please help me on how to open samsung syncmaster T190
  • jhunvidz
    • Jun 2013
    • 27
    • philippines
    hi,
    please help me how to open my samsung syncmaster T190 back cover.
    please provide image or videos.
    thanks
  • smason
    • 1652
    Re: please help me on how to open samsung syncmaster T190
    Check this thread:
    https://www.badcaps.net/forum/showthread.php?t=29068
    Different model, but many monitors are similar.
    • jhunvidz
      • Jun 2013
      • 27
      • philippines
      i just want to know on how to remove the stand that is mounted at the back of the cover.
      • t.j.
        • Apr 2010
        • 383
        • canada
        it should have its own screws! youtube for a vid on disassemble of monitor..
        http://www.youtube.com/results?searc...be.jFn3P2jB95M
        • jhunvidz
          • Jun 2013
          • 27
          • philippines
          but this monitor is not the same as what is in the video...please help...thanks.
          • lexwalker
            • Feb 2011
            • 307
            • Malaysia
            Check my post here: Electronics Theory and Troubleshooting > Troubleshooting Computer Displays > Samsung SyncMaster T190, pwr led flashing > Post #8...
            • jhunvidz
              • Jun 2013
              • 27
              • philippines
              thanks guys,
              i already open the monitor.but my problem is the capacitors are ok.
              the monitor dont have back lights what is the problem of my monitor???
              • martyparish
                • Dec 2012
                • 313
                Are you sure that the capacitors are okay? Did you test them with an ESR meter? They can go bad without any visual signs!
                What exactly are the symptoms with the monitor?
                • jhunvidz
                  • Jun 2013
                  • 27
                  • philippines
                  it will about 3-5 seconds then no more back light but i can see image but light.
                  • martyparish
                    • Dec 2012
                    • 313
                    Could you please upload some photos of the board(s)?
                    • jhunvidz
                      • Jun 2013
                      • 27
                      • philippines
                      here is the photo
                        It has one of those commonly fail high voltage inverter transformer. Check the secondary winding resistances.
                        • jhunvidz
                          • Jun 2013
                          • 27
                          • philippines
                          budm i already replace the transformer but there is another problem occur it blinks every 5seconds the caps are ok...
                          what are the other problem of this monitor?
                          • newtothis
                            • Mar 2013
                            • 1556
                            • england
                            As stated... Have you checked the ESR of the caps?
                            • jhunvidz
                              • Jun 2013
                              • 27
                              • philippines
                              i don't have ESR here..sorry
                              • jhunvidz
                                • Jun 2013
                                • 27
                                • philippines
                                newtothis i already check the caps with an LCR all caps are ok....
                                • newtothis
                                  • Mar 2013
                                  • 1556
                                  • england
                                  Just to check though... Does your LCR meter have an ESR meter built in? If it doesn't you can't know that the caps are ok unless the ESR itself is tested
                                  • jhunvidz
                                    • Jun 2013
                                    • 27
                                    • philippines
                                    i already change all the capacitors the problem occur...
                                    • newtothis
                                      • Mar 2013
                                      • 1556
                                      • england
                                      What output voltages do you get from the PSU?
                                      • jon koay
                                        • Jun 2013
                                        • 8
                                        • Malaysia
                                        Hi, I am having a similar made and model monitor like jhunvidz and also having the same problem but mine switches on for about 5 to 10 minutes before going black. Changed all 9 capacitors (including the large one) and a diode. Made no difference. Lately found out the 330k resistor has gone high (414k ohms). Replaced resistor and the fault still exist. Will be checking the couple of transistors to see if they are faulty. Will get you posted.
                                        Jon
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          09-06-2024, 06:20 PM
