Sony KDL - 52W4100 powers off after turn on, gives 14 blinks
    Re: Sony KDL - 52W4100 powers off after turn on, gives 14 blinks
    I would be thinking about INV ERR but it might be spiking as it powers off or it might be a very quick spike your meter cannot detect. So it's hard to be sure.
    • tibimakai
      • Jan 2012
      • 3680
      Tom, what is the difference between balancer and inverter?
        Balancer balances a fixed supply between all bulbs equally.
        Inverter generates a supply for each bulb separately, which is balanced.
        • withalligators
          • Jun 2013
          • 267
          Is there anything else I should be trying? Are these worth toying with?
          Going to the D4Z board from the main G5 power board is a plug that has these pins: BALANCER_ERR, REG12V, GND, INV_ERR, BACK_LIGHT, DIMMER, GND
          And going from the D5 board from the D4Z board are is a plug with the pins: OCP2, INV_DRV_1L, GND, INV_DRV_1H, GND, V-FB1, GND, VCC(12V)
          There is also a second plug going between the main and the power board with a litany of REG12V, UNREG15V and such if those would be helpful.
          Thanks again!
          • withalligators
            • Jun 2013
            • 267
            Also, Tibimakai, if it's not possible to get this unit up and running you can have the TCON for the TV you posted for the cost of shipping.
            • tibimakai
              • Jan 2012
              • 3680
              Thanks, but I already replaced it and the TV is working(the 46").
              That one in the picture it's gone, I haven't picked it up.
              Lately I have to replace all the Sony main boards and even some Samsung ones too.
              I wouldn't be surprised, that yours may need to be replaced too.
              • tibimakai
                • Jan 2012
                • 3680
                Did you get a T-con or main board?
                • withalligators
                  • Jun 2013
                  • 267
                  I replaced the main because it seemed as though it was throwing a false error. Error persists though, but I have a while before I have to return it. I'm learning a lot about this stuff from all the help I get here, but I'm still fairly clueless on my own. I've managed to fix a SONY 46BX420 that wouldn't power on by swapping the main board, and a Samsung 32 something-something by swapping the powerboard out which had all kinds of cap damage, cracked resistors, and burning on one of the heatsinks. With these not-obvious component level problems though, I'm lost.
                  • tibimakai
                    • Jan 2012
                    • 3680
                    I'm not an expert myself, but I have managed with these guys help to repair a couple of TVs.
                    I would check the tubes(ccfl), inverter transformers, make sure they are showing the same resistance with in 3%.
                    I have just found this one:
                    http://losangeles.craigslist.org/sfv...938254836.html
                    • tibimakai
                      • Jan 2012
                      • 3680
                      You are sure you have a good board? You can't trust Ebay boards.
                      Recently I had a couple "good" boards returned. I have got other ones, from retech.com and those fixed the TVs. Both Sonys with T-con and mainboard issues. Actually the KDL-46W4100 needed the mainboard and the KDL-40V4100 the T-con.
                      • withalligators
                        • Jun 2013
                        • 267
                        I have no way of testing to see if the main I purchased is OK or not. Same story, cracked screen but everything else functions fine, etc etc.
                        Is there a way?
                        • tibimakai
                          • Jan 2012
                          • 3680
                          Tell to the seller that it's not good and send it back. Get another one, from somebody else.
                          • withalligators
                            • Jun 2013
                            • 267
                            But...I'm not sure that it's bad. Or if the main was really even the problem.
                            • withalligators
                              • Jun 2013
                              • 267
                              Bump with this, in case it got missed:
                              Thanks again!
                                Is there a way?
                                It is hard to tell. But some people get frustrated with their broken TV and hit it. They break the screen, drop it off at the recycle, someone picks it up, assumes the boards are good and that's how dodgy boards get on eBay and other sites.
                                • tibimakai
                                  • Jan 2012
                                  • 3680
                                  If it didn't fix your issue, then assume that it's a bad board.
                                  • withalligators
                                    • Jun 2013
                                    • 267
                                    I realize that, and I'm going to go ahead and return the board anyway, as it didn't fix the issue. It's a $20 restocking fee, which is no big deal. My question is, how sure are you that the main board is the issue, and I don't, in fact, have a bad panel? Should I tell them it's defective and try to get a full refund? What are symptoms of a panel with bad drivers or one that is otherwise nonfunctional? There are no lines or anything on it when it powers up. Does the 14 blink code definitely originate from one of the inverter boards and not from the Tcon board? Would it help if I posted a video?
