no picture on my samsung 50 inch plasma
Re: no picture on my samsung 50 inch plasma
So, you have low Ve on X-main?
Do you have low -Vsc too?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Ve is a little low... but not a big deal, it's usually got approx +/-20V tolerance on these panels.Last edited by tom66; 08-17-2013, 07:43 AM.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
The X-main waveform looks better than the Y-main.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Ok tom I retested but I did 2 things which I will mske 2 separate posts
1st I put back in the original xmain and xbuffer to see if the wave pattern changed
To me it pretty much looks the same
But the Ve us a little bit higher but not much
Ve: 73.4vComment
Were the both at the same V/div?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Can you try dropping the intensity and changing the focus to make the trace sharper? I can see most of both sustain waveforms so it should be working, not sure why it is not.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
I have the same problem to and know nothing about tvs. Caps are not visibly bad. It's a 51" samsung plasma. Mine does everything you guys have been talking about except the dark room. It does not illuminate. At first there's a fuzzy red flash at the top of the screen then nothing besides a little LED light on the bad flashing. I need helpComment
It's probably best to start your own thread, including the model number.Comment
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by ohrenI hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
The models launched in 2018 and 2019 respectively.... -
by C152HeavySamsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
Summary for TL-DR readers:
• Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
• Have obtained Samsung schematic & service documents - Can upload if helpful.
• Have read ALL applicable threads
• C1818 and CP820 replaced as low hanging fruit
• CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
• VCC pin (18) of PFC... -
by ermalsHi all!
I've recently run into an issue with my Samsung UN55H8000AF LED TV displaying no image. I've done quite a bit of research in terms of what could be wrong with it. Below are the steps I've taken prior to reaching out here for some assistance:
1. I've tried replacing the T-Con board (BN95-01594A), twice and have still experienced the same issue with all the boards I've tested with.
2. I've tried to remove one side of the ribbon cable that goes from the T-Con board to the panel and still not getting any image on left or right side.
3. I've checked voltages... - Loading...
