Magnavox LCD 37mf437/37 chirping
  • mr2013e
    Elc. Engineer
    • Jul 2013
    • 41
    • TURKEY
    Re: Magnavox LCD 37mf437/37 chirping
    big cap voltage(at full work of power board)=1.41(sqrt 2) x line voltage
    result is DC voltage and for monofaze line voltage
    but i dont know for line voltage 120vac in usa , they have 300-370 vdc (at full work) on big cap .
    it is not necessary for me.
      With PFC circuit, voltage is boosted to around 380V DC, with no relation to input AC voltage, in standby it is 1.4xAC voltage because PFC circuit is disabled (low efficiency at low load.)
        Learning about PFC Booster.
        • steinless
          • Aug 2013
          • 37
          • singapore
          hey any updates on this? i have the same problem
          http://*************/photo/my-images/703/t6wj.jpg/
          http://*************/photo/my-images/191/mlle.jpg/
          mines is v 3 though,
          replaced the caps. looking at the diodes mentioned next. but was thinking to just chuck the whole thing if after the diodes it doesnt work.
          mine measures 13 volts output.
          have sound, no image.
          gecko friend the print board, see the black rusted area. doesnt seem to affect the board though.
          • Rio_Grande
            • Aug 2013
            • 8
            I was going to start a new thread but don't have permission. Same tv 47mf437b/37 chirping when it should be powering up, might get a touch of sound or a few seconds of backlight before it stops trying.
            I have read several threads where several different caps were changed but none where it concludes that this was a specific part. I am just trying to narrow it down. I would buy a replacement board, but the only ones I can find are 350.00.
            I can solder and replace caps, but I am not much use with a multi meter. Not opposed to learning though. We don't have the money to buy a new board and certainly not a new tv.
            Any help will be appriciated. .
            • topfli8979
              • Oct 2012
              • 311
              Had a buddy with a good working power supply laying around, installed, chirping is still there. So its gotta be the main board.
              • elpelado
                • Mar 2014
                • 8
                • united states
                #27
                i fixed mine by buying a kit from ebay and replacing all the parts they sent me on the PSU. it worked out great
                • withalligators
                  • Jun 2013
                  • 267
                  Sorry to resurrect an old thread, but my issue is on the same TV and I figured it better that all the info for future reference be in as few a places as possible.
                  I have the same TV, with power supply 715T2454-2 S/N 07386. It looks a bit different from the other ones I've seen pictured on various threads. For starters, the 3 tall caps at C952, C951, C953 were all PF nichicon caps, and the one at C955 was a VR series Nichicon. The soldering job looked sloppy so not sure if it was a repair job or a revision of sorts.
                  I had the chirping issue, and replaced the two zener diodes at ZD904 and ZD902 because they were burnt. I also replaced all the other caps (besides the 4 Nichicon and big 450V Capxon one) on the board with the same rating Panasonic or Nichicon ones.
                  The TV now works, but there is a very high pitched whine when it is plugged in, and slowly dissipates after it is unplugged.
                  I'd like to sell this TV, but don't want to sell something that might crap out. What else can I replace to make this thing bulletproof?
                  Cheers,
                  Alex
                  • withalligators
                    • Jun 2013
                    • 267
                    Bump, any ideas?
                    • plbproductions
                      • Oct 2014
                      • 28
                      I have a a 37" lc370wx1 and when i got it i it would turn off and on i open up and found someone replaced the 2200uf 45v cap badly i resoldier it and it work for about 10 minutes then quit again the power light stayed green and ever 15 secods the inverter board would ight the screen flicker then shut off. i replaced all the caps on the board execept the 45v 2.2uf still the same thing so i replaced that cap with a 2.2uf 450 v cap and now it doesn't flicker but the inverter board still light up every 15 seconds and power light still solid green the board is like the first picture posted on page one.
                      • jdkruse
                        • Dec 2015
                        • 11
                        I know this is a old thread but I have a 47mf437B/37 replace the four caps and still have chirping and no power. which diodes should i replace?
                        • withalligators
                          • Jun 2013
                          • 267
                          See my post (#28) just a few above yours. I detail what I replaced to get it working pretty well. Still had a bit of a high pitched whine, but it got better with time.
                          • cheeky2
                            by cheeky2
                            05-25-2024, 03:27 AM
                          • karatzdi
                            Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
                            by karatzdi
                            I know some might say... just buy another one. Sell it as parts..!
                            So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
                            Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
                            Spent some time downloading the Service...
                            06-11-2024, 08:38 AM
                          • nicktasios
                            Macintosh Quadra 840AV PSU
                            by nicktasios
                            I had my Quadra 840AV (which I recapped and had working) plugged in for some time without using it and randomly decided to turn it on today. Unfortunately it did not turn on. After checking the PSU, I found out I was not getting anything from 12V, only from the 5V rail. After a few minutes, I removed the PSU and plugged it back in the electrical outlet and it suddenly started making a weird sound and soon after smoke started coming out. I quickly unplugged it. I opened it up but on first instance I didn't see anything out of the ordinary really. I later turned it back on and one of the MOVs blew...
                            12-22-2024, 05:07 AM
                            HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
                            This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                            09-12-2024, 02:30 PM
                            HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
