Replacing SMD Fuse on T-con
  • capkid
    • Oct 2010
    • 1339
    I found a blown fuse on an LCD TV t-con, and the picture came up fine after I jumped the fuse. Instead of buying a replacement t-con, I was going to replace the fuse, but I'm having a hard time finding an exact spec. match. I contacted Digikey, and they provided a replacement recommendation. However, I'm unsure of the replacement's suitability for this application, since it's amperage is slightly less than the original:
    Exact match: http://www.digikey.com/product-detai...21CT-ND/559655
    Suggested replacement (3.0A instead of 3.15A): http://www.digikey.com/product-detai...32CT-ND/686752
    Would this be a better replacement? http://www.digikey.com/product-detai...5TR-ND/1206513
    Edit: Ugh, never mind. I'm going to use MFU12063.15TR-ND, since the voltage doesn't matter much.
    LG Plasma Mal-Discharge Correction Service
  • jbfr_54
    • Dec 2012
    • 52
    • France
    Re: Replacing SMD Fuse on T-con
    Personnaly I use a standard fuse of the same rating that I connect with two little pieces of wire to the PCB and then enclose it in protective insulating tape and put back the T-Con and its metal shield in place. No need to worry for special fuse as long as rating (3.15 amps fast blow in your case I guess) is the same.
    Regards.
    Jean
    • capkid
      • Oct 2010
      • 1339
      I ended up ordering the 3.15A 63V SMD fuse last night.
      • rswails
        • Jul 2013
        • 7
        Did your new fuse work? I'm curious how you're post install went. I too have the same fuse blown. I am scared it will just blow again cause of some other failed component in the circuit of the tcon board.
        • capkid
          • Oct 2010
          • 1339
          Yes, it worked out great. I wouldn't try to remove the old fuse. Just install the new fuse on top of the old one.
          • Ltank
            • Jun 2013
            • 776
            Fuses are designed with voltage and amperage in mind. Example a 250 v 4 amp should allow 1000 watts of power to run through it. A 125v 4 amp fuse should allow 500 Watts of power to run through it. Voltage rating is important as is the amperage.
              'The voltage rating relates to the ability of the fuse to
              function and extinguish internal arcs when it opens. The
              interrupt rating is how large a short-circuit or fault
              current the fuse can interrupt or stop safely without
              allowing a continuing arc and without damaging the
              fuse body or fuse holder."
              • drykid
                Matsui 175S microwave fuse replacement
                by drykid
                I recently picked up a used Matsui 175S microwave that was powering up (starts, turntable rotates) but not heating. From looking online the most likely culprit was the fuse, but unfortunately in this one the fuse had heated up and fused with the (badly designed) fuse holder and couldn't be removed. I guess this might indicate further issues beyond the fuse itself but at this stage I just want to replace the fuse and see how I go from there.
                Anyway since I couldn't get out the fuse itself the easiest fix was to replace the fuse holder assembly that runs between the...
                12-21-2020, 01:15 PM
              • corrize
                Replacing resistor fuse in Sony DV charger
                by corrize
                Hello, I have 2 old chargers for Sony DV, and I found the same resistor fuse dead. Fuse is a crossing component : 0,47 Ohms (0,125W deduced because the lenght is 3mm). But I can’t find the same for buy.
                So, I want to replace by another like 0 Ohms, 1 Ohms 0,125W,
                It is the same please ? I guess it’s the same, the only change should be the time to burn ? Thanks...
                06-30-2025, 06:59 PM
              • whc14765
                Replacement Fuse - 980TI Gigabyte
                by whc14765
                I have a GIGABYTE Windforce 980TI with a blown fuse. I have already found the root cause for the fuse blowing.
                I need help getting a replacement fuse - I'm fine with waiting some time for some cheap ones from China.
                The fuse says 10A on it. And I'm not sure what package size it is exactly. Also, how do I know if it is a fast or slow fuse?
                04-11-2022, 09:01 AM
              • x_orange90_x
                TCL 50S535 bad tcon or panel issue?
                by x_orange90_x
                Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                03-29-2025, 11:02 PM
              • corrize
                A funny fuse story – Lumix LX100 II
                by corrize
                Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                10-19-2023, 09:58 AM
