olevia #237s11 firmware, corupt???
  • Tvbob
    tvbob
    • 204
    I got this used set up and running, Works good except the tuner won't auto scan. It will take direct entry of analog channels. It is in the (home) mode. Does anybody know of a source for firmware? Or is it something else? thanks
  • selldoor
    Slow Learner
    • 7870
    Re: olevia #237s11 firmware, corupt???
    Is there nothing on that menu for factory reset?
    Try digging around with this - maybe a reset option - googling it does seem a common problem but didnt spot a solution
    How To Enable/Disable Olevia Store/Demo Mode 1.Press Menu button from the remote,
    2.Press Down arrow key until you see the word Picture, then press the Right arrow key,
    3.Press Down arrow key until you see Mode, then press the Right arrow key,
    4.Press Down arrow key until you see Power Up, then press the Right arrow key,
    5.Press Down arrow key until you see Home, then press the Enter key,
    6.Press Menu button four times to exit out from the OSD Menu.
    • Tvbob
      tvbob
      • 204
      Yea , I has a factory reset, And an input source settings reset, Tried both they don't affect the tuner function. The tuner tunes analog stations as you can see in the last pix that shows the set in scan mode with the output of an old VCR in the background I found an olevia website that claimed it had firmware, It set off my computer anti virus software. I know the company is out of the business. Can't even find a used board. Thanks
      • selldoor
        Slow Learner
        • 7870
        You do have analogue stations, still, for it to tune to?
        In Manchester UK all stations are digital and we have to use set top boxes
        for the tuning.
        • Tvbob
          tvbob
          • 204
          Yes, there a few small stations, That broadcast reruns form decades ago. This is what you need to avoid all the propaganda and commercial in the states. LOL
          • cadiman
            • Mar 2010
            • 397
            I have repaired a few different versions of these and I have run into the same issues with some models.
            It just seemed like a cheap tv with cheap firmware so I never did anything about it.
            • Tvbob
              tvbob
              • 204
              Hey cadiman, Good to see a fellow Ohioan on here. I like to buy and repair older lcd's The one's that are heavy, With a metal sub structure like the now defunct olevia's I see shopJixxy is now selling flashed eproms (I assume) You would think the firmware for these sets is hosted on a server somewhere .
              • TheUser
                Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                by TheUser
                Hello to everyone ,
                This is my first post here, and i would like to share with you a small story in case you can help me.
                Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                02-10-2024, 02:07 PM
              • gurj1979
                Ubiquiti firmware help. US-8-150W POE
                by gurj1979
                Hi guys.
                I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
                Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
                So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
                Got New chip and writes good.
                THE PROBLEM...
                It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
                Does anyone have a Good Firmware I can have?...
                07-22-2024, 05:13 PM
              • sikocan
                NP930XED Samsung Galaxy Book2 Pro Laptop PD Firmware Loop
                by sikocan
                I hope this message finds you well. I wanted to share a recent experience I had with a laptop that had a Type-C Port issue, specifically related to a PD (Power Delivery) controller problem. After replacing the damaged PD controller chip with a new one I purchased from AliExpress, the laptop now charges properly and negotiates power as expected, allowing the device to power up. I've replaced this chip twice just in case.
                However, it seems that the laptop's BIOS is detecting an older version of the PD Firmware on the newly installed chip. As a result, it attempts...
                01-11-2024, 01:47 AM
              • skynetto
                MSI Z590 MS-7D07 rev 2.1 EC Firmware
                by skynetto
                Hello there.
                I have this mainboard (MSI Z590 Gaming edge - MS-7D07 rev 2.1) with these symptoms.
                1. SIO_3VA ON
                2. ATX_5VSB ON
                3. 3VDSW ON
                4. Mainboard stucked in Deep_S5 state
                Problem:
                RSMRST Incative. (Obviosly everything dead)
                Tried just for fun to update the BIOS with its Bios flashback function (Push button and USB stick with bios in it).
                Main Bios restored succesfully.
                When updating Bios all the voltages comes on except PCH which is not needed.
                EC Controller: NCT6687D-M
                External SIO Firmware...
                03-17-2023, 10:30 AM
                ME Firmware Cleaning Guide
                by SMDFlea
                Here`s a quick ME Firmware cleaning guide.
                The guide is basic,its main goal is to show you how to use intel FIT,its highly recommended that you all follow the guide posted at win-raid
                (The attached FIT version is 11, if your ME Firmware (FW) is not 11.0.*.* follow the win-raid guide. Use the tools version for your ME FW, for example: ME System Tools v9.1 For systems running ME v9.0 - v9.1)
                A video,software (intel FIT) and practice bios are all included. I`ll post a better video and more advanced guide at a later date.
                1. Open the...
                09-09-2020, 09:10 AM
