Dynex DX-LCD32-09 No Picture
  • landyboy
    • Apr 2013
    • 443
    I picked a freebie on this one. Tested Power Board and all appropriate voltages are present. There is no picture, the person I got it off of said it had sound but I am not really sure of that as I can not hook up a source to it. Any thoughts? Tcon? The power light on the front is Red and when I push the power button it turns green.
  • landyboy
    • Apr 2013
    • 443
    Re: Dynex DX-LCD32-09 No Picture
    I went ahead and tested the test point on the tcon and here is what I get
    VDDA 8.20k 3.350v
    VDDD 7.03K 15.20v
    VGL 20.1k -6.2v
    VGH OL 20.94
    • cheapie
      null
      • Jul 2010
      • 849
      Holding a flashlight against the panel in a dark room, is there an image? If so, then you need to look at the backlight inverter. If there isn't, then you should check the other boards.
      • landyboy
        • Apr 2013
        • 443
        There does not appear to be a picture
          So the backlights are not on?
          Pictures of the backlights Inverter board?
          • landyboy
            • Apr 2013
            • 443
            I don't believe so, I can see no lights. I turned the set on green indicator light hit menu button since I do not have a source and can not see anything in a dark room with a flashlight.
              So we need to get the backlights to come on. Cannot do much until we see the pictures of the boards and all the voltage labellings on the connectors.
              • landyboy
                • Apr 2013
                • 443
                From top of board to bottom
                PON 2.503
                GND
                5v 5.179
                G
                G
                16v 15.56
                16v 15.56
                G
                5v 5.108
                G
                9v 9.05
                G
                32v 32.35
                PON 4.827
                PWM 3.277
                G
                G
                G
                24v 23.93
                24v 23.93
                PON 4.826
                PWN 3.277
                G
                G
                G
                G
                G
                24 (5 of them all 23.93)
                  So the inverter board is getting the PON (BL_ON) of 4.827, and alos getting the needed 24v (23.93V) if I read the post correctly?
                  If that is the case, I will need good clear pictures of the inverter board.
                  • landyboy
                    • Apr 2013
                    • 443
                    Yes I believe the inverter is getting the proper voltages. I will post a pic of the inverter soon.
                      There are more than one version of this TV model, as you can see, there are more thna one type of inverter board.
                      http://www.shopjimmy.com/catalogsear...ex+DX-LCD32-09
                      • landyboy
                        • Apr 2013
                        • 443
                        Here are the pics of the inverter board
                          Check the black F1 fuse with '20' on it, more likely to be blown.
                          • landyboy
                            • Apr 2013
                            • 443
                            I see a f201 ans a f301 but I'm not seing a F1 with a 20 on it although I may be blind and am just overlooking it.
                            • landyboy
                              • Apr 2013
                              • 443
                              Ok I did find it it is testing 15K ohms across the fuse. If i'm correct it should read 0 ohms?
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                F1 is bad. A good fuse should measure less than 1.0 ohms.
                                --- begin sig file ---
                                --- end sig file ---
                                • landyboy
                                  • Apr 2013
                                  • 443
                                  Are they hard to solder in? I have done caps and diodes but this seems a little smaller. Can it be bypassed temporarily to prove that it is the only fault? Thanks!
                                  • retiredcaps
                                    • Apr 2010
                                    • 9271
                                    Like anything, practice helps. See
                                    http://www.youtube.com/watch?v=3NN7UGWYmBY
                                    Personally, I would not jumper a fuse for any reason. It is there for a reason. A component around it could be shorted or bad causing the fuse to blow. Sometimes a fuse does go bad on its own.
                                    • landyboy
                                      • Apr 2013
                                      • 443
                                      Ok, I will give it a try. One last question. Is the 20 a reference to 20 amps or 20 ma? Digikey?
                                      • landyboy
                                        • Apr 2013
                                        • 443
                                        I made a temp 1a fuse assembly and it appears the back lighting comes on. I have read you can solder the new fuse on top of the old one, is that recommended?
                                        • Fly_Among_Stars
                                          VIZIO E70-E3 Half picture with half TCON
                                          by Fly_Among_Stars
                                          I have a VIZIO E70-E3.
                                          Symptoms: Black screen, no picture, but LED backlights are working.
                                          I probed the power board and voltages are as listed on the board.
                                          Main board appears fine, too.
                                          I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
                                          There are two separate ribbon cables feeding the LCD.
                                          If both are connected, the screen is black.
                                          If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
                                          04-24-2023, 08:20 PM
                                        • iglitare
                                          by iglitare
                                          09-04-2025, 07:13 AM
                                        • shelby5041
                                          Samsung LCD TV no picture backlight on no 12v at tcon
                                          by shelby5041
                                          hi
                                          i have a samsung lcd tv
                                          it powers on with sound and backlight but no picture
                                          all voltages from PS are good 12v 3.3v and 5v
                                          whats odd is that at the tcon i tested voltage across the fuse on the tcon and i get 0v
                                          i figured main board issue..so i ordered a used main board....when i put replacement main board in i still have same issue
                                          no 12v at the tcon fuse
                                          i disconnect the panel ribbon cables to rule out any panel issues and i still have no 12v at the tcon fuse
                                          the odds of having 2...
                                          10-08-2021, 08:21 AM
                                        • x_orange90_x
                                          TCL 50S535 bad tcon or panel issue?
                                          by x_orange90_x
                                          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                          03-29-2025, 11:02 PM
                                        • Tr0ll
                                          by Tr0ll
                                          Original T-con:
                                          First replacement T-con:
                                          10-07-2023, 07:48 PM
