LG W2452T Back removal
  • wildwilf
    • May 2013
    • 2
    • canada
    How do you get the back off?
    I know there is 1 screw under the stand mount.
  • smason
    • 1652
    Re: LG W2452T Back removal
    Hi, and welcome to BadCaps. Oh and good day eh! </obligatory Canadian>
    Take the stand off. Remove any screws you see on the back, and the VESA mount screws if any.
    Carefully pop the front bezel off. If you can get it started use something thin and stiff, but not metal so as not to damage the plastic. I use a guitar pick, between the bezel and the back..
    Careful of any wire running to the buttons on the front.
    Once the bezel is off, the rest should be obvious, and you'll be amazed at how little holds these things together.
    I'm sure there are some youtube videos on monitor disassembly out there somewhere that may help.
    • smason
      • 1652
      This video should be similar to yours, he just brute-force pops the bezel off, which usually works on LG, some other brands are too tight and you break clips.
      http://www.youtube.com/watch?v=JFukhCMPUEU
      • wildwilf
        • May 2013
        • 2
        • canada
        Thank you, I've been fixing TV's and stuff for over 20 years and this is the first time I've ever been stumped.
        Again thank for the info
          Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
          by sam_sam_sam
          This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
          I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
          I am comparing them to a brand new one that I installed
          The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
          I going to let it run for several days before I remount back on the wall next to the...
          09-05-2024, 06:48 PM
          Surface Mount Fuses Fundamentals Datasheet
          TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
          TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
          10-07-2024, 06:07 AM
          HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
          This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
          09-12-2024, 02:30 PM
          HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
          HP ProBook 430 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
          This specification for the HP ProBook 430 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + APC Back-UPS 700VA boardview and 430 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
          09-06-2024, 08:10 PM
