My Plasma Philips 37inch chassis FTL2.1 does no picture ,and goes into protection mode after 30 seconds (red led blinks at 3Hz).
            Can someone has any symptom like this ?
            Thanks​
            05-09-2024, 10:56 PM
          • G33RT
            Philips 8200 series 65PUS8204/12 stuck at Philips Logo
            by G33RT
            Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
            It does power up when pressing the power button.
            I already try the power button while plugin the plug with no result.
            Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
            Could this be an PSU or eMMC issue ?
            07-19-2025, 03:43 AM
          • double_DD
            Philips curling iron - is this a common AC cable?
            by double_DD
            Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
            As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
            Not sure if this is something Philips proprietary, or a standard, but the cable plug...
            08-18-2025, 10:04 AM
          • janos6662000
            Philips 47PFS7509/12 LCD TV problem
            by janos6662000
            Hi
            I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
            When i applied cable signal to check image, i had normal picture, but TV was restarting.
            I downloaded original firmware and applied the update, but the problem remained.
            From a colleague i received a "factory package software" which is a lot bigger.
            I made another firmware update, but still did not solve the problem.
            Somewhere on the way the error got worse, because at the moment the...
            08-12-2025, 12:54 PM
          • aidanmo
            Philips 43PUS7506/12 - Loud blown out sound
            by aidanmo
            I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
            I thought maybe the speakers got damaged, so I replaced them - no dice.
            • Using the internal speakers, it always happens.
            • Using the headphone jack, it never happens.
            • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
            02-28-2025, 03:13 PM
