L37 HDTV 37" Vizio LCD TV No Picture,
  • Glitcher
    • Mar 2013
    • 673
    • USa
    Got a L37 HDTV Vizio. Plug in the power cable, the standby light turns on orange. Press the power button and standby light turns green but there's no picture, no backlight, not even a flicker.
    Tried using a flashlight, clicked the menu button to look but I don't think I saw anything on the screen, I looked real hard but seems to be nothing. No visible bulging caps.
    I haven't found any common problems with this model around. Anyone have any ideas?
  • capkid
    • Oct 2010
    • 1339
    Re: L37 HDTV 37" Vizio LCD TV No Picture,
    Do you have sound? Have you checked your PSU output voltages?
    LG Plasma Mal-Discharge Correction Service
      I second that, check the ON/OFF (or ps_on) pin to see what DC voltage you are getting, and the 12v, 24v pins.
      • Glitcher
        • Mar 2013
        • 673
        • USa
        Not sure if I have sound since I have no idea which input it is on.
        Theres 3 connectors on the PSU, the red wires go to each inverter board and the white wires go to the main board.
        Measuring while pressing the power button to "on"
        B - 3.03 V on both
        A - 2.51 V on both
        V1 - 5.27V
        V2 - 0.83V
        Remote - 2.95V
        V3 - All measures 0 V <-- seems theres no voltages going to the inverter boards, what does this mean?
          "Remote - 2.95V" That is the PS_ON signal, it is OK.
          V3 is the 24VDC for inverter, which is 0V, bad.
          V2 is the 12V for audio amplfiers, bad.
          Both of above are bad.
          I will disconnect the both V3 cables from the board and see if you will get the 24VDC back, if not, more trouble shooting in the power supply board will be required.
          A and B are for BL_ON and Dimming signals for the inverter board, they are OK.
          • Glitcher
            • Mar 2013
            • 673
            • USa
            So I removed the connectors to the inverter boards, and I measured the V3 pins on PSU and still get 0V.
            So this an issue with the Power Supply?
              Yes, the 12v/24v power supply section is not working. Did you inspect the board real close to see if you locate any blown/burnt components?
              • Glitcher
                • Mar 2013
                • 673
                • USa
                Nothing that's obviously seen. Guess I'll be checking components. Are there any particular?
                  I'd also try starting PSU with a resistor and main board disconnected. 470 ohm resistor from 5V standby to REMOTE should do the job.
                  • Glitcher
                    • Mar 2013
                    • 673
                    • USa
                    Soldered a 470 resistor from V1 Standby to REMOTE. I plug in the TV and get nothing. Power doesn't come on.
                      I did not think anything will happen since your PS_ON is good per your post:
                      Remote - 2.95V
                      You can check the DC voltage right at the two legs of the main 450VDC filter cap to see if the PFC Voltage booster is working or not, it should have about 160VDC in standby, and about 380V when TV is ON.
                      • Glitcher
                        • Mar 2013
                        • 673
                        • USa
                        Measuring in standby I get 160.6V
                        Once I press power button and the standby led turns green and I'm getting 158.5V
                          OK, so the PFC Voltage booster is not working, that will cause the 12v/24v to start up.
                            There is a common fault on this model with the PFC diode failing short which may cause your issue, fuse does not usually blow it just won't work.
                            • Glitcher
                              • Mar 2013
                              • 673
                              • USa
                              Ah I see, so what exactly is the PFC voltage booster? Which is the PFC diode.
                                PFC voltage booster boosts the 160V DC to 400V DC, for several reasons.
                                There will be a diode, mounted to a heatsink, which forms part of this booster -- it will be on the primary side, and likely near the big cap. Diodes are marked "Dnnn" where nnn is a number.
                                  It looks like it has blown part in the PFC section.
                                  • Glitcher
                                    • Mar 2013
                                    • 673
                                    • USa
                                    I think that burnt looking part was just old dried flux, gave it some cleaning and it still looks good.
                                    Just checked the PFC diode and MOSFET out of circuit and they both checked out good...
                                      Look at the P/N of that PFC IC, it may be just a bad PFC CHIP.
                                      • Glitcher
                                        • Mar 2013
                                        • 673
                                        • USa
                                        The Part Number is
                                        N1653
                                        PDHD
                                        is there a way to test it
                                        • fharris1977
                                          Vizio D50u-D1 Dead Set No Standby
                                          by fharris1977
                                          Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                          12-28-2023, 10:25 AM
                                        • SS454
                                          vizio e650i-a2 backlight flashes then turns off
                                          by SS454
                                          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                          panel: au optronics T650HVN05.4
                                          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                          https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                          08-20-2020, 03:57 PM
                                        • csmith
                                          Vizio D50u-D1 Powers up no picture
                                          by csmith
                                          I replaced the backlights all good. Two months later set was dead, had a shorted D9100, replaced all good again.
                                          Now months later set powers up,backlights light ok,no picture. 12volts missing from fuse on tcon. 12VA on power
                                          supply is 19 volts. Changed D9100 again, same, 12 volts measures 19. Am I looking at a power supply or mainboard
                                          issue. Set will power up with remote but not power off....
                                          07-11-2025, 11:52 AM
                                        • brithepi2k
                                          Samsung UE75TU7020k No picture, Standby blinks 2 times
                                          by brithepi2k
                                          My Samsung UE75TU7020k lights up fine when one of the ribbon cables are disconnected from the main board, lights stay on but not getting half a picture, I do the same with the other ribbon and put the other one in and lights stay on but not getting half a picture. The standby light flashes 2 times then reboots then it then tries to come back on again and just keeps looping until I take either one of the ribbon tables out (doesn’t matter which one I take out it stays lit when either one is out). I’ve tested the backlights but all working with none shorting out, I’ve replaced the main board...
                                          04-23-2025, 10:05 AM
                                        • gavric
                                          Vizio M70-C3 Half picture is bad, main board on its last leg?
                                          by gavric
                                          Hello, i am working on Vizio M70-C3. It can hardly power on, it takes 15 power button presses or remote. Seems like eeprom problem that I seen before but all reading online says that this tv has power board or main board problem.
                                          When tv powers on vizio V logo shows nice on whole screen. picture 1
                                          When it goes into tv mode it only shows good picture on left side of screen, right is all scrabbled up. pic 2
                                          When i start youtube picture shows on left side fine, right is all scrambled. pic 2
                                          When i click video to start playing picture goes black(like when you change...
                                          09-02-2021, 08:55 PM