                                    Thanks again guys, sorry to always be second guessing.
                                    • withalligators
                                      • Jun 2013
                                      • 267
                                      Hey folks. The seller said he's extend the return period if I like so I could do more testing and such. Any input? Or just go ahead and return it?
                                      • withalligators
                                        • Jun 2013
                                        • 267
                                        There's some pretty good reading here. Specifically pg76-81, and 57-68. Leads me to believe that it the error isn't generated from the INV_ERR or BALANCER_ERR circuits. So my only option left would be a TCON (considered part of the panel), short of replacing the panel itself (not happening). If anybody seconds this after reading through, I'll give a TCON a shot.
                                        Thanks again folks.
                                        • withalligators
                                          • Jun 2013
                                          • 267
                                          Hey guys, quick question as I have a few free hours to get back to this set:
                                          I'm going to start testing the inverters. There are like a million of them. I'm going to set my multimeter on 2 or 20 AC Volts, put one probe on gnd and one on the test pad. If I get one that read's too high or too low when the backlight comes on, I will mark that transformer. Can I do this with the TCON unplugged? The set will stay on for a few minutes before shutting down that way. Otherwise its just a few seconds.
                                          Sound good thus far?
                                          My question is: Once I determine which ones are bad, how do then determine whether it's the transformer or the bulb?
                                          Thanks again for the help!
                                          Alex
                                          • jason123
                                            Sony XR-55A80J OLED TV 5 blinks - Troubleshooting steps
                                            by jason123
                                            Hi there,
                                            I see a couple of posts related to the troubleshooting of similar TV. The one I have is acting slightly differently and I'd love your help.
                                            So it has the 5 blinks. Previous owner got a TCON, no luck. Got a new Main board (though he didn't do the USB firmware update), again, no improvements.
                                            I see 2 posts that are relevant:
                                            https://www.badcaps.net/forum/troubl...j-oled-5-blink
                                            https://www.badcaps.net/forum/troubl...g-hardware-dev...
                                            10-29-2025, 02:01 PM
                                          • matwan
                                            Sony XR-55X90J 5 blinks
                                            by matwan
                                            I have problem with SONY 55X90J. After several check status is as below;
                                            1. Running power board as stand alone:
                                            TCON_12V =~ 12.6V
                                            EVDD V On Max 24V= 19V.
                                            2.
                                            Running power board with TCON as stand alone:
                                            Effect as below, attched.
                                            3. When bottom LVDS cable is disconnected no blinks, but of course no TCON 12V and EVDD.
                                            "I'm almost sure it's a defective panel, but maybe someone has encountered a similar issue on their screen.
                                            Best regards....
                                            09-28-2025, 04:26 AM
                                          • GoodCapDude
                                            Sony XBR-75X940E intermittent 6 blinks error code
                                            by GoodCapDude
                                            Hi everyone. First post on Badcaps!
                                            I am trying to fix a Sony 940E from 2017 that either starts normally (and works perfectly until turned off) or goes straight to the 6 blinks error code without showing anything on the screen. It is frustrating to know that it can still work perfectly but is barely usable because of the difficulty starting it up. I am willing to try to short the BL_ERR but I would like to avoid that if possible. Does anyone have a view on this? Thanks a lot....
                                            09-20-2025, 06:07 AM
                                          • AK_777
                                            Sony KD-65A1 Repair – 4 Red Blinks Error
                                            by AK_777
                                            Hi everyone!
                                            I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
                                            Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
                                            02-20-2025, 04:15 PM
                                          • Abel Bejan
                                            Sony Vaio does not turn on, overheats
                                            by Abel Bejan
                                            I am quite noob in advanced electronics, however I'm trying to fix a Sony Vaio PCG-71211M laptop mainly because I love old hardware. I don't want to send it to a technician because this computer is not important for me, I want to fix it as a hobby.
                                            Shortly, this laptop does not display any video output when turned on, no POST, nothing. The keyboard leds are on and I can actually turn Num Locks on and off. Sometimes the laptop turns itself off straight away, sometimes, mostly after some attempts, the laptops enters a loop in which the cpu fan spins very aggressively and the CPU,...
                                            01-11-2025, 10:11 AM
