I got this used set up and running, Works good except the tuner won't auto scan. It will take direct entry of analog channels. It is in the (home) mode. Does anybody know of a source for firmware? Or is it something else? thanks
olevia #237s11 firmware, corupt???
Re: olevia #237s11 firmware, corupt???
Is there nothing on that menu for factory reset?
Try digging around with this - maybe a reset option - googling it does seem a common problem but didnt spot a solution
How To Enable/Disable Olevia Store/Demo Mode 1.Press Menu button from the remote,
2.Press Down arrow key until you see the word Picture, then press the Right arrow key,
3.Press Down arrow key until you see Mode, then press the Right arrow key,
4.Press Down arrow key until you see Power Up, then press the Right arrow key,
5.Press Down arrow key until you see Home, then press the Enter key,
6.Press Menu button four times to exit out from the OSD Menu.Please upload pictures using attachment function when ask for help on the repair
http://www.badcaps.net/forum/showthread.php?t=39740 -
Yea , I has a factory reset, And an input source settings reset, Tried both they don't affect the tuner function. The tuner tunes analog stations as you can see in the last pix that shows the set in scan mode with the output of an old VCR in the background I found an olevia website that claimed it had firmware, It set off my computer anti virus software. I know the company is out of the business. Can't even find a used board. ThanksComment
You do have analogue stations, still, for it to tune to?
In Manchester UK all stations are digital and we have to use set top boxes
for the tuning.Please upload pictures using attachment function when ask for help on the repair
http://www.badcaps.net/forum/showthread.php?t=39740Comment
Hey cadiman, Good to see a fellow Ohioan on here. I like to buy and repair older lcd's The one's that are heavy, With a metal sub structure like the now defunct olevia's I see shopJixxy is now selling flashed eproms (I assume) You would think the firmware for these sets is hosted on a server somewhere .Comment
by TheUserHello to everyone ,
This is my first post here, and i would like to share with you a small story in case you can help me.
Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help... -
by zklgfsHi,
I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...-
08-11-2025, 02:14 PM -
by gurj1979Hi guys.
I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
Got New chip and writes good.
THE PROBLEM...
It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
Does anyone have a Good Firmware I can have?...-
Channel: Troubleshooting & Designing Networks
by wattageHello Badcaps Community,
The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...-
by sikocanHello,
I hope this message finds you well. I wanted to share a recent experience I had with a laptop that had a Type-C Port issue, specifically related to a PD (Power Delivery) controller problem. After replacing the damaged PD controller chip with a new one I purchased from AliExpress, the laptop now charges properly and negotiates power as expected, allowing the device to power up. I've replaced this chip twice just in case.
However, it seems that the laptop's BIOS is detecting an older version of the PD Firmware on the newly installed chip. As a result, it attempts... - Loading...
