Replacing a bad cap on TV
  • justjoe
    • May 2013
    • 35
    • England
    Re: Replacing a bad cap on TV
    Originally posted by tom66
    Can we get a close up of this sticker too? We can perhaps look up the panel datasheet from it.
    OK thanks I will do that, ive just soldered the cap back on and the picture is fading in quickly then fading our slowly and does that every 5 or 10 seconds, same symptoms basically so its not the cap.
    I will go take those pics.
    • justjoe
      • May 2013
      • 35
      • England
      can we get a close up of this sticker too? We can perhaps look up the panel datasheet from it.
      • justjoe
        • May 2013
        • 35
        • England
        Red probe on the exposed metal around each pin leaving the power supply.
        Do you mean these pins?
          No. The main board has video inputs like HDMI, scart on it.
          You want to follow the connectors from the main board, any one which goes to the power supply you need to test.
          The TV should be powered on.
          • justjoe
            • May 2013
            • 35
            • England
            ok i will go give that a try thanks, do i need the datasheet to find out what the correct readings should be?
            • justjoe
              • May 2013
              • 35
              • England
              #26
              I think I found the datasheet
              http://www.panelook.com/V390HJ1-L02_...ter_15149.html
                The datasheet is not currently necessary, however, it may prove useful later.
                • justjoe
                  • May 2013
                  • 35
                  • England
                  #28
                  ok heres the voltages...
                    Did you test with the connectors in place? This must be done to provide a "load" to the board. If you did so the power supply would appear to be good.
                    The next stop is to look at the main board. Do you see that long thin black cable going from the main board to the top of the LCD screen? Can you get a picture around the connector for it on the main board?
                    • justjoe
                      • May 2013
                      • 35
                      • England
                      #30
                      Yes they were connected and tv powered up.
                      Heres the pic...
                        Good, thanks. Can you check the voltage on the top left pin of that connector with and without the cable installed?
                        • justjoe
                          • May 2013
                          • 35
                          • England
                          #32
                          ok its reading 12.84v both connected and disconnected.
                          Do you think this is looking like a new mobo replacement? because its hard to find one and i guess they are expensive.
                            That's good, then.
                            It's looking like a panel problem to me.
                            One more thing to confirm: Can you upload a video of the problem? I'm struggling to imagine it well enough.
                            • justjoe
                              • May 2013
                              • 35
                              • England
                              #34
                              That's good, then.
                              I thought of that but the only time i get any kind of picture is when i leave it unplugged for days, but even then its mostly just a black screen, but with working backlight.
                              when you say panel do you mean expensive? lol
                                LCD panel is not economical to replace (80~150% price of TV), and the fading effect you describe is common on some LCD panel failures.
                                Sometimes you can apply a tab bond shim. This sometimes works, but not always.
                                First, please make that video if you can..
                                • justjoe
                                  • May 2013
                                  • 35
                                  • England
                                  #36
                                  That's good, then.
                                  This is exactly the same problem i have.
                                  http://www.youtube.com/watch?v=VuKIo_m2n9I
                                  I had this problem with an old pc monitor, i removed the back and pressed down on the components and unplugged things and replaced them and it worked so i was hoping this might be the same.
                                    That's the backlight. In a dark room, when the screen is "dead" (that is it has powered up and it has faded out) do you see screen glow?
                                    • justjoe
                                      • May 2013
                                      • 35
                                      • England
                                      #38
                                      yes the glow is very bright, the screen isnt actually black its blue from the brightness of the backlight.
                                        So it's probably a panel problem, like this
                                        https://www.youtube.com/watch?v=purk_SyiT44
                                        Different symptoms, probably the same cause.
                                        • justjoe
                                          • May 2013
                                          • 35
                                          • England
                                          #40
                                          well ive tried doing what he did and those ribbons seem to be ok, i dont get anything happening to the screen when i touch them.
                                          • BigPete
                                            Panasonic Heatpump Dryer Repair
                                            by BigPete
                                            I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                                            The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                                            In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                                            Unfortunately the whole machine has to come apart to fix it.
                                            I have...
                                            11-01-2025, 06:40 PM
                                          • AquaMan Ua
                                            by AquaMan Ua
                                            05-17-2025, 09:40 AM
                                          • Alfieh
                                            NAD C320BEE repair possibly bad capacitors
                                            by Alfieh
                                            hey Im very new to repairing electronics with capacitors as well as using a multimeter so I need so help/guidance fixing this issue
                                            recently I was handed a family members old NAD C320BEE that they had in their loft for storage for a few years but when powered on it went into power safety mode due to a problem on the protection circuit somewhere before it went into storage I was told it worked fine I found lots of people online talking about how the capasitors are known to be pretty bad in this model and can cause this issue the only problem being I don't have much experience sorting...
                                            11-19-2024, 04:55 PM
                                          • Andre Gilbert
                                            by Andre Gilbert
                                            Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                            Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                            11-20-2024, 08:52 PM
                                          • yuzupatogik
                                            Help with replacing Capacitors on Altec Lansing ATP 3
                                            by yuzupatogik
                                            I have this old (2004?) Altec Lansing ATP3 and i would like to replace the capacitors. I have identified 34 out of the 36 of them as Samxon GR of various capacities and voltages.
                                            I can't find datasheets for the Samxon in any of the following variants:
                                            10000uF 25 v - this one i really want to replace because i suspect it is what causes a dull hum regardless of the volume knob position or if the source is plugged in. I am eyeballing the Rubycon 25PK10000MEFCGC18X35.5 for this purpose. So if i pay a 10x the price part for shipping i might as well go ahead and...
                                            02-14-2025, 04:11 PM
