Philips 42" Plasma - Model 42PF7320A
  • ajshoe
    replied
    Re: Philips 42" Plasma - Model 42PF7320A
    tom,
    Have a Phillips 50PF9630A with smeared blotchy picture. assumed X sustain was bad - checked x sustain IPMs, checked out good. I see you mentioned something about a cracked resistor on control board - do u have any more info on where this resistor is located ?? Don't believe my x-sustain board is bad. no bad caps, voltages are good, panel comes on with smeared blotchy pic, menu button does nothing visible. do u remember old post heading ??? thanks
    replied
    It sounds like you got a defective Y-buffer board which has caused damage to your Y-main board.
  • Injustice
    replied
    Right,
    I changed back to Original Y buffers first - No change - Still Flashing Red Screen
    Then I changed back to the Original X Board - No Change also - Still Flashing Red Screen
    I did notice that there were 2 Green led lights on the "A2 board" don't know it proper name - [ photos attached ]
    One was Solid green ( inner ) and the other was blinking (outer, closer to the A2 writing ) in the same sequence as the flashing of the screen.
    Also there was a Humming sound coming from the Y Main board area, the hum was in the same sequence as the flashing of the screen. and blinking of the green light.
    Does this mean anything ?
  • Injustice
    replied
    I will replace the original Y buffers tommorrow and check to see if the flashing stops.
    Presently I do not have a Digital Voltmeter, but I believe I can buy one.
    No oscilloscope available
    replied
    With the original Y buffers in place, does it still flash?
    I think your new X-main is defective though I did go through a similar process with another member on this forum -- three X-main later we determined it was a cracked resistor on the control board, the resistor was responsible for sending an important signal to the X-main causing identical symptoms to X-main fault.
    Do you have any access to a digital voltmeter, or an oscilloscope?
  • Injustice
    replied
    No change after replacing the X main. which was changed 1st.
    After changing the Y buffers - the screen turned Bright red and started flashing / blinking, "like a turn signal"
    replied
    You should just be able to clean those with isoproypl alcohol. So you saw -no- change in picture after replacing the X-main and Y-buffer?
  • Injustice
    replied
    done
  • Injustice
    replied
    working on them now
    see attached now
    replied
    Can we see a picture of the corrosion/deterioration?
  • Injustice
    replied
    Re-posting
    Ok, got the parts and did the following :
    Changed the X main board - but there was no difference in the display
    left the X-main in and then changed both the Y- buffers - this caused the screen to turn totally red and began flashing in 1 second pulses.
    I did notice however when changing the X main, that of the 3 ribbons on the right that connects the screen with the board :
    The Top one was OK ie. the gold band was in tact - mostly
    The Middle one was lacking some gold on the band
    The Bottom was in a bad state - about 50% on the gold on the band was missing - interspersed across the band.
    It looks that it was consumed - missing parts for proper connectivity to occur.
    Please tell me your thoughts ...
  • Injustice
    replied
    Originally posted by Injustice
    Anyone wish to take a stab at this ...
    tom66
  • Injustice
    replied
  • Injustice
    replied
    Please tell me, your thoughts ...
    replied
    X-main is common vertical, Y-main is scan vertical. It is a little strange, the X-main would be more accurately called a Z-main (LG use Z-sustain) or common driver. It has nothing, at all, to do with the columns.
  • Injustice
    replied
    X-axis is horizontal and Y-axis is vertical right ?
    and I am having issues with both
    the ''X" issue is more predominant and visible in my case,
    the "Y" lines are there too, just not as visible.
    replied
    I'm pretty certain the X-main is at fault as well, you would not see the black part of panel with Y-buffer fault.
  • Injustice
    replied
    Originally posted by tibimakai
    I would just replace the upper and lower Y boards. The bottom chip still looks OK.
    I have started on these TVs, I still have a bunch of these Y buffer chips on hand.
    Ordered both the upper and lower Y-buffer boards and the X-main, just to be safe.
  • Injustice
    replied
    Originally posted by tom66
    Who made the plasma panel in this set? Order boards from that. They may be marked as Philips boards, but they are most likely made by Samsung.
    Just checked, Made by Samsung.
    and that answers my question :P
  • tibimakai
    replied
  • celiabrown
    Issue with Plasma Philips 37inch chassis FTL2.1
    by celiabrown
    Hello guys,
    My Plasma Philips 37inch chassis FTL2.1 does no picture ,and goes into protection mode after 30 seconds (red led blinks at 3Hz).
    Can someone has any symptom like this ?
    Thanks​
    05-09-2024, 10:56 PM
  • alro7779
    Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
    by alro7779
    Hello, guys!
    The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
    09-14-2025, 12:25 AM
  • G33RT
    Philips 8200 series 65PUS8204/12 stuck at Philips Logo
    by G33RT
    Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
    It does power up when pressing the power button.
    I already try the power button while plugin the plug with no result.
    Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
    Could this be an PSU or eMMC issue ?
    07-19-2025, 03:43 AM
  • double_DD
    Philips curling iron - is this a common AC cable?
    by double_DD
    Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
    As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
    Not sure if this is something Philips proprietary, or a standard, but the cable plug...
    08-18-2025, 10:04 AM
  • janos6662000
    Philips 47PFS7509/12 LCD TV problem
    by janos6662000
    Hi
    I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
    When i applied cable signal to check image, i had normal picture, but TV was restarting.
    I downloaded original firmware and applied the update, but the problem remained.
    From a colleague i received a "factory package software" which is a lot bigger.
    I made another firmware update, but still did not solve the problem.
    Somewhere on the way the error got worse, because at the moment the...
    08-12-2025, 12:54 PM
