Vizio M421VT LED no display
  • ryan74
    • Oct 2012
    • 471
    • usa
    I can't find much info or a service manual for this tv and it is my first Led model.
    When I plug this in the vizio standby/power logo flashes white about 1 minute, shuts off(typical vizio) and nothing else. If I then press power the light stays on white but nothing else happens.
    No sound, no pic, no backlight at all and I do not hear any relays click when plugging in or pressing power.
    Iam not sure on correct voltages and everything looks ok visually.
    Anyone have a similar issue or suggestions?
    Here is what I checked(dc).
    CN902
    Vled = 235.6mV
    #4-1 = 10.69V
    #4-2 = 10.27V
    #4-3 = 10.67V
    #3-3 = 10.65V
    #3-2 = 10.66V
    #3-1 = 10.64V
    Vled = 236.2mV
    Cn905
    Vled = 237mV
    #2-1 = 10.25V
    #2-2 = 10.63V
    #2-3 = 10.64V
    #1-3 = 10.66V
    #1-2 = 10.27V
    #1-1 = 10.67V
    Vled = 237.0mV
    Cn904
    1 = 4.91V
    2 = 2.93V
    3 = 12V
    4 = 12V
    5 = 20mV
    6 = 20mV
    7 = 20mV
    8 = 24.73V
    9 = 24.73V
    10 = 3.09V
    11 = 5.09V
    12 = 5.09V
    13 = 2.8mV
    Power supply # 080GL1927LT
    PCB # 3PCGC10021A-R
    Panel # LC420EUH
  • ryan74
    • Oct 2012
    • 471
    • usa
    Re: Vizio M421VT LED no display
    CN904 connects to main board and had some voltages listed so I relisted it.
    Im still not sure but shouldn't Vled(power supply) and pwr_ok(main board) have voltage?
    Cn904
    1)BL_on = 4.91V
    2)BL_DIM = 2.93V
    3)12V. = 12V
    4)12V. = 12V
    5)G = 20mV
    6)G = 20mV
    7)G = 20mV
    8)24V. = 24.73V
    9)24V. = 24.73V
    10)BS_on = 3.09V
    11)5V. = 5.09V
    12)5V. = 5.09V
    13)PWR_ok = 2.8mV
    main board # is TXACB5K05304(barcode sticker)
    • ryan74
      • Oct 2012
      • 471
      • usa
      After reseating plugs and playing with inputs I get a display, menu, and sound but no backlight.
      So the only issue is no backlight at all.
      I don't know if it is power supply inverter issue to led backlight or a bad led backlight.
      CN902 and CN905 go to backlight. I assume 10v is ok but I have no clue about VLED.
      Im not sure if pwr_ok should have voltage.
      I hate to open panel to look at backlight if I don't have to.
        If you got 24V and BLON going to backlight inverter, check the output going to the LED strips (around 90V or so, probably.)
        • ryan74
          • Oct 2012
          • 471
          • usa
          The power output to led strips I think is CN902 and CN905 on power supply (see above post).
          Nowhere neer 90v.
          So it must be inverter/power board or im confused?
            10V doesn't sound right at all; test it without the LEDs connected, there may be a short in one of the strips (seems fairly common...)
            • ryan74
              • Oct 2012
              • 471
              • usa
              with led wires disconnected I still get 10v on all the # pins.
              vled showed 15mV (connected it was 235mV)
              Looking at the back of power board all the # pins lead to the board atached to top side
              -top side board is labeled:
              LGIT PCB P/N: 3PHAC20004A-R
              LED DRV-12CH
              Barcode # FF4610BPV20L12304
              Could there be 12 led strips(12CH) each being supplied 10v?
              • ryan74
                • Oct 2012
                • 471
                • usa
                Since Iam still unable to confirm if this is power board or led backlight problem, is there an easy way to test or bypass led lamps without opening panel?
                  What's the highest voltage ISOLATED power supply you've got?
                  • martyparish
                    • Dec 2012
                    • 313
                    Nobody has mentioned it yet, but I'd be leery of those "sam young" caps. May or may not help, but they are known junk right?
                    • ryan74
                      • Oct 2012
                      • 471
                      • usa
                      That would be a 12v 1.0A charger or a computer power supply. So testing led probly wont work for me.
                      I may try replacing caps but testing them seems pointless with my multimeters capacitor test. If a cap is bad but looks ok visually my multimeter reads it as good.
                      Better quality pic from shopjimmy below(not my board)
                        If you can beg borrow or steal a 90V, constant current limited power supply that may work.
                        • ryan74
                          • Oct 2012
                          • 471
                          • usa
                          That will be difficult.
                          Im not sure what I should do at this point. It's a repair for a friend so I have to try and keep cost down so I cannot buy boards to just swap and try.
                          If I understand right, there is 12channels feeding power to led strips at 10v. each.
                          How possitive are you it should be more like 90v.?
                          I found a board for $119
                            Probably somewhere in range of 40~90V.
                            Each strip is basically lots of LEDs in series, usually with a resistor to balance the current (and limit fault current.)
                            The controller (green "addon" board) monitors the current overall and regulates the voltage to compensate for small changes in LED operating voltage as the set warms up.
                            That's at least how I think it works.
                              It does have 12 strings of LEDs, the LED's brightness is also controlled by the T-CON board for the dynamic contrast so they can say it has high contrast ratio. You can try disconnecting the cable between the T-CON and the power supply board by that big green board for the LED power supply to see if the LEDs will come on.
                              • ryan74
                                • Oct 2012
                                • 471
                                • usa
                                Thought I would list caps on cold side of board. Maybe it will help confirm voltages I should have.
                                upper left side:
                                2-Samwha BL 200v 33uf
                                2-Samwha ZS 50v 47uf
                                upper right side:
                                2-Samwha MK 10v 1000uf
                                4-Samyoung NXB 25v 330uf
                                2-Samyoung NXB 50v 150uf
                                4-Smawha MK 50v 47uf
                                  It looks like the output (maybe up to 200V) is on VLED. Not sure what the individual points are, then. Have you tested that bridge rectifier on the secondary for shorts?
                                    Those 33uf 200v Caps are for the LED power supply primaRy drive circuits which is fed by the bridge rectifier, they are not for the LED power supply out put side.
                                    Those 50V caps in the leaft side where the output connectors for the LEDs are for the LED power supply output voltages. So I expect the LEDs to be driven by less than 50V.
                                    • ryan74
                                      • Oct 2012
                                      • 471
                                      • usa
                                      no change/no led
                                      • ryan74
                                        • Oct 2012
                                        • 471
                                        • usa
                                        no I haven't. Ill check it.
                                          Acer Spin SP313-51N-509V Hybrid (2-in-1) 3 Specification for Upgrade or Repair
                                          This specification for the Acer Spin SP313-51N-509V Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SP313-51N-509V boardview and SP313-51N-509V schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 11:20 PM
                                          Acer ENDURO EN715-51W-509V Notebook N7 Specification for Upgrade or Repair
                                          This specification for the Acer ENDURO EN715-51W-509V Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EN715-51W-509V boardview and EN715-51W-509V schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 10:00 PM
                                        • SS454
                                          vizio e650i-a2 backlight flashes then turns off
                                          by SS454
                                          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                          panel: au optronics T650HVN05.4
                                          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                          https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                          08-20-2020, 03:57 PM
                                        • mrtek
                                          Vizio M65-C1
                                          by mrtek
                                          Hi.
                                          picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                                          When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                                          This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                                          07-14-2025, 07:28 PM
