no picture on my samsung 50 inch plasma
  • jose6326
    • May 2013
    • 707
    Having problems with my tv model PN50C550G1F
    When I turn on the tv the power on sound comes on but the screen is black
    No functions work with the remote
    I watched a few youtube videos and most of them said it would be the power supply board, y main and/or y buffer board
    I visually checked all the caps and none of them were physically blown
    Initially I was getting the following voltages
    Vs 211 actual 80
    Va 55 actual no reading
    Vsc -193 actual -.084
    Ve 86 actual 23
    2ve 77- I cant find this test point on any board
    So I bought the power supply board, y main and y buffer board on ebay
    After I replaced the 3 boards I got the following voltages
    Vs 211 actual 205
    Va 55 actual 54
    Vsc -193 actual -195
    Ve 86 actual 73.7
    2ve 77 - I still cant find this on any board
    Now when I power on the tv the power on sound comes on and the screen illuminates for about 3 seconds and shuts off (blacks out)
    I began to recheck the connections and I decided to check the ribbon cables
    I disconnected and reconnected the ribbon cable from the logic board to the main board and now the screen stays illuminated.
    I tried the remote and still no functions work
    Another thing I noticed is that there is 2 led's on the logic board
    Before I replaced the boards the led on the right would blink
    After I replaced the boards the led on the right would still blink
    After I reconnected the the ribbon cable from the logic board to the main board the right led turned off and now the left led is blinking not sure if this is relevant
    So now I am at this point looking for help
    I don't want to continue throwing boards at it
    Please help and thanks in advance
  • jose6326
    • May 2013
    • 707
    Re: no picture on my samsung 50 inch plasma
    Here are pics of the
    power supply
    Y main
    Y buffer
    X main and buffer
    Main board
    Logic board
      See here:
      https://www.badcaps.net/forum/showpo...61&postcount=2
      See if you get test patterns.
      • jose6326
        • May 2013
        • 707
        Tom66 sorry to sound like an idiot but I do not know which is the Lvds cable
        Is it the one to the main board or to the y main
        I was guessing its the one to the main board but I want to be sure
        I have the 4 pin connector jumpered just need to identify the lvds cable
          You were correct, it is the one going to the main board.
          Topmost connector of this image.
          https://www.badcaps.net/forum/attach...8&d=1369516918
          • jose6326
            • May 2013
            • 707
            I will get to it today when I get home from work
            What test patterns am I looking for?
              This is what it should do. (Not my video.)
              http://www.youtube.com/watch?v=JCtF5...ature=youtu.be
              (Ignore the flicker on the patterns: it is due to the camera.)
              • jose6326
                • May 2013
                • 707
                Cool I will test it today
                I will record it as well
                • jose6326
                  • May 2013
                  • 707
                  i jumpered number 3 and 4 on the 4 pin connector disconnected the cable to the main board, turned on the tv and i did NOT receive any test pattern as shown in the youtube video you provided
                  the tv turned on the screen illuminated and stayed illuminated and that is it
                  what is the next step or do you kow the issue?
                  thanks
                    Yes, I have a hunch. Can I have a picture of the long thin boards that run along the bottom of the plasma panel? You may need to remove the speakers.
                    N.B. Do not disconnect any connections from these boards while the set still has power or you will FUBAR the plasma panel.
                    • jose6326
                      • May 2013
                      • 707
                      Here are the pics of logic buffer board E and F
                      I also tested the fuse that is on the buffer board E and it is not blown
                        What voltage do you get either end of that fuse you checked?
                        • jose6326
                          • May 2013
                          • 707
                          i checked voltage to the fuse on the logic buffer E
                          with power on -0.000
                          voltage with no power .005 then i double checked and it went to -0.000
                          ohms 0.1
                          • jose6326
                            • May 2013
                            • 707
                            Tom66 i was reading another thread where you are helping someone with sound but no picture on a Bush (samsung) tv
                            the issues on that tv are similar to mine
                            do you think it is my xmain board? the reason i ask is because the Ve test point on the x main board reads 73.7 but should be 86
                            im just throwing ideas out there you are the tech
                            let me know
                            thanks
                              Not at presently suspecting X-main no.
                              I am thinking control or bad panel.
                              • Vipermarty
                                ISP Guru
                                • May 2013
                                • 28
                                • Northern Ireland
                                Hi Jose, yes that was my thread, i've been watching yours too
                                ViperMarty
                                • jose6326
                                  • May 2013
                                  • 707
                                  I really hope its not the panel
                                    Dark room, confirm if you have screen glow or not.
                                    • jose6326
                                      • May 2013
                                      • 707
                                      Yes there is a glow
                                      When I turn on the tv the screen illuminates (glows) shuts off after 3 seconds then the chime comes on then the screen illuminates (glows) again and stays illuminated (glowing)
                                        OK, show me how you set up the test patterns, because if that does not work you probably have a control board issue.
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • Cooperr
                                          Samsung 59" plasma PN59D550C1F seeking advice on mystery power board issue
                                          by Cooperr
                                          I picked up this TV from Facebook Marketplace, original owner described it as "screen went black after a pop" and I hoped to see an obvious fuse or cap to replace. Doesn't seem to be the case, but my experience and electrical knowledge are kind of limited for this.
                                          The power board (BN44-00445A, see attached) turns on and Vs and Va seem to momentarily have power, then they steadily drain to zero over a minute or two as if they're only getting power from capacitors. I've been measuring Vs and Va from the test pads, with and without the other boards connected to the power board...
                                          10-21-2025, 01:11 PM
                                        • ohren
                                          Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
                                          by ohren
                                          I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
                                          I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
                                          The models launched in 2018 and 2019 respectively....
                                          09-08-2023, 05:24 PM
                                        • alltvrepairs
                                          Plasma Samsung PS-50C96HD Main board BN94-01223C switches off supply after few seconds
                                          by alltvrepairs
                                          I have this almost brand new Plasma was well stored. I would like to repair it for a friend of mine.
                                          I have noticed that it works for few seconds then switches Off the Power_ On signal. Have disconnected boards and left maion board and power supply and still the same. The power supply with PS_ON and VA signals On stays on so it is not a problem in the power supply.
                                          Any one met this problem in the past?...
                                          10-08-2025, 07:34 AM
