hello, I have a Visio p50 HDTV20A and the bottom half of picture is yellow red with pink lines floating is my tv shot?? or can I replace a board of some sort?? any help would be amazing.
vizio p50 hdtv20a half screen pic if problem attached
Re: vizio p50 hdtv20a half screen pic if problem attached
Just saying, if it were mine, that's the board I would replace.Last edited by cliff_hootarski; 03-22-2013, 07:03 PM.
Sorry, forgot the link:
http://blog.coppelltvrepair.com/2010...er-boards.html
And here is a video:
https://www.youtube.com/watch?v=51SZsfH60EY
I'm going to disagree. The picture doesn't go crazy at exactly half of the screen. Probably the upper buffer -- one lower IC failed -- meaning the chained signal is getting lost for the rest.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
i have the p50 hdtv20a. one of the buffer chips on the upper buffer board was noticeably burnt out, but i couldn't see anything wrong with the ysus board. i replaced the bad buffer chip, now the tv powers on, but only the top 1/4 of the picture comes on. ideas?
Could be other buffer chips bad. The signal between each is chained, so if one goes bad the signal can get lost.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
There are 4 buffer chips per board, and 2 boards. since the top 1/4 of the screen shows picture, i'm guessing the top 2 are working, but something with the lower 2 aren't chaining the signal correctly? and since they aren't chaining, they also cause the lower buffer board to malfunction?
What I'm saying is it's possible that there are additional chips that are failed. In this case I'd look at replacing either the second or third chip, most likely third, from the top.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Check if -Vsc and Vsch are OK. You may only be able to locate -Vsc.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
