Vizio E421VA Need help
  • TJV
    • May 2013
    • 5
    I got this TV from a neighbor. It was manufactured in 2011. I have replaced the power supply. The original had 2 burnt resistors. It now has power at the 24 volt ,12 volt and 5 volt pins. The Vizio badge lights when I plug the power cord in. The badge goes to bright white when I turn on the power button. I am not getting anything on the screen or sound.
    I would like to know what route I need to take to diagnose this. I have a multimeter and have changed a few caps on another old vizio with success.
    In advance
    TJV
  • mcross
    • Sep 2011
    • 201
    Re: Vizio E421VA Need help
    Vizio TVs are known for problems with the main board. I would start there
    • TJV
      • May 2013
      • 5
      I have 2 main boards. I just plugged an hdmi cable in and got sound.
      I know the the tv was used on hdmi1 and I plugged in a cable off my laptop and got sound. I am not getting any backlighting.
      Any suggestions would be appreciated.
      TJV
      • 1beertap
        • Mar 2009
        • 219
        While the tv is on with sound, take a flashlight and look closely at the screen to see if there is a faint picture. If so, you may have an inverter issue or a broken/bad ccfl. If not, check main board or replace it.
        • TJV
          • May 2013
          • 5
          Thanks I'll try that tonight.
          TJV
            Any good clear pictures of how all the boards are connected?
            • TJV
              • May 2013
              • 5
              Here are some pics.
              I see the power supply is set up in tandom for inverters.
              When it was dark this morning I powered up the set and
              saw the right side back light try to fire for a half second.
              I then swapped the power feeds to see if the left would try to
              fire as well. It didn't. I swapped them back and right fired again.
              Wouldn't that mean the left ccfl was bad and shutting down the
              power supply?
              TJV
              http://s1278.photobucket.com/user/tjv2/library/
              • TJV
                • May 2013
                • 5
                That test with the florescent bulb is cool as it gets.
                The other will take me a few to digest.. lol
                Not giving up..
                Thanks TJV
                • Tynan Dill
                  by Tynan Dill
                  Assuming...
                  11-22-2024, 01:46 PM
                • SS454
                  vizio e650i-a2 backlight flashes then turns off
                  by SS454
                  vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                  panel: au optronics T650HVN05.4
                  72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                  link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                  Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                  https://www.shopjimmy.com/vizio-56-0...-power-supply/
                  Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                  08-20-2020, 03:57 PM
                • mrtek
                  Vizio M65-C1
                  by mrtek
                  Hi.
                  picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                  When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                  This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                  07-14-2025, 07:28 PM
                • howardc64
                  Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                  by howardc64
                  Failure Symptom
                  No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                  Where is the short?
                  Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                  Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                  05-27-2025, 02:56 PM
                • howardc64
                  Vizio SmartCast TV software bug that looks like hardware
                  by howardc64
                  Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
                  It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot....
                  11-16-2024, 05:17 PM
