no picture on my samsung 50 inch plasma
  • jose6326
    • May 2013
    • 707
    Re: no picture on my samsung 50 inch plasma
    I still have the scope
    I can retest and take pics if you want
      Can you repeat the Y-main test? Except this time also turn the intensity/brightness thing down, as that will make the image sharper.
      • jose6326
        • May 2013
        • 707
        Tom please look at pics
        Im not sure if I set the time/div in the correct position
        The dial has a tab and 2 black hash marks
        Is the 5ms supposed to be in between the hash marks or is the tab supposed to be over the 5ms?
        • jose6326
          • May 2013
          • 707
          I went ahead and tested it with the 5ms in between the hash marks
          Please see pics
          • jose6326
            • May 2013
            • 707
            Here is the test with the tab over the 5ms
              The waveform looks OK except it looks to be like the SUSTAIN portion is missing! I am not sure why... A missing SUSTAIN portion will cause no image. Can you go over to testing the X-main?
              • jose6326
                • May 2013
                • 707
                how do i test the xmain?
                  Here -- I think end nearest the connector.
                  • jose6326
                    • May 2013
                    • 707
                    Hey tom I been really busy and haven't had a chance of testing my tv
                    I will get to it tonite or tomorrow
                    Hopefully you haven't given up on helping me
                    • jose6326
                      • May 2013
                      • 707
                      Hey tom I want to give it another shot at this problem child of a tv lol
                      I put the test lead on the xmain and this is what I got
                      • capkid
                        • Oct 2010
                        • 1339
                        I don't want to derail you from your testing, but can you post the current panel voltage readings?
                        LG Plasma Mal-Discharge Correction Service
                        • jose6326
                          • May 2013
                          • 707
                          Vs 205.1
                          Va 54.1
                          Vsc -195.2
                          Ve 72.5
                          • capkid
                            • Oct 2010
                            • 1339
                            I haven't read the whole thread thoroughly, but the service tips point to a bad X-main (see page 3):
                            http://www.toms-service-manuals.com/...&Search=Submit
                            If Ve is low or missing and Vs is OK, the failure is with the X-Board since the Ve is generated by the X-Board from the Vs supplied by the SMPS. Please note in some rare cases the Ve may be generated by the Y-Board feed to the X-Board.)
                            I'd remove the X-main from the TV to see if you can locate a bad component. Check the heat sink components first. I'd be careful with this TV, since the Y-main and X-main are chained; you risk damaging your Y-main.
                            • jose6326
                              • May 2013
                              • 707
                              I actually replaced the xmain and buffer
                              I still have the original one
                              • capkid
                                • Oct 2010
                                • 1339
                                Ok. I saw a mention of the X-main, but I wasn't sure if you'd gone ahead with a purchase: https://www.badcaps.net/forum/showpo...8&postcount=25
                                Was that the last thing you changed in the TV?
                                • jose6326
                                  • May 2013
                                  • 707
                                  The xmain was the last thing I changed
                                  Before that I changed the psu, the ymain ,y buffer, and logic board in that order
                                  • capkid
                                    • Oct 2010
                                    • 1339
                                    Strange. One thing I didn't get about that last sentence from the service guide, and maybe Tom can shed some light, is that it says that Ve is generated by the Y-main feed to the X-main in some rare cases. Since many of these Samsungs have the Y-main and X-chained without a connection from the PSU to the X-main, I don't understand why this is rare.
                                    • jose6326
                                      • May 2013
                                      • 707
                                      The only thing i havent changed is the main board and the e and f buffers
                                      • jose6326
                                        • May 2013
                                        • 707
                                        i might just order the main board
                                        but i will test the mosfets on the heat sink first on the xmain
                                        • jose6326
                                          • May 2013
                                          • 707
                                          So does that mean there might be something wrong with the y board if it is feeding Ve to x board?
                                          Im just throwing stuff out there
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                          • ohren
                                            Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
                                            by ohren
                                            I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
                                            I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
                                            The models launched in 2018 and 2019 respectively....
                                            09-08-2023, 05:24 PM
                                          • C152Heavy
                                            Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
                                            by C152Heavy
                                            Summary for TL-DR readers:
                                            • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
                                            • Have obtained Samsung schematic & service documents - Can upload if helpful.
                                            • Have read ALL applicable threads
                                            • C1818 and CP820 replaced as low hanging fruit
                                            • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
                                            • VCC pin (18) of PFC...
                                            01-11-2023, 02:53 PM
                                          • alltvrepairs
                                            Plasma Samsung PS-50C96HD Main board BN94-01223C switches off supply after few seconds
                                            by alltvrepairs
                                            I have this almost brand new Plasma was well stored. I would like to repair it for a friend of mine.
                                            I have noticed that it works for few seconds then switches Off the Power_ On signal. Have disconnected boards and left maion board and power supply and still the same. The power supply with PS_ON and VA signals On stays on so it is not a problem in the power supply.
                                            Any one met this problem in the past?...
                                            Today, 07:34 AM
